msporis Posted November 23, 2016 Posted November 23, 2016 Zasto je onda na f30 contijev? VDO - A Trademark of the Continental Corporation TPMSovi su VDO proizvod, Continental je vlasnik VDOa i sad stavlja svoj brand na njih.
Ico Posted November 23, 2016 Posted November 23, 2016 To ti ja rijesim bez problema,kad smo vec gume rijesili rijesit cemo i ventile.
FilipS3 Posted November 23, 2016 Posted November 23, 2016 Felgenonline.de i tamo narucis sve sta ti treba i dode ti na adresu.
Uros Posted November 23, 2016 Posted November 23, 2016 Kak to lijepo na 2012 radi prek senzora abs-a,stavis koje god felge i sve normalno...ne znam kaj izmisljaju toplu vodu
msporis Posted November 23, 2016 Posted November 23, 2016 Kak to lijepo na 2012 radi prek senzora abs-a,stavis koje god felge i sve normalno...ne znam kaj izmisljaju toplu vodu As of 1st November 2012, all new-type vehicles will be required by EU law to have a pressure based tyre pressure monitoring system installed. This applies to the road wheels, not the spare. By November 2014, all new passenger vehicles will have to have TPMS installed by the manufacturer The law is not currently retrospective, and does not apply to older vehicles This law applies to passenger vehicles only, with no more than 7 seats Dakle, od 1.11.2012 svi novi modeli koji su izašli morali su imati TPMS, a od 1.11.2014 sva nova vozila (nebitno kada je model izašao) moraju imati TPMS.
ND4SPD Posted November 24, 2016 Posted November 24, 2016 To bi trebalo biti ovo: Sent from my LG-D855 using Tapatalk Koliko citam nije problem u tpms-u nego u felgama, ocito ide nekakav drugaciji tpms na te aftermarket felge... Dakle, od 1.11.2012 svi novi modeli koji su izašli morali su imati TPMS, a od 1.11.2014 sva nova vozila (nebitno kada je model izašao) moraju imati TPMS. Nisi shvatio, mogli su napraviti tako da svi auti imaju tpms preko abs-a...
Sasaa Posted November 24, 2016 Author Posted November 24, 2016 Koliko citam nije problem u tpms-u nego u felgama, ocito ide nekakav drugaciji tpms na te aftermarket felge... Nisi shvatio, mogli su napraviti tako da svi auti imaju tpms preko abs-a... Upravo tako, problem je sta felga ima rupu za ventil od 8mm, a tpms serijski ima ventil od 12-13mm. Rjesit ce se vec nekako... Sent from my iPhone using Tapatalk
FilipS3 Posted November 24, 2016 Posted November 24, 2016 Kak to lijepo na 2012 radi prek senzora abs-a,stavis koje god felge i sve normalno...ne znam kaj izmisljaju toplu vodu Ali nemas temperaturu a to je dosta zanimljiv podatak. - - - Updated - - - Ali nemas temperaturu a to je dosta zanimljiv podatak. Meni je normalno tpms pasao na bbs felge. Samo sam preselio sa OEM felgi.
Sasaa Posted November 25, 2016 Author Posted November 25, 2016 Ali nemas temperaturu a to je dosta zanimljiv podatak. - - - Updated - - - Meni je normalno tpms pasao na bbs felge. Samo sam preselio sa OEM felgi. Kako citam na Renlistu, kazu da ne ide, ovaj shop preko kojeg sam felge narucio isto kaze da ne ide... cemo vidjet sta ce bit... treba sad bit strpljiv 10 tjedana da felge stignu. Sent from my iPhone using Tapatalk
Lovrek Posted November 25, 2016 Posted November 25, 2016 Kako citam na Renlistu, kazu da ne ide, ovaj shop preko kojeg sam felge narucio isto kaze da ne ide... cemo vidjet sta ce bit... treba sad bit strpljiv 10 tjedana da felge stignu. Sent from my iPhone using Tapatalk Kaj si uzeo ak nije tajna? Sent from my LG-D855 using Tapatalk
msporis Posted November 25, 2016 Posted November 25, 2016 Nisi shvatio, mogli su napraviti tako da svi auti imaju tpms preko abs-a... Jel ima koji auto iz 2015 a da ima preko ABSa? Jer moje je shvaćanje da je od 2014 obvezno da su TPMS senzori... jer kaže da su obvezni TPMS, a ne samo TPM
Sasaa Posted November 25, 2016 Author Posted November 25, 2016 Kaj si uzeo ak nije tajna? Sent from my LG-D855 using Tapatalk Nesto za bubu... sa centerlockom nema bas previse izbora u toj dimenziji. Klasican auto, klasicna felga... BBS. Sent from my iPhone using Tapatalk
Lovrek Posted November 25, 2016 Posted November 25, 2016 Nesto za bubu... sa centerlockom nema bas previse izbora u toj dimenziji. Klasican auto, klasicna felga... BBS. Sent from my iPhone using Tapatalk Mislio sam da pitas za bekija... Ja sebi nasao i boju i sve i onda mi jave da se vise ne proizvodi u toj boji (srebrna, wtf).... Sent from my LG-D855 using Tapatalk
fiatuno Posted November 25, 2016 Posted November 25, 2016 ma i taj utor na felgi se rijesi za senzor bez problema
Sasaa Posted November 25, 2016 Author Posted November 25, 2016 Mislio sam da pitas za bekija... Ja sebi nasao i boju i sve i onda mi jave da se vise ne proizvodi u toj boji (srebrna, wtf).... Sent from my LG-D855 using Tapatalk Za tamo nije problem, znam sta cu i s cime nema drame.... kad potrosim ljetne gume i tamo vjerovatno idu druge felge... Sent from my iPhone using Tapatalk
ND4SPD Posted November 25, 2016 Posted November 25, 2016 Jel ima koji auto iz 2015 a da ima preko ABSa? Jer moje je shvaćanje da je od 2014 obvezno da su TPMS senzori... jer kaže da su obvezni TPMS, a ne samo TPM Pa TPMS je skracenica, kakav TPM? Postoje dvije verzije, indirektni, taj mjeri preko ABS-a i direktni, taj mjeri preko senzora na svakom kotacu... Obje verzije se najnormalnije upotrebljavaju, cak isti proizvodjaci u razlicitim modelima imaju razlicite sustave...
darko_st Posted November 25, 2016 Posted November 25, 2016 Baš gledam na njuškalu tpms senzore ze mercedes, ako ja to dobro vidim original dođe 200kn kom. http://www.njuskalo.hr/autoelektrika-elektronika/tpms-senzor-sustav-nadzor-tlaka-gumama-oem-mercedes-benz-oglas-18528336
Srele_St Posted November 26, 2016 Posted November 26, 2016 Pitanje koliko je star jer uzmi u obzir da je njegov vijek trajanja nekih 6-7 god. Poslano sa mog LG-H850 koristeći Tapatalk
Tuco Posted November 26, 2016 Posted November 26, 2016 Baš gledam na njuškalu tpms senzore ze mercedes, ako ja to dobro vidim original dođe 200kn kom. http://www.njuskalo.hr/autoelektrika-elektronika/tpms-senzor-sustav-nadzor-tlaka-gumama-oem-mercedes-benz-oglas-18528336 ne znam baš..neki dan smo kompic i ja gedali u casopisu Mercedes i bili su po 500-600kn komad ali nisam zapamtio koji modeli
