ND4SPD Posted April 8, 2016 Posted April 8, 2016 Ima netko iskustva sa Beren gold? Ili sa Barenom, Toplom ili Vesnom?
Lev Posted April 8, 2016 Posted April 8, 2016 Realno, isti drek, kolko srece imas, tolko ce ti trajati samo da je struja i kapacitet odgovarajuć. Ja bi od tih uzeo najjeftiniji.
nix Posted April 8, 2016 Posted April 8, 2016 Ja imam toplu onu crvenu evo već 4g da dizelu i nema frke...
ND4SPD Posted April 9, 2016 Author Posted April 9, 2016 Realno, isti drek, kolko srece imas, tolko ce ti trajati samo da je struja i kapacitet odgovarajuć. Ja bi od tih uzeo najjeftiniji. Tako nekako si i sam mislim, ali rekoh zasto ne pitati
Raptor6767 Posted April 9, 2016 Posted April 9, 2016 Za koji auto? Sent from my SM-G920F using Tapatalk
ND4SPD Posted April 9, 2016 Author Posted April 9, 2016 Za koji auto? Sent from my SM-G920F using Tapatalk Pitao sam i tebe vec, zaboravio si EVO 9 I da, rado bi Optimu, ali necu dati tolike novce za akumulator
Raptor6767 Posted April 9, 2016 Posted April 9, 2016 Pitao sam i tebe vec, zaboravio si EVO 9 I da, rado bi Optimu, ali necu dati tolike novce za akumulator Mislio sam da trebaš za neki "kramp" kad ni ne razmatraš Vartu, Banner, Exide. Sent from my SM-G920F using Tapatalk
ND4SPD Posted April 9, 2016 Author Posted April 9, 2016 Mislio sam da trebaš za neki "kramp" kad ni ne razmatraš Vartu, Banner, Exide. Sent from my SM-G920F using Tapatalk Razmatram i Banner i Exide, ti su poznati, ove koje sam nabrojao bas i nisu Vartu nekako ne bih, dosta ekipe se u zadnje vrijeme zali na nju... Cak i Panasonic dolazi u obzir, ali ne znam tko ih ima kod nas...
FilipS3 Posted April 9, 2016 Posted April 9, 2016 Akumulator ko akumulator.... ja koji uvijek kupim koji god (ne bas kineske ove najeftinije) i sve to dode na isto...
pacey Posted April 9, 2016 Posted April 9, 2016 Samo autopower i onaj neki energy izbjegavaj..svaki drugi valja
Dottore Posted April 10, 2016 Posted April 10, 2016 Imao sam tvornički Banner akumulator i izdržao je 5 godina. U Hercegovini mi krepao pa uzeo Vartu (nije bilo druge).
SVEN Posted April 10, 2016 Posted April 10, 2016 veliku vecinu radi ista firma samo druga naljepnica tako da ono..
SEGI Posted April 10, 2016 Posted April 10, 2016 Ima tko da trguje akumulatorima? Planiram kupiti ovaj http://www.solarno.hr/katalog/proizvod/AGM250/agm-akumulator-180ah-megalight idući tjedan, treba mi kao servisni akumulator za barku, ako ga tko ima za nižu cijenu uzimam odmah, bilo koji način plaćanja mi odgovara. Sent from my iPhone using Tapatalk
Kevin Posted April 10, 2016 Posted April 10, 2016 Odi na Optimu, neces pozalit. Jebga, dodje nekih 1600kn
Kevin Posted April 10, 2016 Posted April 10, 2016 Btw, super s optimom sto kad auto duugo stoji negubi snagu/napon pa ga odmah okrene na prvi zub Meni je u gepeku, spojena s 6m zavarivackog kabla od 50mm2
Kas Posted April 10, 2016 Posted April 10, 2016 Imao Toplu i Exide, oba izdržala 5 godina, prodao aute sa njima bez znakova zamora.
robi Posted April 10, 2016 Posted April 10, 2016 Meni je originalni na civicu trajao 10 god. Mislim da je panasonic bio u igri.
Raptor6767 Posted April 10, 2016 Posted April 10, 2016 Ljudi zaboravljaju da ni struja u autu nakon 10god nije ista. Anlaser, alternator, spojevi...sve to utječe na dugotrajnost idućeg akumulatora kad ga se uspoređuje sa "onim prvim u autu". Sent from my SM-G920F using Tapatalk
robi Posted April 10, 2016 Posted April 10, 2016 Kada smo vec kod akumulatora, tko ih otkupljuje i koliko se dobije po komadu cca. Imam ih valjda 6,7 po garazi...
dar-mar Posted April 10, 2016 Posted April 10, 2016 Meni je originalni na civicu trajao 10 god. Mislim da je panasonic bio u igri. Meni isto Panasonic originalni na Accordu 2.4 2006 izdržo ravno 2.5 godine:lol:
jobuljan Posted April 11, 2016 Posted April 11, 2016 Meni original trajao 5 na Civicu. Sad energizer pri kraju nakon 3 godine i koji mjesec..
Vucko Posted April 11, 2016 Posted April 11, 2016 Kada smo vec kod akumulatora, tko ih otkupljuje i koliko se dobije po komadu cca. Imam ih valjda 6,7 po garazi... Svi ih skoro otkupljuju, prije godinu dana sam dobio 3,6kn po kili,prije par mjeseci su mi nudili kunu i pol po kili u zg. Raspitaj se gdje otkupljuju metal, raznolikih ponuda ima.
Bezimeni Posted April 11, 2016 Posted April 11, 2016 Exide preko 5 godina u BMWu, s time da auto stoji mjesecima preko zime u garazi u uvijek upali na "prvi zub"
