bojan25 Posted January 15, 2013 Posted January 15, 2013 prvo na škodi pa na golfu pa na škodi pa na golfu,otpadne,komad pukne,pa visi,pa pukne pa se pitam ima li smisla to uopće imat na autu jer samo se mučim s tim.
Cale Posted January 15, 2013 Posted January 15, 2013 negdje se na stranom forumu povela rasprava i ispalo je da je ipak s razlogom tamo postavljena. Cak i zbog akustike jer smanjuje buku navodno.
bojan25 Posted January 15, 2013 Author Posted January 15, 2013 ma za buku me boli briga.voda i onak ulazi od naprijed po motoru,zupčasti je zaštičen u svom kučištu,aerodinamika isto ne igra jer ne vozim NASCAR..ja bi to skinuo
Kaki Posted January 15, 2013 Posted January 15, 2013 vozim vec 3-4 godine bez te plastike (seat ibiza) , nakupi se prljavštine ... 1 tjedno dobro pranje motornog prostora,i kao novo !
bojan25 Posted January 15, 2013 Author Posted January 15, 2013 Ma to i ja velim,neda mi se svakih 3 dana vezice nove metat.
Pekx Posted January 15, 2013 Posted January 15, 2013 To ti je super stvar kad motor pocne slinit ulje. :lol:
bojan25 Posted January 15, 2013 Author Posted January 15, 2013 ne slini.to je golf 110 konja.suh ko babina pička
Exfreerider Posted January 15, 2013 Posted January 15, 2013 Po zimi je dobro imati radi bržega grijanja i kad se normalno stavi nema otpadanja,moja je preživjela svašta i još je na autu
bojan25 Posted January 15, 2013 Author Posted January 15, 2013 ja imam šugave eibach 35mm pa svugdje zapinjem.kak je tek ekipi na gewindama??
Bushido Posted January 15, 2013 Posted January 15, 2013 Prezivljava i moja... ali ovih dana ju JAKO cujem....
Exfreerider Posted January 15, 2013 Posted January 15, 2013 Prezivljava i moja... ali ovih dana ju JAKO cujem.... Ja je slabo cujem morat cu provjeriti je li dolje :lol:
avanti Posted January 15, 2013 Posted January 15, 2013 ne slini.to je golf 110 konja.suh ko babina pička Moram... AHAHAHAHAHHAHAHAHAHAHHAHAHAHAHHAHAHAHAHHAHAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAHAHHAHAAAAAAAAAAAAA
bojan25 Posted January 15, 2013 Author Posted January 15, 2013 zato sam to i napsial...al fakat ako očeš mogu poslikat motor odozdo ili odozgo....a nisam ga prao nikad u ovih 180 000 kolko sam ja s njim napravio..a dalje je pitanje dal skinut plastiku ili ne ispod motora jer je pri kraju života?
jady Posted January 15, 2013 Posted January 15, 2013 ja imam šugave eibach 35mm pa svugdje zapinjem.kak je tek ekipi na gewindama?? ak znas kak vozit sa gewinde onda nije prob...imao plastiku 2-3 godine na G4 bez problema... razlog je kaj je zvucna izolacija na dizelima a i radi aerodinamike i radi boljeg zagrijanja motora kod dizela...nebi vw stavio nesto ak nije bas potrebno
marek1 Posted January 15, 2013 Posted January 15, 2013 btw jel zna gdje bi se mogla nabaviti takva plasticna ploca za male pare, ja bi to stavio na kombi jer kaplje ulje...
matija0311 Posted January 15, 2013 Posted January 15, 2013 skrojiš ju sam doma od pleha i šerafi na auto
Bushido Posted January 15, 2013 Posted January 15, 2013 btw jel zna gdje bi se mogla nabaviti takva plasticna ploca za male pare, ja bi to stavio na kombi jer kaplje ulje... Za male pare neznam.... sajam neki/oglasnik.... U ducanima nude orginalne i zamjenske..... Ove druge nisu za preporuku... iako tebi u ovom slucaju treba bas tako nesto... A ni cijene nisu "simpaticne"....
Gabre Posted January 15, 2013 Posted January 15, 2013 zato sam to i napsial...al fakat ako očeš mogu poslikat motor odozdo ili odozgo....a nisam ga prao nikad u ovih 180 000 kolko sam ja s njim napravio..a dalje je pitanje dal skinut plastiku ili ne ispod motora jer je pri kraju života? moj isto suh, nemam s tim problema, kilometri su nam eto isti, i meni je potrgana ta plastika, ali to je uredio prošli vlasnik, iako ne znam kako. ja sam i na gevindama, i vozim se svukuda i pripazim i nigdje ne stružem s njom. ako i zastružem to je onda baš po sredini motora, a to je nebitno, oni bočni nosači su se poderali i zato visi...
bojan25 Posted January 15, 2013 Author Posted January 15, 2013 loše su ceste kod mene bile do nedavno(hajdaš dončić došao).kladimo se da nemamo iste km ja sam napravio s golfom 180tkm a kupio ga prije 6god uvoz iz D.
Goertosing Posted January 16, 2013 Posted January 16, 2013 Za male pare neznam.... sajam neki/oglasnik.... U ducanima nude orginalne i zamjenske..... Ove druge nisu za preporuku... iako tebi u ovom slucaju treba bas tako nesto... A ni cijene nisu "simpaticne".... Za A4 taj komad plastike dođe 1000 kn u ovlaštenome satro sam je dok sam imao gewinde ali drži se još nekako
bojan25 Posted January 16, 2013 Author Posted January 16, 2013 sad sam je još pokrpo ali sljedeći put kad opadne ide dole for good
Gringo Posted January 16, 2013 Posted January 16, 2013 Imao sam na ventu pa je pukla. Nikad je nisam prežalio. Buka veća, kroz plitvice zimi se nije mogao ugrijat a o flekama ulja po tuđim dvorištima da ne govorim. Plastika je zakon. Znao sam zimi skoro ostat bez grijanja. Puše mlako. Ali zato Mazda grije ko sunce u egiptu!
jady Posted January 16, 2013 Posted January 16, 2013 loše su ceste kod mene bile do nedavno(hajdaš dončić došao).kladimo se da nemamo iste km ja sam napravio s golfom 180tkm a kupio ga prije 6god uvoz iz D. ja sam svojeg sa 98tkm od buraza iz D kupio..nakon 8 godina sam ga sa 263tkm prodao...malo opreznije voznje i izdrzat ce plastika...
Gonzaga Posted January 16, 2013 Posted January 16, 2013 (edited) Ta plastika također služi kad zapneš u snijegu da se motorni prostor ne zatrpa sa tim bijelim govnom a postoji OEM alu verzija koja zamjenjuje ne samo tu donju ploču nego i one sa strane a šarafi se direktno na šasiju u unaprijed predviđene rupe :naughty: Ja planiram to uskoro ugraditi u auto remetincu. Edited January 16, 2013 by Gonzaga
Luky Posted January 16, 2013 Posted January 16, 2013 Ta plastika također služi kad zapneš u snijegu da se motorni prostor ne zatrpa sa tim bijelim govnom a postoji OEM alu verzija koja zamjenjuje ne samo tu donju ploču nego i one sa strane a šarafi se direktno na šasiju.Ja planiram to uskoro ugraditi u auto remetincu. kolko to košta?
