Risbo Posted March 21, 2016 Share Posted March 21, 2016 to je model u rangu ovog Einhela - http://www.ekupi.hr/Einhell-TC-CD-12-Li-aku-busilica-435402.aspx To je nešto slabiji model.... a ionako ne kupujem u Kauflandu pa bi skupio naljepnice nikad...pogotovo jer akcija vrijedi do četvrtka... Link to comment Share on other sites More sharing options...
bojan25 Posted March 22, 2016 Share Posted March 22, 2016 na INA-i ima boscha sad zelenog,ima i šrafilica neka Link to comment Share on other sites More sharing options...
Coupe VD Posted March 22, 2016 Share Posted March 22, 2016 na INA-i ima boscha sad zelenog,ima i šrafilica neka Da...taman sam zalijepio onih 15 nalja i idem danas/sutra po onu aku busilicu. Gledao sam malo i kod nas je nema ispod 900 kuna...vani je oko 100 eura na amazonu. Link to comment Share on other sites More sharing options...
bojan25 Posted March 22, 2016 Share Posted March 22, 2016 obavezno nek ti ovjeri račun pečatom na pumpi Link to comment Share on other sites More sharing options...
SVEN Posted March 22, 2016 Share Posted March 22, 2016 to na ini je takvo smece da neznam Link to comment Share on other sites More sharing options...
Risbo Posted March 22, 2016 Share Posted March 22, 2016 Evo usporedba Bosch na Ini i ovaj Einhell... Bosch PSR 1440 LI-2 - 670 kn - 1 baterija - 2g garancije - 1,2 kg - 14,4 V - 1,5 Ah - 0-1350 rpm (u 2 brzine) - max 34Nm - ne piše kolko dugo se puni, ali s obzirom da ne piše, sigurno nije 1 h.... - led lampa Einhell TE-CD 12 Li - 699 kn - 2 baterije - 2g garancije - 1 kg - 12 V - 1,3 Ah - 0-1300 rpm (u 2 brzine) - max 25Nm - 1 h punjač - led lampa Link to comment Share on other sites More sharing options...
dodo99 Posted March 22, 2016 Share Posted March 22, 2016 Jesi siguran da je kod Bosch-a samo jedna baterija? Google mi svugdje izbacuje da su dvije u pakiranju Link to comment Share on other sites More sharing options...
Enkei Posted March 22, 2016 Share Posted March 22, 2016 Jesi siguran da je kod Bosch-a samo jedna baterija? Google mi svugdje izbacuje da su dvije u pakiranju Bosch dosta individualno radi pojedine akcije, nekada je 1, nekada 2, pa čak i 3 baterije u određenim situacijama Link to comment Share on other sites More sharing options...
golfijaner Posted March 22, 2016 Share Posted March 22, 2016 Ovu prijatelj prodaje: http://www.njuskalo.hr/rucni-alati/makita-df330dwe-akumulatorska-busilica-odvijac-oglas-18565492 Nekorištena, kupljena 20.03.2016.. Račun i garancija. Link to comment Share on other sites More sharing options...
Risbo Posted March 22, 2016 Share Posted March 22, 2016 super cijena, ali nažalost dosta van buđeta.... i za ovih 700 kn ću se natezati sa dragom Link to comment Share on other sites More sharing options...
golfijaner Posted March 22, 2016 Share Posted March 22, 2016 Ha pa ja doma uvijek kazem nizu cijenu Link to comment Share on other sites More sharing options...
pelepelezg Posted March 22, 2016 Share Posted March 22, 2016 Ovu prijatelj prodaje: http://www.njuskalo.hr/rucni-alati/makita-df330dwe-akumulatorska-busilica-odvijac-oglas-18565492Nekorištena, kupljena 20.03.2016.. Račun i garancija. preporuka za tu akicu (lagana a dosta jaka, naravno ovisi za kaj ju trebas), kod mene vec godinama radi bez problema... Link to comment Share on other sites More sharing options...
Risbo Posted March 22, 2016 Share Posted March 22, 2016 Evo uzeo einhelicu u Pevecu.... 2 akumulatora, dovoljno jaka (ionako je uglavnom koristim za šarafljenje ili bušenje drva) Na kraju je bila 620 kn a ne 700 (dobro da sam krivo zapamtio) i bila je zadnja u Pevecu Zapruđe.... A inače to mi je žena sa svojima kupila za rođkas pa zna koliko košta jer je ona plaćala.... ionako sam nategnuo već početnu cifru Nisam je još probao kak spada, ali čini mi se baš ok.... lagana je, dobro leži u ruci, ima blokadu pogona pa ne treba sa dvije ruke odšarafljivati glavu. kofer je nešto manji nego na starom zelenom Boschu šta sam imao... Bit će posla uskoro pa ću je istestisirati kako spada.. Link to comment Share on other sites More sharing options...
n0p Posted March 23, 2016 Share Posted March 23, 2016 Ima tko preporuku za kvalitetni set alata za preciznu mehaniku (laptop, mobitel itd). Da su magnetizirani itd. Ovako nešto: http://www.imagebam.com/image/66e348473302417 Davno sam kupio neki mali set u konzumu ali su loši...brzo provrte itd. pa bi sad uzeo nešto pouzdanije. Link to comment Share on other sites More sharing options...
Rockatansky Posted March 23, 2016 Share Posted March 23, 2016 Ima tko preporuku za kvalitetni set alata za preciznu mehaniku (laptop, mobitel itd). Da su magnetizirani itd. Ovako nešto: http://www.imagebam.com/image/66e348473302417 Davno sam kupio neki mali set u konzumu ali su loši...brzo provrte itd. pa bi sad uzeo nešto pouzdanije. Ja imam baš takav Luxov da slike, uzeo prije kakvih 10 godina i još je vrhunski. Link to comment Share on other sites More sharing options...
Kevin Posted March 23, 2016 Share Posted March 23, 2016 ko jos drzi one toptul setove u zelenoj kutiji kod nas? Link to comment Share on other sites More sharing options...
n0p Posted March 23, 2016 Share Posted March 23, 2016 Ja imam baš takav Luxov da slike, uzeo prije kakvih 10 godina i još je vrhunski. Gdje, cijena (ako se sjećaš)? Taj mi baš izgleda kvalitetno. Link to comment Share on other sites More sharing options...
Rockatansky Posted March 23, 2016 Share Posted March 23, 2016 (edited) Mislim da je bivši Pevec bio u pitanju, a cijena je bila cca 200-250 kn, ali mislim da nije relevantno. Našao sam ti u Conrada nešto slično za 260 kn Edited March 23, 2016 by Rockatansky Link to comment Share on other sites More sharing options...
n0p Posted March 23, 2016 Share Posted March 23, 2016 Da, vidio sam i ja tamo - http://www.conrad.hr/Komplet-alata-za-preciznu-mehaniku%2Felektroniku,-30-dijelova.-814892-Basetech.htm?websale8=conrad-hr&pi=814892 budem još malo pronjuškao Link to comment Share on other sites More sharing options...
Vucko Posted March 23, 2016 Share Posted March 23, 2016 ko jos drzi one toptul setove u zelenoj kutiji kod nas? Kak misliš ko još? Intercars među ostalim dakle pero. može nabavit Link to comment Share on other sites More sharing options...
Kevin Posted March 23, 2016 Share Posted March 23, 2016 mislim znam da je pelepele drzao... trebao bi onaj 130pcs u kutiji.. bum navratio do inercarsa. tenx Link to comment Share on other sites More sharing options...
golfijaner Posted March 24, 2016 Share Posted March 24, 2016 Ima tko preporuku za kvalitetni set alata za preciznu mehaniku (laptop, mobitel itd). Da su magnetizirani itd. Ovako nešto: http://www.imagebam.com/image/66e348473302417 Davno sam kupio neki mali set u konzumu ali su loši...brzo provrte itd. pa bi sad uzeo nešto pouzdanije. Pogledaj Wiha u Alati Milic. Uzimam Wihu elektricarski alat i nemam primjedbe. Link to comment Share on other sites More sharing options...
Medic Posted March 24, 2016 Share Posted March 24, 2016 Ima tko preporuku za kvalitetni set alata za preciznu mehaniku (laptop, mobitel itd). Da su magnetizirani itd. Ovako nešto: http://www.imagebam.com/image/66e348473302417 Davno sam kupio neki mali set u konzumu ali su loši...brzo provrte itd. pa bi sad uzeo nešto pouzdanije. Probaj ovdje. Mi koristimo takve svakodnevno u optici. Neznam kolko koštaju , ali znam da nisu jeftini. Imaš pojedinačno, imaš komplete....svašta nešto http://shop.b-s.com.hr/hr/screwdrivers-nutdrivers Link to comment Share on other sites More sharing options...
Vucko Posted March 24, 2016 Share Posted March 24, 2016 Od 29 og čini mi se u lidlu parkside mala aku bušilica za 333kn s 3 godine garancije,litijion baterjom i sat vremena punjenja. Kevin nije poanta u tome jel imaju vec koliko rabata sam možeš izvuć Link to comment Share on other sites More sharing options...
Risbo Posted March 24, 2016 Share Posted March 24, 2016 Da, baš sam ja htio napisati da LIdl ima akciju.. samo nije 29. nego 31. (četvrtak) Ima i fleksa sa regulacijom brzine (125mm) za 250 kn.. Još nije na webu, ali sam danas ulovio svježi katalog.... Link to comment Share on other sites More sharing options...
