Mexx Posted June 21, 2009 Share Posted June 21, 2009 preporuke,cijene,... naime na mk funfa bi stavlja ,al volio bi da mi ostane udoban kao sta je sada na serijala amortizerima + h&r opruge -50 mm... i bitna mi je stavka koliko spustaju auto??nebi htio odvidat do kraja a auto visok. znaci-udobnost,kvalitet,cijena...omejer tog troje.-. Link to comment Share on other sites More sharing options...
andy Posted June 21, 2009 Share Posted June 21, 2009 Lowtec,neces fulati Najbolji omjer ulozeno - dobiveno,neces imat problema jer Scorpion ce ti max izaci u susret Link to comment Share on other sites More sharing options...
Eleven Posted June 21, 2009 Share Posted June 21, 2009 scorpion dila s lowtecom? Link to comment Share on other sites More sharing options...
Joki Posted June 21, 2009 Share Posted June 21, 2009 što sam čuo od poznanika...najbolja komba ali i najskuplja - varijanta tri, ostalo je više ili manje dobro, ovo najbolje Link to comment Share on other sites More sharing options...
Dado007 Posted June 21, 2009 Share Posted June 21, 2009 scorpion dila s lowtecom? Ne dila nego ih preko svoje forme prodaje, sve legalno, racun, moze i R1. Ja narucio i trebaju mi ovaj tjedan stici pa javim dojmove, ali na VWCC sam cuo dosta pohvala za LOWTEC Link to comment Share on other sites More sharing options...
Mexx Posted June 21, 2009 Author Share Posted June 21, 2009 nisam se stiga provozat u mk5 sa lowtec....bitna mi je udobnost dosta neznam skeptican sam glede lowteca Link to comment Share on other sites More sharing options...
dcrnic Posted June 21, 2009 Share Posted June 21, 2009 Koni... Link to comment Share on other sites More sharing options...
charger Posted June 21, 2009 Share Posted June 21, 2009 koni, osim ako imaš para onda KW Link to comment Share on other sites More sharing options...
Mexx Posted June 21, 2009 Author Share Posted June 21, 2009 na konija se svi vlasnici mk5 žale...da je tvrd i da auto neide dovoljno nisko....kw isto,svi se zale da ga nemogu zakucat kako zele...jebate nakraju isapda da je lowtec-za kojeg danas drugi put u zivotu cujem,najbolji Link to comment Share on other sites More sharing options...
Rudy Posted June 21, 2009 Share Posted June 21, 2009 što sam čuo od poznanika...najbolja komba ali i najskuplja - varijanta tri, ostalo je više ili manje dobro, ovo najbolje Misliš na KW var3,definitvno su te gewinde udobnije nego serijski ovjes,a auto neusporedivo bolje drži,cijena je cca 8500kn. Link to comment Share on other sites More sharing options...
13snc Posted June 21, 2009 Share Posted June 21, 2009 (edited) ma di je to v3 8500kn!? toliko je 2ica.. ja sam isto zapea za gewinde.. ali odkad sam stavia H&R -4 malo sam se oladia... auto drzi blesavo.. a ne virujem da bi isa nize.. ovo mi je taman.. jedino bi mozda tu lovu preusmjeria prema Koni FSD jer mi je bitan komfor. http://www.koni.com/index.php?id=190 http://www.tirerack.com/suspension/tests/koni_fsd_charts.jsp ako netko ima na autu FSD neka napise malo dojmove.. Edited June 21, 2009 by 13snc Link to comment Share on other sites More sharing options...
Rudy Posted June 21, 2009 Share Posted June 21, 2009 ma di je to v3 8500kn!? toliko je 2ica.. Kod Dragiše,mexx ako poznaje maminju,pa će mu sve objasniti,oba su iz ST. Link to comment Share on other sites More sharing options...
semper Posted June 21, 2009 Share Posted June 21, 2009 šta se desilo sa airride-om :blink: Link to comment Share on other sites More sharing options...
Mexx Posted June 21, 2009 Author Share Posted June 21, 2009 (edited) šta se desilo sa airride-om :blink: uvjet za posten pod na air-u je vanserijski amortizer... tako da cu se ovu godinu-dvi vozit na gewindi a kasnije izbit opruge i na stablu gewinde jastuk . see? Edited June 21, 2009 by Mexx Link to comment Share on other sites More sharing options...
Joki Posted June 21, 2009 Share Posted June 21, 2009 Misliš na KW var3,definitvno su te gewinde udobnije nego serijski ovjes,a auto neusporedivo bolje drži,cijena je cca 8500kn. da, KW koliko je onda dvojka ako je trojka tako jeftina? Link to comment Share on other sites More sharing options...
Rudy Posted June 21, 2009 Share Posted June 21, 2009 da, KW koliko je onda dvojka ako je trojka tako jeftina? Eh i ti nađeš ono što nitko neće,tko još uzima dvojke,jedinica je cca 5,5tkn,znači samo podešavanje visine. btw di bi ti to stavljao,na smarta!?! :lol: Link to comment Share on other sites More sharing options...
Joki Posted June 21, 2009 Share Posted June 21, 2009 Eh i ti nađeš ono što nitko neće,tko još uzima dvojke,jedinica je cca 5,5tkn,znači samo podešavanje visine.btw di bi ti to stavljao,na smarta!?! :lol: Čekam elektro smarta krajem 2010 i definitivno stavljam Link to comment Share on other sites More sharing options...
Mattas Posted June 22, 2009 Share Posted June 22, 2009 Ja sam si uzeo Weitec, navodno su dobre...vidjet ćemo, dosta su nahvaljene Link to comment Share on other sites More sharing options...
Dario Posted June 22, 2009 Share Posted June 22, 2009 KW Eibach ili Weitec i to je to...ostalo necu komentirat...,ovo sam probo na par autica ,osobono Eibach na ibizi i predobro je bilo ,a sad imam KW na golfu i to je to ,Weitec ima zizz na golfu i kolko god ga je ubio bio u pod zadovoljavajuce odubno je Link to comment Share on other sites More sharing options...
golfijaner Posted June 22, 2009 Share Posted June 22, 2009 ja sam vrlo zadovoljan weitec gewindama hicon gt (samo podesavanje visine). kad ih odvidam do kraja guma je u ravnini s blatobranom. neki tvrde da s nekim no name gewindama spustaju jos vise auto ali to je prica za sebe. naravno, nije rijec o mk5. da li si razmisljao o d2 gewindama? Link to comment Share on other sites More sharing options...
kutija Posted June 22, 2009 Share Posted June 22, 2009 bilstein.... Link to comment Share on other sites More sharing options...
2fast Posted June 22, 2009 Share Posted June 22, 2009 (edited) Ako hoćeš da taj ovjes i "radi" kak spada a ne samo da ubiješ auto u pod, onda uzmi nešto tipa KW, Bilstein, H&R... Imao sam na Astri do pred godinu dana KW V1, auto je držao odlično, i bio je puno udobniji nego auto spušten na oprugama, naravno da nema baš onu udobnost serijala ovjesa. Prošle godine sam stavio Bilstein B14, što se tiče udobnosti, čine mi se malo bolje, kao da bolje upijaju kratke neravnine... Bitna razlika, a to je tebi vjerovatno i najvažnije, je ta da se KW dao spustit nekih 2cm niže od Bilsteina, imale su više navoja (govorim o prednjim gewindama), otraga se obije daju spustit podjednako. btw: mislim da ima na forumu već jedan thread di je bila rasprava o kvaliteti gewidni, itd.. potraži malo... Edited June 22, 2009 by 2fast Link to comment Share on other sites More sharing options...
SVEN Posted June 22, 2009 Share Posted June 22, 2009 kw v3 na mk5 je po meni najbolji izbor definitivno. hrvoje ima d2 i iskreno nisu bas nesto plus to da uporne klapaju jer d2 ne koristi serijske nego daje te svoje koje su zakurac hr voze ovi ameri to mozes citat na vortexu al je jako tvrdo a i njihove ceste su za nase pojmove znanstvena fantastika tako da to zaborav. po meni samo kw ili ako je to previse novaca uzmi one weitec za 7400 ili 7600 neznamkoliko su. sa podesavanjem tvrdoce. to je to. drugo nebi ni gledao. auto ti definitivno nije udoban na serijskima s oprugama nego nisi probao primjerice kw ubijen u pod i vise nego tvoj auto a jos vise udobniji. xxxx Link to comment Share on other sites More sharing options...
mariotdi Posted June 22, 2009 Share Posted June 22, 2009 na vwvortexu vise ima fk highsport bar kolko sam ja vidio Link to comment Share on other sites More sharing options...
dcrnic Posted June 22, 2009 Share Posted June 22, 2009 Hic ima najpovoljniji KW... Ako se odlučiš za FDS javi pa ćemo sližiti neku cijenu... Link to comment Share on other sites More sharing options...
