Tko mi može riješit za golf 2 Rally-e poliuretanske selene za prednji kraj,znači sve što se da promjenit na prednjem kraju, da bude jače od originala?
  • Replies 55
  • Last Reply
Mogu ti ja strongflex nabaviti.
Strongflex mislim da ima 2 god garancije. Kod mene su vec 12000km na autu i jos uvijek rade. Dok su serijski seleni drzali max 10 000km.
Jel može neko objasniti kako se auto ponaša sa tim poliuteranskim selenima u odnosu na serijske i koja im je prednost osim što duže traju? Iz prakse?
Bolje se ponasa auta.
powerflex punokvalitetniji...
Strongflex pretvrd imao sam crvene koji su kao mekaniji
Ja sam mislio da cu crveni najblize originalnoj tvrdoci.
Which material should I choose: RED or YELLOW?
What is the difference between RED (80 ShA) and YELLOW (90 ShA) bushes?
RED color - hardness of about 80 ShA - suspension components have a hardness similar to the original metal-rubber bushes. However, strength of the polyurethane is many times greater, and the unique properties ensure long lasting comfort. Our RED products we recommend for all the "normal" car users who want improve stability and better driving. We give 2 years warranty, we are sure that at that time, our products will fully meet their tasks.
YELLOW color - hardness of about 90 ShA - recommended for racing-sports vehicles, tuned.. etc. The suspension is much stiffer, as at higher speeds is important. Durability ensures stability of polyurethane suspension for many years.
BLACK color - hardness 80 or 90 ShA - made on request.
The main difference between red and yellow products is HARDNESS! Material resistance to weathering, oils, grease, salt, acids, solvents, in both cases is EXCELLENT!
Šta su ti strongflex tvrđi od powerflexa?
Ovisno koju boju uzmes. Crveni je otprilike kao stock tvrdi, zuti je tvrdi.
Ali da ovi u Powerflexu ne mogu napraviti ništa za auto (Clio 197/200) koji se proizvodio 2006-2012...:(
Pa napravi sam. Gdje je problem? U tome sto se ne zove Powerflex?
Na svojim sam autima sve selena dao napraviti na CNC glodalici i tokarilici. PU je PU.
S time da sam svoje selene radio od Poliamida PA-MoS2
Edited by KIMI_1.8T
Gdje ima toga za kupit,daj neku adresu?
Imaš te crvene ( mekaniji) i žuti ( tvrdi)....isprobao i jedne i druge i powerflex je tv u boji naspram ovih. Vesko ako naručujes naruči powerflex nebudes pogriješio.
