Jopa Posted October 1, 2013 Report Share Posted October 1, 2013 Imam jedan problemcic, kad ubacujem u 3. brzinu getriba zakrci. Ne zakrci jedino ako stvarno sporo presaltam. Sutra tako i tako moram raskopat getribu pa me zanima dali je to do sinhrona? Koliko znam kad je sinhron los, saltanje je puno teze cak nemoguce ali ne krci. Dali je to ipak problem do sinhrona ili do neceg drugog i kad cu vec imati raskopanu getribu kako da vidim dali je sinhron los ili dobar? Link to comment Share on other sites More sharing options...
Jopa Posted October 1, 2013 Author Report Share Posted October 1, 2013 ne mogu vise editirat a sjetio sam se jos jednog problema.. Naime nekad mi je u leru znalo nesto klamparat, i cim bi stisnuo kuplung prestalo bi. Guglam malo pa kazu da bi to mogao biti lezaj spojnicke, te da zato i 3. krci? p.s. ulje u getribi je novo Link to comment Share on other sites More sharing options...
semper Posted October 1, 2013 Report Share Posted October 1, 2013 Prvo sinhron drugo potisni lezaj, ovako od oka Link to comment Share on other sites More sharing options...
Coupe VD Posted October 1, 2013 Report Share Posted October 1, 2013 Prvo sinhron drugo potisni lezaj, ovako od oka Da, upravo to. Istrošen sinhron...i isto tako istrošen druk ležaj. Kad već sve skidaš, promjeni cijeli set...da ne bi za 10-20 tisuća opet skidao radi korpe ili lamele... Link to comment Share on other sites More sharing options...
the-rider Posted October 1, 2013 Report Share Posted October 1, 2013 to drugo ce prije biti lezaj spojnicke, on lupka onako dok ne stisnes kvacilo Link to comment Share on other sites More sharing options...
Zeljko_M Posted October 1, 2013 Report Share Posted October 1, 2013 Imam jedan problemcic, kad ubacujem u 3. brzinu getriba zakrci. Ne zakrci jedino ako stvarno sporo presaltam. Sutra tako i tako moram raskopat getribu pa me zanima dali je to do sinhrona? Koliko znam kad je sinhron los, saltanje je puno teze cak nemoguce ali ne krci. Dali je to ipak problem do sinhrona ili do neceg drugog i kad cu vec imati raskopanu getribu kako da vidim dali je sinhron los ili dobar? To ti je mehaničar ostavio turpiju kad je zadnji puta raskopao mjenjač! I meni se dogodilo.... Link to comment Share on other sites More sharing options...
obie Posted October 2, 2013 Report Share Posted October 2, 2013 najvjerojatnije sinhron.... tako je i meni bilo Link to comment Share on other sites More sharing options...
Alfaludak Posted October 2, 2013 Report Share Posted October 2, 2013 jebat ces se u pak dok izvadis gornji konusni lezaj sa piramide Link to comment Share on other sites More sharing options...
Jopa Posted October 2, 2013 Author Report Share Posted October 2, 2013 Znaci najbolje da odmah sve lezajeve zamijenim.. nadam se da nisu bas skupi Alfa ti imas iskustva, kolko su cca svi lezajevi i semerizi? Upravo sam ispustio ulje iz getribe i imao sam cca deci vode unutra od 2 litre ulja.... A sto se tice sinhrona, kako njega na kraju provjeriti? Mozda je krcalo sto je bilo vode unutra? Alfa imas koji dobri sinhron od 3.? iste su getribe od 16vt, 20vt.... 2 Zeljko - To nije losa ideja uopce, razmisljam si ako je nema da je ubacim unutra, dobro dode da poturpija srhove sa zupcanika Link to comment Share on other sites More sharing options...
