@Dodo@ Posted February 2, 2012 Report Share Posted February 2, 2012 Jel ima tko kakvu ideju kako napraviti EGT senzor da daje signal od 0-5V. EGT čukica mi ne treba, samo mi je signal važan. Jedino što sam našao su čukice, koje imaju i output signal, ali da ne kupujem sve, možda se može složiti nešto od stvari kupljenih kod nas. Link to comment Share on other sites More sharing options...
Petar001 Posted February 2, 2012 Report Share Posted February 2, 2012 Ima za kupit EGT senzor od TT-a koji ima to serijski Link to comment Share on other sites More sharing options...
Marko Posted February 2, 2012 Report Share Posted February 2, 2012 ide ti sonda pa pojacalo, jer sonda daje neki mali signal. Pitaj fajra. Edit: e si ti bio neki dan na okretistu tramvaja borongaj? Ne vjerujem da bas ima puno bijelih RX7 u Zagrebu Link to comment Share on other sites More sharing options...
fire Posted February 2, 2012 Report Share Posted February 2, 2012 Imam ja takvo pojacalo za prodati. Link to comment Share on other sites More sharing options...
Petar001 Posted February 2, 2012 Report Share Posted February 2, 2012 evo cca 200€ Link to comment Share on other sites More sharing options...
tcode Posted February 2, 2012 Report Share Posted February 2, 2012 Za manje od 200 eura rađe onda ovo: http://shop.vems.hu/catalog/roundv2wbo2egt-p-166.html?osCsid=ca0f1429ba74f13fa7688d10418fe8ec Link to comment Share on other sites More sharing options...
Petar001 Posted February 2, 2012 Report Share Posted February 2, 2012 da samo sto je LSU4 WBO2 sensor i EGT sensor još 150€ extra Link to comment Share on other sites More sharing options...
@Dodo@ Posted February 2, 2012 Author Report Share Posted February 2, 2012 Imam ja takvo pojacalo za prodati. Jel znaš tip senzora na koji se spaja? Link to comment Share on other sites More sharing options...
tcode Posted February 2, 2012 Report Share Posted February 2, 2012 (edited) da samo sto je LSU4 WBO2 sensor i EGT sensor još 150€ extra Da, 248 eura sa EGT sondom. Ali onda ima kontorler-pripremu za WB i IAT, sa mogućnošću logiranja, čukicu sa prikazom za ta tri parametra u RT-u. A sa ovim tvojim vau vau ima kaj? Zgodan privjesak. Btw. ionako nije bitno, koliko vidim on puca na neki DIY i nada se proći puno jeftinije od toga. Edited February 2, 2012 by tcode Link to comment Share on other sites More sharing options...
Mitja Posted February 2, 2012 Report Share Posted February 2, 2012 evo sheme za DIY Link to comment Share on other sites More sharing options...
@Dodo@ Posted February 2, 2012 Author Report Share Posted February 2, 2012 Da, 248 eura sa EGT sondom. Ali onda ima kontorler-pripremu za WB i IAT, sa mogućnošću logiranja, čukicu sa prikazom za ta tri parametra u RT-u. A sa ovim tvojim vau vau ima kaj? Zgodan privjesak. Btw. ionako nije bitno, koliko vidim on puca na neki DIY i nada se proći puno jeftinije od toga. Imam u autu instaliranu LM1 WB sondu sa RPM converterom na koji mogu spojiti RPM signal i još 5 drugih 0-5v signala i logirati sve skupa. Na RPM converter je sad spojen i 3 bar map senzor tako da mi još fali i taj EGT signal da mogu skupa imati AFR/PSI/RPM/EGT Link to comment Share on other sites More sharing options...
@Dodo@ Posted February 2, 2012 Author Report Share Posted February 2, 2012 evo sheme za DIY Thanks Mitja, K-type sondu nabavim, a NiCr-Ni kabel imam. Ovaj AD595CQ je ono što mi je falilo, vidim da ih ima na eBayu... Javim se kad složim, thanks ! Link to comment Share on other sites More sharing options...
fire Posted February 2, 2012 Report Share Posted February 2, 2012 Ovo mozes kod mene dobiti za 20E, za k type sonde. Imam, tako da mozes sutra imati http://shop.vems.hu/catalog/amplifier-dsub9-p-129.html?osCsid=ca0f1429ba74f13fa7688d10418fe8ec BTW ono s audia vam nije dobro. Taj modul ne daje van naponski signal nego PWM. I daje ga samo u rasponu od 900 do 1000C gdje mu zapravo i egt sonda sluzi. Link to comment Share on other sites More sharing options...
@Dodo@ Posted February 3, 2012 Author Report Share Posted February 3, 2012 Ovo mozes kod mene dobiti za 20E, za k type sonde. Imam, tako da mozes sutra imati http://shop.vems.hu/catalog/amplifier-dsub9-p-129.html?osCsid=ca0f1429ba74f13fa7688d10418fe8ec BTW ono s audia vam nije dobro. Taj modul ne daje van naponski signal nego PWM. I daje ga samo u rasponu od 900 do 1000C gdje mu zapravo i egt sonda sluzi. Thanks, poslao sam burazu da mi uzme preko ebaya ovaj AD595CQ odmah nakon zadnjeg posta, već je kupio Nema veze, ovako i onako nije vrijeme za voziti se sa autom. Samo da snmijeg popusti pa cu onda to stavljati u auto. Link to comment Share on other sites More sharing options...
@Dodo@ Posted February 8, 2012 Author Report Share Posted February 8, 2012 Danas sam naručio EGT sondu u firmi MARUS-ATM. Rade po vašoj specifikaciji: duljina senzora ispod navoja, M8 ili M10 navoj, duljina senzora iznad navoja, duljina kabela, i tip kabela (Tip-K ili drugi). Gotovo za jedan dan, cijena cca 400-500kn, ovisi o specifikaciji. Sutra slike Link to comment Share on other sites More sharing options...
fire Posted February 8, 2012 Report Share Posted February 8, 2012 Hm, za tu cijenu dobis kod mene 6mm sondu(pogodnu za turbake) umjerenu. Link to comment Share on other sites More sharing options...
ZOD Posted February 8, 2012 Report Share Posted February 8, 2012 ............... Link to comment Share on other sites More sharing options...
@Dodo@ Posted February 9, 2012 Author Report Share Posted February 9, 2012 Hm, za tu cijenu dobis kod mene 6mm sondu(pogodnu za turbake) umjerenu. Jel postoji razlika, za turbake i NA ? Link to comment Share on other sites More sharing options...
Zeljko_M Posted February 9, 2012 Report Share Posted February 9, 2012 Bok, Imas u elektoru project za wideband lambda controller. Mislim da ima i podršku za EGT, provjeri. Link to comment Share on other sites More sharing options...
tcode Posted February 9, 2012 Report Share Posted February 9, 2012 Jel postoji razlika, za turbake i NA ? N/A sonde su 2mm, turbo su 6 mm. Link to comment Share on other sites More sharing options...
fire Posted February 9, 2012 Report Share Posted February 9, 2012 Jel postoji razlika, za turbake i NA ? Da, sonde za turbake moraju biti crvsce(znaci deblje) da ne puknu prilokom velkih temperatura i velike mase plinova sto idu preko njih. 2mm sonda cesto kod turba zna puknuti(kada je pravi boost, ne na 0.5bara) i odletjeti u turbinu i napraviti havariju. Zato se obicno stavlja 6mm za turbo motore. Link to comment Share on other sites More sharing options...
@Dodo@ Posted February 9, 2012 Author Report Share Posted February 9, 2012 Evo, stigla je, 6mm Link to comment Share on other sites More sharing options...
KIMI_1.8T Posted February 9, 2012 Report Share Posted February 9, 2012 A cemu sluzi ova bakrena sajbica?? Link to comment Share on other sites More sharing options...
Mitja Posted February 9, 2012 Report Share Posted February 9, 2012 Mozda ide ispod matice? Link to comment Share on other sites More sharing options...
KIMI_1.8T Posted February 9, 2012 Report Share Posted February 9, 2012 Mozda ide ispod matice? Daj jos jednom razmisli. Kolika je temp. ispusne grane?:naughty: Link to comment Share on other sites More sharing options...
