danijels2006 Posted November 16, 2015 Posted November 16, 2015 Bubi said: je probao tko ove šmrklje za čišćenje interijera? http://www.ebay.com/itm/Auto-Glue-Gum-Gel-Cleaning-Air-Outlet-Vent-Dashboard-Interior-Trim-Panel-Cleaner-/121606480790?fits=Year%3A2002|Model%3AMegane&hash=item1c504fa396:g:RhAAAOSwrklVFRzE&vxp=mtr ili nešto slično, ako postoji...ako ne, što koristite vi profići? i mene zanima el ovo čemu valja
Gabre Posted November 16, 2015 Posted November 16, 2015 ja sam jednom probao nesto slicno, i nekako mi ostavi nekakav malo ljepljivi osjecaj, jednostavno kupite obicni mali penzl/kist za bojanje i s njim se sva prasina pocetka vani za cas. Isto tako ako radis detaljnije pranje unutra, kist i malo vode/sapunice/detailera cuda radi.
Lev Posted November 16, 2015 Posted November 16, 2015 forinta said: Ovaj Fusso Coat Mirror Shine je zbilja extra lagan za nanošenje. Hvala na brzoj dostavi, ni 2 sata od narudzbe nije proslo Nadam se da ce za vikend biti vremena za isprobati to.
forinta Posted November 16, 2015 Posted November 16, 2015 Nema na čemu i hvala tebi na narudžbi Kad isprobaš, javi utiske
Kroky Posted November 16, 2015 Posted November 16, 2015 Lev na plasticnim lajsnama malo jace slojeve stavi!
Lev Posted November 16, 2015 Posted November 16, 2015 Nema tog kod mene nes sitno oko prozora samo, to cu skinuti kad cu voskati. Nego, sta s kromiranom lajsnom? isto to moze ili da je ne diram?
Red Devil Posted December 5, 2015 Posted December 5, 2015 http://forea-ocd.hr/gtechinq-g5-water-repellent-coating-100ml Jel ima sta bolje od toga?
Kroky Posted December 5, 2015 Posted December 5, 2015 http://forea-ocd.hr/soft99-glaco-roll-on-large-120ml ovaj sam stavio na sestricnin auto, nakon 2 tjedna je sajba kao da je oprana prije 5 min. auto vozen svaki dan, negaraziran. poslije 35-40 km/h brisace netreba palit. G5 nisam probao...
forinta Posted December 7, 2015 Posted December 7, 2015 Za početak i jedan i drugi traže prethodno dobru pripremu i očišćena stakla. Nakon toga oba proizvoda se donekle jednako nanose. Aplicira se na staklo u tankom sloju (g5 ide kružnim pokretima preko aplikatora ili mikrofibre a glaco u crtama po dužini ili širini cijelog stakla direktno kroz aplikator na bočici). Ostavi se da se osuši i napravi se buffing. Ovisno o vanjskim uvjetima i temperaturi, 15-30min je vrijeme sušenja. Za glaco se prilikom buffinga negdje treba malo potruditi da se skine i dobro iz svih kuteva provjeriti da je sve dolje ali ako i ostane može se naknadno buffing odraditi nije problem. Stavljao sam oba i meni je Glaco draži čisto zbog brže same aplikacije na staklo. Kasnije se njega malo duže skidalo sa stakla do duše ali no frx.
Kroky Posted December 7, 2015 Posted December 7, 2015 S99 glaco stavljen na sajbu 9.11. znaci prije skoro mjesec dana. NISTA se ne prima na sajbu
CooleR Posted December 8, 2015 Posted December 8, 2015 Ajde vi meni recite koji osvjezivac zraka nije agresivan a dosta dugo traje... pokusao sam sa nekoliko "borica" i kantica iz lidla al nije mi to vise to... Postoji li neko ucinkovitije (makar i skuplje) rijesenje... hvala
Svig Posted December 9, 2015 Posted December 9, 2015 CooleR said: Ajde vi meni recite koji osvjezivac zraka nije agresivan a dosta dugo traje... pokusao sam sa nekoliko "borica" i kantica iz lidla al nije mi to vise to... Postoji li neko ucinkovitije (makar i skuplje) rijesenje... hvala California Scents, stvarno širok asortiman mirisa, traju ti dosta dugo. Imaš i za kućne ljubimce da im ne ošteti osjetiv njuh. http://www.partes.hr/index.php?page=katList&cat=050550
Kroky Posted December 9, 2015 Posted December 9, 2015 i bas super mirise, ali slabog inteziteta al kad stavis 5 komada ko ja, onda je ok
Tomica93 Posted December 9, 2015 Posted December 9, 2015 Tu se moram sloziti s Krokyem, ako je mali auto, onda je ok, al max mj dana
Kroky Posted December 9, 2015 Posted December 9, 2015 (edited) Moj focus, prvo sam unutrasnjost rijesio (netko ga je prao prije i to jako lose, i naravno cijelog zasrao sa dressingom za plastike masnim ko ulje), izvana detaljno opran, gliniran, ociscen iron i tar-xom, ispoliran sa menzernom shc300 i fg400, rijeseno par sitnih ogrebotina i na kraju par slojeva jetseal-a i fuss-a. Na stakla stavljen glaco repelent, na felge fusso vosak i na gume tyre wax. I sad se premisljam dal da ga vozim ili ne (obzirom na vrijeme ) Edited December 9, 2015 by Kroky
_DEX_ Posted December 9, 2015 Posted December 9, 2015 Mene zanima kolko takvo unutarnje pranje kosta za moj A6? Na proljece bi to odradio. Bas onak dubinski.
Gabre Posted December 9, 2015 Posted December 9, 2015 bagatela iskreno za taj posao. smao da kupis koju krpicu i sredstvo za ciscenje i dressing, potrosis 200kn. meni je napetije ovo izvana, odlican posao kroky, bas odlican! :thumbsup: da si mi blize dao bi ti audija da poludis na njemu sa svime sto imas, lak je 10 godina zanemarivan i prepustan cetkama, i raznim praonama. Ja kupio svu opremu, ali jednostavno sastavit dva dana za auto - neizvedivo.
