puki Posted January 10, 2014 Posted January 10, 2014 moze neka preporuka full sintetike za getribu 75w90, colt czt , navodno da je Fuchs titan race SYN5 jako dobar? po originalu neznam sta ide unutra ali nikad nisam imao problema..
jucca Posted January 10, 2014 Posted January 10, 2014 (edited) TAF X imam i ja odnedavno, nije mi rjesio saltanje u potpunosti, ali vecinu jest. Ovi moji sa Mazda foruma se kunu u Ford Manual Transaxle fluid XT-M5-QS Imam i dalje problemcic sa saltanjem u drugu, kao i mnogi ostali u ovom threadu: http://www.mazdaspeedforums.org/forum/f629/transmission-cured-125104/ i rješili su problem stavljajuci ovo Fordovo ulje tj. Fuchs koji ih radi za njih Edited January 10, 2014 by jucca
Raptor6767 Posted January 10, 2014 Posted January 10, 2014 Sa Castrolom TAF X nemožeš omašiti :thumbsup: U novom pakiranju (ovaj na desno) i s novim imenom:
Kevin Posted January 10, 2014 Posted January 10, 2014 10€ na ebayu litra :doh: http://www.ebay.de/itm/Castrol-Syntrax-Limited-Slip-75W-140-ehe-SAF-XJ-1-Liter-Dose-BMW-m-LS-Sp-/170861826041?pt=DE_Autoteile&hash=item27c8288ff9
ZOD Posted January 10, 2014 Posted January 10, 2014 Naspram 161kn za Syntrax Limited Slip. Ili Syntrans Transaxle: http://www.ebay.de/itm/Castrol-Syntrans-Transaxle-75W-90-1-Liter-API-GL-4-VW-501-50-VW-G-052-9119-/171156221908?pt=Motorrad_Kraftradteile&hash=item27d9b4afd4#ht_1354wt_1160
jucca Posted January 10, 2014 Posted January 10, 2014 http://www.ebay.de/itm/Castrol-Syntrans-Transaxle-75W-90-1-L-/200995380873?pt=DE_Autoteile&hash=item2ecc421e89
ZOD Posted January 10, 2014 Posted January 10, 2014 Ili ovdje: http://www.topstart.hr/katalog/89/castrol/?block=5
Hic Posted January 11, 2014 Posted January 11, 2014 Samo imajte na umu da je trziste ulja PREPLAVLJENO laznjacima, npr. U Srbiji se nabavi Motul 300V pa 6€ litra. Toliko malo ni tvornicu ne kosta. Castrol je nor. NAJKRIVOTVORENIJA marka ulja, uz Mobil. Prije nego svrsite na ebay cijene, ukljucite malo mozdane vijuge. Nema TAKO jeftinig, a kao NAJBOLJEG ulja.
Kevin Posted January 11, 2014 Posted January 11, 2014 ima nesto i u tome "ako nemam marzu od 60%, neradim". mislim na nase prodavace djelova i ulja..
fire Posted January 11, 2014 Posted January 11, 2014 ima nesto i u tome "ako nemam marzu od 60%, neradim".mislim na nase prodavace djelova i ulja.. Prije bi bilo ako nemam marzu 100% ne radim. Pa dosta mehanicara na nake djelove ima popust 60%, a na tim djelovima je trgovac zaradio.
Uros Posted January 11, 2014 Posted January 11, 2014 ima nesto i u tome "ako nemam marzu od 60%, neradim".mislim na nase prodavace djelova i ulja.. a s koliko bi ti radio i platio ljude,prostor,struju,doprinose,komunalnu naknadu,aute,gorivo i sve ostale troškove poslovanja?
Hic Posted January 11, 2014 Posted January 11, 2014 Otvorite svoju firmu, kupite/iznajmite prostor, neki mali lager, npr. 5000€, pa serite o marzama. Po ovakvim proljevima za 3 dana NITKO ne bi radio, jer bi propali u roku keks. Najlakse sjedit doma i pametovat o marzama. A nitko nije probao raditi kad ima 1000000kn godisnje koje mora zaraditi(ne prometovati) da bi platio ljude, prostor, drzavu, itd, a da jedne jebene kune ne stavi u djep.
Kevin Posted January 11, 2014 Posted January 11, 2014 a kako to onda vani uspjeva i funkcionira s normalnim marzama od 10-12%? cek, vec vidim odgovor, drzava je kriva
Swordfish Posted January 11, 2014 Posted January 11, 2014 Teški OT... Koje ulje da ja stavim u scenica 1.6 16v? Postoji li neka tekućina da se ispere mjenjač kod izmjene? Negdje sam pročitao da to rade petrolejem ?!
Mille Posted January 11, 2014 Posted January 11, 2014 a kako to onda vani uspjeva i funkcionira s normalnim marzama od 10-12%? cek, vec vidim odgovor, drzava je kriva Na šta točno je to marža od 10-12% ? Na proizvodnju ? Preprodaju ?
fire Posted January 11, 2014 Posted January 11, 2014 ebay ima puno bolju zastitu brandova. Ako pise da je orginal, onda je 99.99999% orginal. Jer ako se skuzi da nije orginal nesto, taj kupac gubi oho love i gotov je. A kod nas ce slegnuti ramenom i gotovo. Ako se gdje treba bojati neorginal robe to je kod nas, ne ebay.
Žile Posted January 11, 2014 Posted January 11, 2014 a kako to onda vani uspjeva i funkcionira s normalnim marzama od 10-12%? cek, vec vidim odgovor, drzava je kriva Ako je sve po PS-u kao u mome slučaju, ispod 20% si propao...možda maloprodaja malo manje jer mi frankiramo robu sa svojih 12 kamiona po cijeloj HR. Ali i maloprodaja sumnjam ispod 15% da može disati. Ovih 10-12% eventualno u svome prostoru i da i ti radiš. Zanemarimo ovo što sam napisao u slučaju da imaš bolesno dobar promet što vjerovatno i je u ovom slučaju koji spominješ
Hic Posted January 11, 2014 Posted January 11, 2014 a kako to onda vani uspjeva i funkcionira s normalnim marzama od 10-12%? cek, vec vidim odgovor, drzava je kriva Ponavljam, daj primjer!
