fire Posted November 17, 2009 Share Posted November 17, 2009 Di kupiti nesto kao ovo? http://www.ekwaterblocks.com/shop/media/catalog/product/cache/1/image/5e06319eda06f020e43594a9c230972d/e/k/ek-12mm_1.jpg Znaci jedan dio se serafi, a na drugi dio cijev s selnom? Link to comment Share on other sites More sharing options...
Misek_Chipsy Posted November 17, 2009 Share Posted November 17, 2009 (edited) u bilokojoj zeljezariji/sve za kucu i vrt immo takve stvari imas da se serafe npr na pipe za vrtna crijeva i slicno. ili pogledaj u termokomercu Al ti je bakreni. http://www.termocommerce.hr edit: ak nema ako onda imas istu stvar al sa upustenim navojem...onda u njega samo jos userafis ovaj navoj. Edited November 17, 2009 by Misek_Chipsy Link to comment Share on other sites More sharing options...
fire Posted November 17, 2009 Author Share Posted November 17, 2009 u bilokojoj zeljezariji/sve za kucu i vrt immo takve stvari imas da se serafe npr na pipe za vrtna crijeva i slicno. edit ak nema ako onda imas istu stvar al sa upustenim navojem...onda u njega samo jos userafis ovaj navoj. Ok, ima tko preporuku neku zeljezaru u centru zg-a ili istocni dio? Link to comment Share on other sites More sharing options...
KIMI_1.8T Posted November 17, 2009 Share Posted November 17, 2009 Hansaflex - semafor prije Slovenijalesa (skretanja za Sesvete) kad ides iz grada autoputom prema Slovenijalesu na tom semaforu desno i nakon 30m na desnu stranu. Link to comment Share on other sites More sharing options...
IgoRR Posted November 17, 2009 Share Posted November 17, 2009 koliko ti komada treba? se smije znati za kaj? Link to comment Share on other sites More sharing options...
matija0311 Posted November 17, 2009 Share Posted November 17, 2009 killer ulja možda ili tak nekaj Link to comment Share on other sites More sharing options...
fire Posted November 17, 2009 Author Share Posted November 17, 2009 Ma dovod goriva za motor, trebam 2komada. Navoj 1/4 cola(inch), a tamo di ide crijevo, za 8mm crijevo. Link to comment Share on other sites More sharing options...
Jopa Posted November 17, 2009 Share Posted November 17, 2009 isto tako preporucam hansaflex, jesu skupi ali je i roba kvalitetna! i imaju stvarno svega! Link to comment Share on other sites More sharing options...
IgoRR Posted November 17, 2009 Share Posted November 17, 2009 mogu ti pogledati ako imam 2 komada doma, ali tek kad se vratim u subotu iz Varaždina u Zg. btw jedno pitanje. Možeš li porihtati Tartarini plin?? Link to comment Share on other sites More sharing options...
fire Posted November 18, 2009 Author Share Posted November 18, 2009 Idem danas to kupiti. Link to comment Share on other sites More sharing options...
Gear Posted November 18, 2009 Share Posted November 18, 2009 ja kupio nedavno u gramatu takav isti. Link to comment Share on other sites More sharing options...
mr_G Posted November 18, 2009 Share Posted November 18, 2009 Mislim da sam to za bengu vidio i u pevecu... Za odvod turbine si riješio? Link to comment Share on other sites More sharing options...
Giz Posted November 18, 2009 Share Posted November 18, 2009 Ma dovod goriva za motor, trebam 2komada. Navoj 1/4 cola(inch), a tamo di ide crijevo, za 8mm crijevo. To ti za XEa treba, konkretno za prithvate na fuel rail. Ja sam to radio več par puta u Vrapču kod dečkiju iz VEP hidraulike. Ostaviš par kuna i naprave ti to za čas. Link to comment Share on other sites More sharing options...
ZOD Posted November 18, 2009 Share Posted November 18, 2009 Mr G: riješeno Giz: pogodio si, mislim da je fire to več kupio u Industrijskoj pneumatici Link to comment Share on other sites More sharing options...
fire Posted November 19, 2009 Author Share Posted November 19, 2009 Mr G: riješenoGiz: pogodio si, mislim da je fire to več kupio u Industrijskoj pneumatici Kupio, ali nisu 1/4 navoji. Cini se da su M navoji Idem danas s fuel railom vidjeti ako imaju takve mozda. Link to comment Share on other sites More sharing options...
mr_G Posted November 19, 2009 Share Posted November 19, 2009 Ne mora biti. Provjeri, izmjeri. Jer moguće da su ti, ti adapteri pocinčani, samim time taj sloj ih podebljava i prvi puta teže uđu unutra (logično, zar ne)... To sam i ja doživio sa vodom na turbini... Link to comment Share on other sites More sharing options...
fire Posted November 20, 2009 Author Share Posted November 20, 2009 Bio u vep hidraulici, napravili nove navoje i sad sve to radi. Uglavnom preporuka za vep hidrauliku. Link to comment Share on other sites More sharing options...
Giz Posted November 20, 2009 Share Posted November 20, 2009 Sam ti rekao Link to comment Share on other sites More sharing options...
