mrlakis Posted October 15, 2016 Posted October 15, 2016 (edited) The 400 differed from other small blocks in that the cylinders were siamesed and therefore required 'steam' holes in the block, head gaskets, and heads to help alleviate 'hot-spots' in the cooling system at the point above the siamesed cylinders moze li mi netko pojasniti ovaj pojam odnosno da li se na ovaj tip izrade bloka mogu staviti kosuljice? Edited October 15, 2016 by mrlakis
kutija Posted October 15, 2016 Posted October 15, 2016 zaboravi to na lijevanom bloku i jos turbo......nema smisla...ako su cilindri potroseni jednostavo se uzmu veci klipovi i izbusi se blok na koliko treba..........barem za 1.8t imas izbor klipova koliko hoces
mrlakis Posted October 15, 2016 Author Posted October 15, 2016 kutija said: zaboravi to na lijevanom bloku i jos turbo......nema smisla...ako su cilindri potroseni jednostavo se uzmu veci klipovi i izbusi se blok na koliko treba..........barem za 1.8t imas izbor klipova koliko hoces gorane radi se o chevy small block,ameri ga se plase busiti preko 0.030" ,moj je probusen za .020",jedan cilindar mi je dobija krater lip,a ostatak je prakticki netaknut http://www.chevelles.com/forums/18-engine/205022-mamimum-safe-over-bore-400-chevy.html ovdje se vidi stanje cilindara a ovdje pojedeni cilindar,osjeti se ne pod noktom nego i pod prstom. ima pola milimetra sigurno dubine pa se raspitivam jel moguce na ovaj osteceni cilindar nabiti kosuljicu,neznam koliko treba probusiti cilindar da bi sila kosuljica
kutija Posted October 15, 2016 Posted October 15, 2016 zaboravi...uzmi klipove na specijalu i izbusi blok.....mozda ti netko ima polovne klipove na specijalu i uzmes samo nove prstenove
mrlakis Posted October 15, 2016 Author Posted October 15, 2016 (edited) ja bih volio probusiti jos za .010"=.254mm i uzeo flat top klipove,ali bojim se da se nece skinuti ovaj krater sa tim znam da ce tokar kazati svoje ,ali volim biti pripremljen a i nisam siguran da su se susreli sa ovakvim tipom bloka " siamesed" ma sto to znacilo,pretpostavljam da su blizu cilindri jedan drugome kad malo razmislis izmedu njih je rupa,ako postoje odusci za paru, i tu di su te rupice vole pucati,kod mene su te rupe blokirane ,sad neznam jel od ruzine ili namjerno.nasao sam kao da ti odusci nisu bitni ako se blok hladi morem,uglavnom duga prica Edited October 15, 2016 by mrlakis
mrlakis Posted October 15, 2016 Author Posted October 15, 2016 http://www.chevytalk.org/fusionbb/showtopic.php?tid/248699/ evo ovdje ima slika kako izgleda blok
mrlakis Posted October 15, 2016 Author Posted October 15, 2016 Re: Mamimum safe over bore on a 400 Chevy I don't know the Co's But as to the 400. It all depends on the block. I have seen some bored .060 over others that were maxed at .030. The block really needs to be sonic tested to check wall thickness before trying anything over .030. ja bih se drzao ovoga,treba izmjeriti dubinu ostecenja ,pa ce se znati vise
kutija Posted October 15, 2016 Posted October 15, 2016 o kako si ga uspio toliko zakomplicirat......imas ljevani blok....ako je ostecenje vise od prve i druge specijale slobodno ga izbusi za 1mm vise od standarda....ako je jos vise ostecen nadi drugi blok...barem tih 1.8t ima...
mrlakis Posted October 15, 2016 Author Posted October 15, 2016 kutija said: o kako si ga uspio toliko zakomplicirat......imas ljevani blok....ako je ostecenje vise od prve i druge specijale slobodno ga izbusi za 1mm vise od standarda....ako je jos vise ostecen nadi drugi blok...barem tih 1.8t ima... :no2: no,no kutija,citaj gore o cemu se radi
kutija Posted October 15, 2016 Posted October 15, 2016 jel ti pricas o svom motoru 1.8t ili nesto drugo?
tonci Posted October 15, 2016 Posted October 15, 2016 kutija said: zaboravi to na lijevanom bloku i jos turbo......nema smisla...ako su cilindri potroseni jednostavo se uzmu veci klipovi i izbusi se blok na koliko treba..........barem za 1.8t imas izbor klipova koliko hoces Zasto? Ako su klipovi OK, ugradnja kosuljica je oko 1500 kn i novi prstenovi oko 500. Novi klipovi za 1.8t se tesko mogu naci ispod 4000 kn...
mrlakis Posted October 15, 2016 Author Posted October 15, 2016 kutija said: jel ti pricas o svom motoru 1.8t ili nesto drugo? da, pricam o svom motoru,al ne iz auta,1.8t jos dobro potegne.pokusavam sloziti chevy v8 za brod,onako nesto kao maturalni rad,selene,lamele i sl sam polozija,sad je vrime za prvi motor,moj je pa nema veze ako se razleti
bvlahov Posted October 16, 2016 Posted October 16, 2016 Ja to ne bi slagao. Nabavi 350 iz nekakvog terenca starog, za par sto eura, da ju u standardu, ili prvoj specijali i imas lufta koliko hoćeš. Ovi motori su problematicni i u standardu, a kamoli ako se nesto žešće slaže...
mrlakis Posted October 16, 2016 Author Posted October 16, 2016 bvlahov said: Ja to ne bi slagao. Nabavi 350 iz nekakvog terenca starog, za par sto eura, da ju u standardu, ili prvoj specijali i imas lufta koliko hoćeš. Ovi motori su problematicni i u standardu, a kamoli ako se nesto žešće slaže... o toj opciji ozbiljno razmisljam,jos cu pricekati sto ce tokar reci,ali nekako mi je u tome i draz sto je poseban,a i netko se vec prije potrudio da ucini nesto od njega sto mogu iskoristiti od ovoga?radilicu pobrusiti i urediti 383 bregasta bi trebala odgovarati budem jos malo istrazio,ako bi uspija pronaci roller blok za sicu..
BMW_Motorsport Posted October 16, 2016 Posted October 16, 2016 nazovi čukmana u lučko pa pitaj, meni je on nedavno to slagao. s tim da on ima nekog drugog suradnika za blokove. stjenka pikse koju je upresao je debela cca 2mm. nisam mjerio jer nije bilo upitno, mjesta je bilo dovoljno. s tim da kad su jedan upresali ovaj do njega se izbacio, pa su morali i njega i na kraju su sve
mrlakis Posted October 16, 2016 Author Posted October 16, 2016 (edited) BMW_Motorsport said: nazovi čukmana u lučko pa pitaj, meni je on nedavno to slagao. s tim da on ima nekog drugog suradnika za blokove. stjenka pikse koju je upresao je debela cca 2mm. nisam mjerio jer nije bilo upitno, mjesta je bilo dovoljno. s tim da kad su jedan upresali ovaj do njega se izbacio, pa su morali i njega i na kraju su sve znaci 2mm nosi piksna,ok,hvala uvik se dobro raspitati Edited October 16, 2016 by mrlakis
