Mitja Posted January 28, 2010 Posted January 28, 2010 Neka mjerenja http://forums.vwvortex.com/zerothread?id=2830512 http://forums.vwvortex.com/zerothread?id=2976756 http://forums.vwvortex.com/zerothread?id=3181945 http://forums.vwvortex.com/zerothread?id=3430845 http://forums.vwvortex.com/zerothread?id=2949008 http://forums.vwvortex.com/zerothread?id=3843767 I jedan vrlo interesantan link http://forums.vwvortex.com/zerothread?id=3068263 Kako je kod flandze turba visa temperatura nego odmah na izlazu iz pojedinacnog cilindra. "So there you have some more scientific information backing up as to what differences can be seen in different locations of the manifold. As a result it seems there is a difference of 80-100c when moving the probe from the ATP WG location to the collector flange."
fire Posted January 28, 2010 Posted January 28, 2010 Znaci to su turbine koje na 2000rpm imaju vec max boost? A druga stvar kako rade novi motronici koji imaju egt senzor? Ima jedan zanimljiv algoritam.
ZOD Posted January 28, 2010 Posted January 28, 2010 Ja mislio nešto novo I da tamo je cast manifold, nije tubular.
Mitja Posted January 28, 2010 Author Posted January 28, 2010 (edited) I neki nama znani Puntac sa GT2560 ima slican response na turbu. Ovi zadnji link i dosta ostalih je sa klasicnom EGT cukom. A Motronic koristi LSU lambdu za EGT. Radi vrlo precizno. Fora je da se svi 4 kanali zdruze v 1 prije turba i tamo su temperature najvece. Standard za mjereje EGT je na exhaust runneru 5cm iza glave motora. ZOD said: Ja mislio nešto novo I da tamo je cast manifold, nije tubular. Edited January 28, 2010 by Mitja
ZOD Posted January 28, 2010 Posted January 28, 2010 Jedini pravi način je za svaki runner posebni egt senzor. Tamo di se sudaraju sva 4 toka ispušnih plinova naravno da je najveća temp, što se i vidi kad se zacrveni manifold kod gaženja. edit: no istu stvar govorimo, meni je to jasno...
Mitja Posted January 28, 2010 Author Posted January 28, 2010 Znam za neki auto koji ima tako montiranu EGT sondu i koja mjeri prilicno visoke EGT.
Akula Posted January 28, 2010 Posted January 28, 2010 imam snimku sa termovizijskom kamerom kako je na runnerima temp za 200tinjak C manja nego na spoju sa turbinskim kućištem...
Mitja Posted January 29, 2010 Author Posted January 29, 2010 To je od ECU-ja sigurno je to na MS :-) tako da snimka samo potvrduje ta ti je ECU glup :-) Sorry na off topic.
tcode Posted January 29, 2010 Posted January 29, 2010 Mitja said: I neki nama znani Puntac sa GT2560 ima slican response na turbu. Ovi zadnji link i dosta ostalih je sa klasicnom EGT cukom. A Motronic koristi LSU lambdu za EGT. Radi vrlo precizno. Fora je da se svi 4 kanali zdruze v 1 prije turba i tamo su temperature najvece. Standard za mjereje EGT je na exhaust runneru 5cm iza glave motora. To ti sebe tješiš, Seba ili nas? Mene samo zanima da li stojiš iza Seb-ovog motora i spreman si pokriti troškove popravka kad bude spaljen zbog ovako visokog EGT-a koji je po tebi normalan? Ozbiljno pitam, nije podje*avanje.
ZOD Posted January 29, 2010 Posted January 29, 2010 Ako se ja nevaram zar nema gt25 kao i gt28 serijski rupu na ulazu u turbinski dio baš namjenjen za egt sondu? Ako se več spominje taj položaj EGT senzora.
mr_G Posted January 29, 2010 Posted January 29, 2010 ZOD said: Ako se ja nevaram zar nema gt25 kao i gt28 serijski rupu na ulazu u turbinski dio baš namjenjen za egt sondu? Ako se več spominje taj položaj EGT senzora. Imaju sve garetove turbinu upravo u gaćama rupu za EGT..
Alfaludak Posted January 29, 2010 Posted January 29, 2010 mr_G said: Imaju sve garetove turbinu upravo u gaćama rupu za EGT.. nemaju :thumbsup:
Seb Posted January 29, 2010 Posted January 29, 2010 ako je na tom spoju tolka temp onda ulazi u turbo kao takva a i za njega je to previše zadnji put kad sam stisno auto onak malo žešće mi je bacio plavkasti dim na abgasu pa sam se usro da nešto rikava a moglo bi bit da se nešto sa turbinom dešavalo...za sad više ne dimi no nisam ga tak više ni stisko
Mitja Posted January 29, 2010 Author Posted January 29, 2010 Sve majstore, koji su i kako krivili i MS kad nije islo u visoke obrtaje i bio je vrlo velik EGT. Gle cuda bio je i zagusem auspuh. Motor radi OK i stojim za time. Sad je EGT veci je je u toj tacki uvijek veci nego direkt na izlazu iz glave motora. Evo jedan slicno velik motor Fiat 2.0 i K04 turbo 270 HP na 1.7 bar. Znaci jos manji na auspuhu. Koji izdrzi puni gas tekom utrke. I nista ne izgori. Nisam mjerio EGT jer ga nikad ne mjerim. Kad je lambda i paljenje OK nema problema. tcode said: To ti sebe tješiš, Seba ili nas? Mene samo zanima da li stojiš iza Seb-ovog motora i spreman si pokriti troškove popravka kad bude spaljen zbog ovako visokog EGT-a koji je po tebi normalan? Ozbiljno pitam, nije podje*avanje.
Mitja Posted January 29, 2010 Author Posted January 29, 2010 Jos jedan put provjeri izlaz ulja iz turba. Vec sam nesto napiso o tome. Sad ide i horizontalno prema karteru. Nije optimalno. Seb said: ako je na tom spoju tolka temp onda ulazi u turbo kao takva a i za njega je to previšezadnji put kad sam stisno auto onak malo žešće mi je bacio plavkasti dim na abgasu pa sam se usro da nešto rikava a moglo bi bit da se nešto sa turbinom dešavalo...za sad više ne dimi no nisam ga tak više ni stisko
