  • Replies 68
a kakvog ste misljenja o JE Piston???
Moje preporuka.
Uzmeš Je Piston i Pauter klipnjače i nećeš sigurno pogriješit u odabiru :thumbsup:
pa killer je vrtio svoju b16 kovanu na 9500 na serijskim bregastima, naravno imo je dobre aftermarket ventile i opruge
b16 stock motor, blokada stavljenja u kompu na 10000okr to je po cajgeru više jel obrtomjer laže za nekih 400 okretaja. par puta stisnuo do blokade, jest da ne razvija snagu i nema smisla. al osim oblaka dima ništa se drugo nije desilo
stock fiat tempra 1.6S fergazer bez problema na 9000 svaki put, pri tome je najveća buka bila iz getribe.
e sad fauve, digo liku na njegov zahtjev blokadu na ABF motoru na 7500 okretaja, i nakon 3 mjeseca mu se raspo motor. LOOOOOL .. i još je kao bila glava rađena.
Evo tebi kao "strucnjaku" jedno pitanje:
Koji motor ima vecu brzinu klipova:
ABF na 7500 o/min, ili B16 na 9000 o/min??:naughty:
O tezini klipova, radilice, zamasnjaka, klipnjaca,..... ovaj put necu ni pricati.
1. Honda S2000:
Engine Code: F20C1
Bore/Stroke: 3.43" X 3.31"
Redline: 9000rpm
Piston Speed: 4965 Ft/min
2. Lamborghini Gallardo
Engine Code: N/A
Bore/Stroke: 3.25" X 3.65"
Redline: 8000rpm
Piston Speed: 4866.67 Ft/min
3. Acura Integra Type R
Engine Code: B18C5
Bore/Stroke: 3.19" X 3.43"
Redline: 8400rpm
Piston Speed: 4802 Ft/min
4. BMW M3
Engine Code: S54
Bore/Stroke: 3.43" X 3.58"
Redline: 8000rpm
Piston Speed: 4773.33 Ft/min
5. Honda S2000 2004
Engine Code: F22C
Bore/Stroke: 3.43" X 3.57"
Redline: 8000rpm
Piston Speed: 4760 Ft/min
6. Honda Integra Type R (JDM)
Engine Code: K20A
Bore/Stroke: 3.39" X 3.39"
Redline: 8400rpm
Piston Speed: 4746 Ft/min
7. Acura Integra GSR 2001
Engine Code: B18C
Redline: 8200rpm
Piston Speed: 4687.67 Ft/min
8. Saleen S7
Engine Code: N/A
Bore/Stroke: 4.13" X 4.00"
Redline: 7000rpm
Piston Speed: 4666.67 Ft/min
9. Acura TSX
Engine Code: K24A2
Bore/Stroke: 3.43" X 3.90"
Redline: 7100rpm
Piston Speed: 4615 Ft/min
10. Suzuki Hayabusa Sport Prototype
Engine Code: W701
Bore/Stroke: 3.19" X 2.48"
Redline: 11000rpm
Piston Speed: 4546.67 Ft/min
11. Honda Civic Type R
Engine Code: B16B
Bore/Stroke: 3.19" X 3.03"
Redline: 9000rpm
Piston Speed: 4545 Ft/min
12. Toyota Celica GTS / Matrix XRS 2001
Engine Code: 2ZZ-GE
Bore/Stroke: 3.23" X 3.35"
Redline: 8100rpm
Piston Speed: 4522.5 Ft/min
13. Honda Prelude Type S (JDM)
Engine Code: H22A
Redline: 7500rpm
Piston Speed: 4462.5 Ft/min
14. Acura RSX Type S
Engine Code: K20A2
Bore/Stroke: 3.38" X 3.38"
Redline: 7900rpm
Piston Speed: 4450.33 Ft/min
15. Ferrari 360 Modena (incl. Challenge, Stradale, etc)
Engine Code: N/A
Bore/Stroke: 3.35" X 3.11"
Redline: 8500rpm
Piston Speed: 4405.83 Ft/min
aktualna lista top 15 motora po brzini klipa u stock formatu
prepuna lista VW motora DOH
Edited by charger
Pojasnite si sami.
Kako se izracunava brzina klipova svakog pojedinog motora?
Npr. ABF 92,8 mm hod na 7500 o/min,....
Koja je brzina klipa?
a duljina klipnjace?
a, tu pricate o srednjoj brzini klipa. Skoro pa beskorisan podatak. Nisam vidio dobro.
Zbunila me chargerova mjera, jer je u 1min, a ne u 1s. Pa mi je letimicno izgledalo da se prica o najvecoj brzini.
hebo srednju brzinu ako najveca prelazi 25-26 m/s pogotovo na nekom "normalnom" autu koji nema ogranicen budget ...
F1 ima 27 m/s u crvenom...
Ovdje dolazi do izrazaja rod ratio i sto je veca najveca brzina klipa trebali bi se koristit sto laksi klipovi i klipnjace ako se zeli da to traje imalo :)
Uglavnom dosta varijabli ima i nema univerzalnog rjesenja nego ovisno o svakom slucaju zasebno pa prema tome treba i odabrat :) ... a tu onda igra rod ratio
Edited by kutija
Naravno da je rod ratio itekako bitan.
Sto je veci, to ce i odaziv na vecim okretajima biti bolji, i obratno.
Jos bitnija stvar je hod kao i bore to stroke ratio koji je kod F1 motora oko 2,5..
F1 motor ima oko 40mm hod i rod ratio preko 2,1.
A o masama, sta reci,.....kad cijeli motor (V8) od F1 ima manje od 100kg.:)
Edited by KIMI_1.8T
