huzek Posted October 23, 2008 Posted October 23, 2008 Dakle zanima koje je najbolje ulje za kočnice? Mora biti 5.1 i trkače.....
SMA Posted October 23, 2008 Posted October 23, 2008 Ate SUPER BLUE RACING DOĐE TI 109KN LITRA PLUS JOŠ NEKI POPUST KOD MENE U TAS-u. Inače ulje je odlično imam na svom autu i dosta ga ljudi hvali!
Dinnek Posted October 23, 2008 Posted October 23, 2008 Ate SUPER BLUE RACING DOĐE TI 109KN LITRA PLUS JOŠ NEKI POPUST KOD MENE U TAS-u.Inače ulje je odlično imam na svom autu i dosta ga ljudi hvali! tak je ja ga sebi uzeo neki dan.. :thumbsup:
huzek Posted October 23, 2008 Author Posted October 23, 2008 Nisam ni mislio kupiti nigdje drugdje haha Jednom TAS uvijek TAS
eNcode Posted October 23, 2008 Posted October 23, 2008 samo ti ate blue racing nije dot 5,1 ulje vec dot 4
ND4SPD Posted October 23, 2008 Posted October 23, 2008 inace da vas naucim, kako su i mene naucili nije ulje nego tekucina, brake fluid, kociona tekucina neke od boljih: Castrol SRF Motul RBF600 ATE Super Blue (ista stvar kao i ATE TYP 200) Mintex C-Tech Selenia Tutela Extreme 5 Ferodo Formula racing brake fluid samo ti ate blue racing nije dot 5,1 ulje vec dot 4 to nema veze, jer nadmasuje svojstva dot 5.1, a dot 5.1 se ponekad onzacava i kao dot 4+ i sl. i samo da napomenem, nikako ne stavljati dot 5 tekucinu u automobil!
galeb_st Posted December 31, 2008 Posted December 31, 2008 inace da vas naucim, kako su i mene naucili nije ulje nego tekucina, brake fluid, kociona tekucina neke od boljih: Castrol SRF Motul RBF600 ATE Super Blue (ista stvar kao i ATE TYP 200) Mintex C-Tech Selenia Tutela Extreme 5 Ferodo Formula racing brake fluid to nema veze, jer nadmasuje svojstva dot 5.1, a dot 5.1 se ponekad onzacava i kao dot 4+ i sl. i samo da napomenem, nikako ne stavljati dot 5 tekucinu u automobil! zasto NE DOT 5
Dottore Posted January 1, 2009 Posted January 1, 2009 DOT 5 se ne sipa u DOT 4 sisteme, razgriza sve gumice.!!!! I ne koristi se u normalnim autima. Silikonsko 5.0 je potpuno otporno na vlagu to je točno ali su kočnice "malo mekane" sa njim. Maknite se ulja 5.0 kao da je to nešto drugo ( i jeste posebno) osim ako se izričito ne traži to ulje zbog specifičnosti kočionog sistema a traži se sigurno za upotrebu na Harley Davidson-u za ostalo nisam baš siguran a za automobile posebno ne. Ne pravite zabunu pišite TOČNO. 5.1 nije ni slično 5.0 (5 u vašem tekstu).Još nešto veoma važno. Piše u uputstvu da je 5.1 kompatibilno (kad su gumice u pitanju) sa dot3 ili dot4 ali se isto kaže da se ta dva ulja ipak ne mješaju ! ! ! Drugim riječima znači da se prvo isprazni sistem pa da se sipa novo 5.1 i to je onda to. Nasuprot toga dot5 ili 5.0 je ulje na bazi silikonskog ulja i uglavnom se koristi u nekim motociklima i jedino je koje se potpuno razlikuje od ostalih. I dot5.1 i dot5 (5.0) se teže nalaze a ima uglavnom dot4. Ne čitaju svi sve postove pa zato pišite točno da ne dođe do zabune jer je ovdje svaka greška opasna. Ja sam nailazio na ulje koje se zove 4plus i nije mi jasno kakva je tu fora. Logično bi bilo da je to ustvari 5.1 ali pustimo tu logiku kad je i ovako zakomplicirano sa nazivima.Pitam se samo da li je taj bio normalan kad je silikonskom ulju dao broj u nizu 5 (5.0) posto već postoje 2,3,4 što dovodi do strašne zabune. No , što je tu je. @Nid for spid dobar izbor tekučine njam 5.1 ulja su inače jako toksična i mogu izazvati alergije, dodir sa kožom nije preporučljiv!!!
Prpa Posted January 1, 2009 Posted January 1, 2009 i samo da napomenem, nikako ne stavljati dot 5 tekucinu u automobil! Ja imam vec godinu dana dot 5.0 i nikakvih problema i super sam zadovoljan jedino sto se nesmije mjesat s nijednim drugim uljem i pri izmjeni trebalo bi citav sistem oprat alkoholom:thumbsup:
Rudy Posted January 1, 2009 Posted January 1, 2009 Ate SUPER BLUE RACING DOĐE TI 109KN LITRA PLUS JOŠ NEKI POPUST KOD MENE U TAS-u.Inače ulje je odlično imam na svom autu i dosta ga ljudi hvali! Yep ulje je odlično,mislim da je negdje cca 280 stupnjeva!!:thumbsup:
eNcode Posted January 1, 2009 Posted January 1, 2009 (edited) Ne znam baš, imao sam to ate ulje na 2 auta s serijskim diskovima i pločicama. Na prvom mi autu uopće nije kočio auto dok je bio hladan, znači prvih par kočenja ništa. Poslje je bilo ok. Nisam uspio skužiti do čega je, jer sam ga prodo. Kupio sam drugi auto, vozio se i onda napravio servis. Opet promjenio ulje u Ate i opet auto dok je hladan ne koči ok. Nakon tog vraćam orginal ulje, topao ili hladan koči jednako. Jel itko išta zna o tom? Edited January 1, 2009 by eNcode
Akula Posted January 1, 2009 Posted January 1, 2009 koristio do sada ferodo racing 5.1 i za moje potrebe je ok
galeb_st Posted January 1, 2009 Posted January 1, 2009 DOT 5 se ne sipa u DOT 4 sisteme, razgriza sve gumice.!!!! I ne koristi se u normalnim autima.Silikonsko 5.0 je potpuno otporno na vlagu to je točno ali su kočnice "malo mekane" sa njim. Maknite se ulja 5.0 kao da je to nešto drugo ( i jeste posebno) osim ako se izričito ne traži to ulje zbog specifičnosti kočionog sistema a traži se sigurno za upotrebu na Harley Davidson-u za ostalo nisam baš siguran a za automobile posebno ne. Ne pravite zabunu pišite TOČNO. 5.1 nije ni slično 5.0 (5 u vašem tekstu).Još nešto veoma važno. Piše u uputstvu da je 5.1 kompatibilno (kad su gumice u pitanju) sa dot3 ili dot4 ali se isto kaže da se ta dva ulja ipak ne mješaju ! ! ! Drugim riječima znači da se prvo isprazni sistem pa da se sipa novo 5.1 i to je onda to. Nasuprot toga dot5 ili 5.0 je ulje na bazi silikonskog ulja i uglavnom se koristi u nekim motociklima i jedino je koje se potpuno razlikuje od ostalih. I dot5.1 i dot5 (5.0) se teže nalaze a ima uglavnom dot4. Ne čitaju svi sve postove pa zato pišite točno da ne dođe do zabune jer je ovdje svaka greška opasna. Ja sam nailazio na ulje koje se zove 4plus i nije mi jasno kakva je tu fora. Logično bi bilo da je to ustvari 5.1 ali pustimo tu logiku kad je i ovako zakomplicirano sa nazivima.Pitam se samo da li je taj bio normalan kad je silikonskom ulju dao broj u nizu 5 (5.0) posto već postoje 2,3,4 što dovodi do strašne zabune. No , što je tu je. @Nid for spid dobar izbor tekučine njam 5.1 ulja su inače jako toksična i mogu izazvati alergije, dodir sa kožom nije preporučljiv!!! HVALA :notworthy:
GoranE46 Posted January 2, 2009 Posted January 2, 2009 Castrol SRF DOT 4 je meni osobno najdraže..... Ferodo racing mi je očaj živi i nikako dokučit zašto se pregrijava i sve, dok nismo otkrili da svako NOVO pakiranje ima u ulju 1% vlage...., dok recimo Shell neko 5.1 0%, SRF isto 0% i ostane 0% vlage jako dugo...
huzek Posted January 2, 2009 Author Posted January 2, 2009 To nisam znao da se ne smije stavljat 5.1 ulje u sisteme za DOT4. Ja imam Valvoline 5.1 već dvije godine i lajtunzi su u super stanju...... Znači ATE Blue?
2fast Posted January 2, 2009 Posted January 2, 2009 (edited) Ne, nego se DOT 5.0 ulje ne smije stavljati u ostale sisteme. DOT5.1 ti je ulje, odnosno "tekućina" kao i DOT4 ili DOT3, znači nije agresivna prema sistemu / gumicama i može ići u sve sisteme. Edited January 2, 2009 by 2fast
444IN Posted January 2, 2009 Posted January 2, 2009 Jeli taj Castrol jos uvijek ima onu "popularnu" cijenu, ja davno kad sam gledao bio je brda skup...??
Dominik Posted January 2, 2009 Posted January 2, 2009 aha :lol:, zato sam i napisao da je novo najbolje
ND4SPD Posted January 2, 2009 Posted January 2, 2009 Jeli taj Castrol jos uvijek ima onu "popularnu" cijenu, ja davno kad sam gledao bio je brda skup...?? skup je jos uvijek
Dottore Posted January 2, 2009 Posted January 2, 2009 najbolje je novo, a od novih castrol SRF koliko? mislim 480kn?
ND4SPD Posted January 3, 2009 Posted January 3, 2009 koliko? mislim 480kn? a tak je nekako bilo kad sam prosli put gledao
444IN Posted January 3, 2009 Posted January 3, 2009 PSMTR i cijeni, mozda jednom probam ako se bas jako zainatim...:doh:
Dinnek Posted January 3, 2009 Posted January 3, 2009 To nisam znao da se ne smije stavljat 5.1 ulje u sisteme za DOT4. Ja imam Valvoline 5.1 već dvije godine i lajtunzi su u super stanju......Znači ATE Blue? Imam ja ATE i ne znam kako da ti procjenim... a i za 100 kn koliko dodje ako ti se ne svidi mozes promjenit... Ali mislim da ce ti biti ok. :thumbsup:
