killercivic Posted May 22, 2015 Share Posted May 22, 2015 Upute na rosstech stranici imas Link to comment Share on other sites More sharing options...
CooleR Posted May 30, 2015 Share Posted May 30, 2015 IMa li netko (cini mi se da je Pekx jednom prilikom spomenuo) kakav pdf ili doc sa "uputama" oko koristenja VCDS-a? BOlje da su upute na hrvatskom - ako postoje? Link to comment Share on other sites More sharing options...
killercivic Posted May 30, 2015 Share Posted May 30, 2015 http://www.ross-tech.net/VCDS/download/manual/VCDS-Printable-Manual-2013.pdf Link to comment Share on other sites More sharing options...
CooleR Posted June 11, 2015 Share Posted June 11, 2015 Moze netko prokomentirat Ne mogu zakljucati vozaceva vrata (putem daljinskog) - ne radi podizanje stakala sa vozaceve strane... Skoda Yeti u pitanju. Hvala P.S. i kolika moze biti cijena rijesenja? Link to comment Share on other sites More sharing options...
grga22 Posted June 11, 2015 Share Posted June 11, 2015 Provjeri osigurače ako nisi. Druga opcija, probaj skinuti klemu na 15 min, takav slučaj sam imao s jednim Golfom, kad sam vratio klemu, sve proradilo... Ak to ne pomogne, raskopaj vrata i vidi jel šta korodiralo u konektoru na motoru prozora, tamo mu je modul vrata... Link to comment Share on other sites More sharing options...
Beli Posted June 11, 2015 Share Posted June 11, 2015 (edited) Provjeri zice u gumenom pregibu na vratima.. i skine se oplata vrata pa na modulu vrata provjeri napajanja.. Prije par dana rijesio jedan takav slucaj Edited June 11, 2015 by Beli Link to comment Share on other sites More sharing options...
Kegalj Posted June 11, 2015 Share Posted June 11, 2015 Ok pitanje. Kolega s posla ima 2010 Passat CC 2.0 TSI i pojavio mu se Check Engine Light. (naravno vw ) Ocitali smo sa mojim ELM 327 gresku P2015. (motoric varijabilnog usisa). E sad posto bi mu tu u VW to naplatili u milijunima on bi to sam zamijenio ali treba nakon instalacije programirat motoric preko dijagnostike. On bi to probao napravit sam ali sad se namece pitanje koji kabel ili sto god kupit i kako to odradit. On je gledao ovaj ali ne vidim cemu toliko placat: http://store.ross-tech.com/shop/VCuCAN.html Da li se to isto moze odradit i sa ovim kablom?: http://www.ebay.com/itm/KKL-VAG-COM-409-1-OBD2-USB-Cable-Auto-Scanner-Diagnostic-Tool-for-Audi-VW-SEAT-/261347142998?hash=item3cd980ed56&item=261347142998&vxp=mtr Unaprijed hvala. Link to comment Share on other sites More sharing options...
Jambo Posted June 11, 2015 Share Posted June 11, 2015 Nemozes tim 409 cablom...taj je za preCAN aute...treba mu nesto novije tipa vcds 12.10 ili slicno.. Link to comment Share on other sites More sharing options...
Kegalj Posted June 11, 2015 Share Posted June 11, 2015 Nemozes tim 409 cablom...taj je za preCAN aute...treba mu nesto novije tipa vcds 12.10 ili slicno.. jel mi mozes nac nesto na ebayu i sibnut link? Meni izbacuje sve iste pa valjda krivo trazim. Link to comment Share on other sites More sharing options...
Beli Posted June 11, 2015 Share Posted June 11, 2015 Nije problem motorica najvjerojatnije.. nego je ostao zaglavljen jer ja plasticna klapna pukla u usisnoj grani Link to comment Share on other sites More sharing options...
Kegalj Posted June 11, 2015 Share Posted June 11, 2015 Nije problem motorica najvjerojatnije.. nego je ostao zaglavljen jer ja plasticna klapna pukla u usisnoj grani znaci prvo pogledat? Justros je nemirno radio par sekundi nakon sto je upaljen i od onda je check engine upaljen. Resetirao sam gresku, ali cim ugasim i upalim auto vrati se.. Link to comment Share on other sites More sharing options...
Beli Posted June 11, 2015 Share Posted June 11, 2015 Mozes rukom probat viditi dali poluga koja zakrece klapne slobodno se pomice.. Link to comment Share on other sites More sharing options...
Kegalj Posted June 11, 2015 Share Posted June 11, 2015 sad sam gledao. Auto mu nema EVAP uopce. jel ima to kakve veze? Link to comment Share on other sites More sharing options...
Beli Posted June 11, 2015 Share Posted June 11, 2015 Slikaj motorni prostor.. Link to comment Share on other sites More sharing options...
Kegalj Posted June 11, 2015 Share Posted June 11, 2015 upravo rijesio problem. Rucka od ventila je iskocila sa ruckice na klapni. Vratio natrag, resetirao gresku i auto se odmah ouno bolje ponasa. Nema cukanja, ide bolje i nema greske. Ali vratio sam klapnicu natrag skroz lagano. Sad me zanima sto prije ode? klapna ili ruckica na motoricu? Tesko mi objasnit ali pitanje je je li plastika na motoricu slabija od plastike na klapni ili obrnuto. Nadams e da je klapna Link to comment Share on other sites More sharing options...
CooleR Posted June 13, 2015 Share Posted June 13, 2015 Hvala ekipa, sutra cu pokusat otklonit ovaj moj problem. Link to comment Share on other sites More sharing options...
Gabre Posted June 13, 2015 Share Posted June 13, 2015 ima li netko negdje dobre upute kako instarlirati kabel i software, doslo mi s ebaya nekidan, ali nisam jos stigao.. pa da ne ujebem nesto prije ne go pocnem haha Link to comment Share on other sites More sharing options...
grga22 Posted June 13, 2015 Share Posted June 13, 2015 Ne bi trebalo biti previše mudrosti. Instaliraš softeware sa CDa i driver, uštekaš kabel, pokreneš VCDS, odeš na Options, napraviš test kabla i save postavki i možeš ga koristiti. Sve ti vjerojatno piše u nekakvom *.txt fileu na tom CDu... Link to comment Share on other sites More sharing options...
CooleR Posted June 14, 2015 Share Posted June 14, 2015 Dobio sam bio link na eng. al bih radije za pocetak neke domace upute... postoji li nesto tako? neke osnovne stvari na HRV? hvala Link to comment Share on other sites More sharing options...
Gabre Posted June 14, 2015 Share Posted June 14, 2015 Ne bi trebalo biti previše mudrosti. Instaliraš softeware sa CDa i driver, uštekaš kabel, pokreneš VCDS, odeš na Options, napraviš test kabla i save postavki i možeš ga koristiti. Sve ti vjerojatno piše u nekakvom *.txt fileu na tom CDu... Ma negdje sam.procitao da wifi treba gasiti, neki update da sjebe kabel, svasta nesto Link to comment Share on other sites More sharing options...
Booster Posted June 14, 2015 Share Posted June 14, 2015 (edited) Jel zna netko gdje se moze nabaviti kabel i VAG-COM (za novije modele konkretno mene zanima za Audi B7) za neke normalne novce (citaj do 50€)? Ja imam ovu stariju verziju koju koristim na Ibizama ali ne citaju Audi (2005) Edited June 14, 2015 by Booster Link to comment Share on other sites More sharing options...
killercivic Posted June 14, 2015 Share Posted June 14, 2015 (edited) Imam ti ja, oces 12.12 ili 11.3. Novi isprobani rade i na a7 novom. 300kn komad. Ili stara verzija 409.1 200kn Edited June 14, 2015 by killercivic Link to comment Share on other sites More sharing options...
Booster Posted June 14, 2015 Share Posted June 14, 2015 Nasao na njuskalu malo prije, ako taj ne bude radio javim se. Link to comment Share on other sites More sharing options...
grga22 Posted June 15, 2015 Share Posted June 15, 2015 Ma negdje sam.procitao da wifi treba gasiti, neki update da sjebe kabel, svasta nesto Ma samo kad ti kaže da postoji nova verzija i da napraviš update kažeš mu da nećeš... Link to comment Share on other sites More sharing options...
killercivic Posted June 15, 2015 Share Posted June 15, 2015 ovaj 12.12 automatski prebacuje datum na 1.1.2013 tak neš Link to comment Share on other sites More sharing options...
