Seb Posted May 1, 2014 Report Share Posted May 1, 2014 Imo ko za preporučit nekog ko bi mi mogo napravit sportsku ispušnu granu za Fiatov 1.9 16v MJet motor?! ili zna di se već može kupit gotova? Link to comment Share on other sites More sharing options...
Raptor6767 Posted May 1, 2014 Report Share Posted May 1, 2014 Mille, ali neće biti jeftino. Link to comment Share on other sites More sharing options...
AntonioVW Posted May 1, 2014 Report Share Posted May 1, 2014 Možda Vesko? Link to comment Share on other sites More sharing options...
Red Devil Posted May 1, 2014 Report Share Posted May 1, 2014 Imas Mille Lastovcic - moze raditi po uzorku ili po slici Dak motorsport - meni je pukla na 1.8T Vesko Sve ovisi koliko para u igri Link to comment Share on other sites More sharing options...
Hitt Posted May 1, 2014 Report Share Posted May 1, 2014 Imas Mille Lastovcic - moze raditi po uzorku ili po slici Dak motorsport - meni je pukla na 1.8T Vesko Sve ovisi koliko para u igri Cijene? Inox? mmstjenka? Varovi? Garancija? Ne pitam za sebe samo me zanima kakva je ponuda kad se vec pise Link to comment Share on other sites More sharing options...
Sasaa Posted May 1, 2014 Report Share Posted May 1, 2014 Mille ... +1 Link to comment Share on other sites More sharing options...
SVEN Posted May 1, 2014 Report Share Posted May 1, 2014 (edited) Ja konkretno trazim ovo. Tko moze izraditi identicnu granu. Koliko novaca, materjal ? Ovaj gotov proizvod vani ksota 850 eura. Koliko bi kod nas kostalo ? Nekazem da je ovo puno nego bih radije potpomogao nase ljude nego neke tamo ko zna koga. EDIT: Ovo je DAK Motorsport varijanta ispusne za 500e. Ne svidjaju mi se ova koljena koja idu u spic. Mada od do sad vidjenog u HR, najpriblizniji produkt gornjim slikama. Edited May 1, 2014 by SVEN Link to comment Share on other sites More sharing options...
Ozy Posted May 1, 2014 Report Share Posted May 1, 2014 Meni je Lastin decko radio Ivica Šuflaj ali nije dobro radila.. misfire idr. simptomi.. Bila je sponzorska pa se nisam zalio a kad je doggy preuzeo auto je stavio h-dev i sve okej.. dakle do grane je bilo 100%. Dao bih Milletu iducu raditi.. Link to comment Share on other sites More sharing options...
Sasaa Posted May 1, 2014 Report Share Posted May 1, 2014 Mille, ali neće biti jeftino. Posto imam nekog iskustva sa Milletom, pa komentar na ovo: Mille nije jeftin (kako se uzme), ali kad pogledas sta dobijes... pa stavis na papir koliko kosta grana za takvim spec vani, pa platis postarinu i uvoz... matematika je jednostavna. Pogotovo ako imas neku stvar koju treba malo pripasat, covjek to odradi vrhunski. Da ne kazem da se dogadja i da te grane "izvana" znaju puknut, pa sta onda, salji nazad, natezi se sa garancijom, placaj postarinu itd... Link to comment Share on other sites More sharing options...
Raptor6767 Posted May 1, 2014 Report Share Posted May 1, 2014 Definitivno, ali ekipa kad čuje 1000€ za granu, a upola su platili cijeli ispušni sistem onda ja moram upravo te stvari reći. Link to comment Share on other sites More sharing options...
Alfaludak Posted May 1, 2014 Report Share Posted May 1, 2014 Na Mazdi trebam novu granu, pitao na nekoliko mjesta i dobio nekoliko punuda. Razlike u cijeni su onako... poprilicne ali iskustvo je reklo svoje - nisam toliko bogat da kupujem dvaput! Dvoumim se između Milleta, Veska, Meme (Trogir) i jos jednog covjeka, vidio sam i jedne i druge uratke i ne mogu reci ni za jednoga nista lose jer sve sto sam vidio bilo je savrseno. Svi oni rade kvalitetno, rade provare, rade od 3mm stjenke i stoje iza svog posla. Ja skupljam pare za granu pa cu vidjeti i odluciti Inace, trebam tri grane, za mazdu, ficu i za golfa, tako da cu vidjeti cija ponuda mi najvise odgovara jer kako kazem, nema sanse da vise radim 2 puta isti posao! Link to comment Share on other sites More sharing options...
Raptor6767 Posted May 1, 2014 Report Share Posted May 1, 2014 Ako ti lova nije problem - Mille. Jer ionako ti je u ZG pa i da se dogodi sranje možeš se odmah vidjeti sa njim itd... Link to comment Share on other sites More sharing options...
Pekx Posted May 1, 2014 Report Share Posted May 1, 2014 Sven, znas da su sa tim "tubular" granama dobici na pd130 minimalni, odnosno ako uzmes ulozeno dobiveno - zanemarivi. Osim ako ne juris 300 konja, daj nekom da ti preradi vulgaris oem "gus" granu i vozi. Evo exfreerider se tak vozi i nema problema, skupa sa gomilom auta po stranim forumima sa 250+ konja. A sto se tice ispusnih sustava i grana, za Mileta sam cuo sa vise strana, od ljudi koji nisu na forumu da odlicno radi, a vjerujem da to moze sloziti bolje od ovih ponekad fuserskih internet grana. Link to comment Share on other sites More sharing options...
Red Devil Posted May 1, 2014 Report Share Posted May 1, 2014 Cijene? Inox? mmstjenka? Varovi? Garancija? Ne pitam za sebe samo me zanima kakva je ponuda kad se vec pise sve je stvar tvojih želja.....garanciju daje samo mille koliko znam Link to comment Share on other sites More sharing options...
buby_FR Posted May 1, 2014 Report Share Posted May 1, 2014 Sven ako ibiza od AM motorsporta vozi 10 sek na grani od seriske turbine 130 ks onda ne vidim zašto ic dat 500+ eura za drugu. Link to comment Share on other sites More sharing options...
fire Posted May 1, 2014 Report Share Posted May 1, 2014 Zaboravili ste jos spomenuti konopeka. Vidio puno uradaka od gore svih navedenih i po mome neki ne vrijede tog novca. Link to comment Share on other sites More sharing options...
ZOD Posted May 1, 2014 Report Share Posted May 1, 2014 Ante Buličić isto izrađuje. Link to comment Share on other sites More sharing options...
SVEN Posted May 2, 2014 Report Share Posted May 2, 2014 Na Mazdi trebam novu granu, pitao na nekoliko mjesta i dobio nekoliko punuda.Razlike u cijeni su onako... poprilicne ali iskustvo je reklo svoje - nisam toliko bogat da kupujem dvaput! Dvoumim se između Milleta, Veska, Meme (Trogir) i jos jednog covjeka, vidio sam i jedne i druge uratke i ne mogu reci ni za jednoga nista lose jer sve sto sam vidio bilo je savrseno. Svi oni rade kvalitetno, rade provare, rade od 3mm stjenke i stoje iza svog posla. Ja skupljam pare za granu pa cu vidjeti i odluciti Inace, trebam tri grane, za mazdu, ficu i za golfa, tako da cu vidjeti cija ponuda mi najvise odgovara jer kako kazem, nema sanse da vise radim 2 puta isti posao! pune li argonom tokom varenja ? Sven, znas da su sa tim "tubular" granama dobici na pd130 minimalni, odnosno ako uzmes ulozeno dobiveno - zanemarivi. Osim ako ne juris 300 konja, daj nekom da ti preradi vulgaris oem "gus" granu i vozi. Evo exfreerider se tak vozi i nema problema, skupa sa gomilom auta po stranim forumima sa 250+ konja.A sto se tice ispusnih sustava i grana, za Mileta sam cuo sa vise strana, od ljudi koji nisu na forumu da odlicno radi, a vjerujem da to moze sloziti bolje od ovih ponekad fuserskih internet grana. znas da je tuning skup malih poboljsanja koji na kraju cine "nesto" . Naravno neces sa svakim upgrejdom dobit ko cipanjem sa 100 na 150 konja. Sven ako ibiza od AM motorsporta vozi 10 sek na grani od seriske turbine 130 ks onda ne vidim zašto ic dat 500+ eura za drugu. Ma ne kazem da nevalja i da nemre. Cisto me zanimaju ponude. Ak netko napravi ovo za stvarno super cijenu zasto ne kupiti ? Mada je i ova cijena od 750 ili koliko vec eura cisto ok. Link to comment Share on other sites More sharing options...
d.e.n.i.s Posted May 2, 2014 Report Share Posted May 2, 2014 Koliko ja vidim na njihovoj stranici, je cijena £750,00, a to je 900 Eura. Cijene od nekih nasih majstora su prebolesne, no bedaka uvijek ima i bit ce ih. Link to comment Share on other sites More sharing options...
Zeljko_M Posted May 2, 2014 Report Share Posted May 2, 2014 Mille mi je radio neke fantasticne stvari na bivsem vozilu i mogu ga samo pohvaliti. Netreba puno pisat, njegov rad treba vidjet svojim ocima, a njegov rad je sam sebi reklama. Seb ako jos nisi bio kod Milleta fino se dogovorite i odi baci oko. Link to comment Share on other sites More sharing options...
Zeljko_M Posted May 2, 2014 Report Share Posted May 2, 2014 pune li argonom tokom varenja ? Jeli dobar odgovor? Link to comment Share on other sites More sharing options...
Marko Posted May 2, 2014 Report Share Posted May 2, 2014 fora orbitalac :thumbsup: Link to comment Share on other sites More sharing options...
Mille Posted May 2, 2014 Report Share Posted May 2, 2014 fora orbitalac :thumbsup: Imam ih 4 komada + fanuc robot , za sada jedini u hrvatskoj koji vari sa tigom i kamerom u 8 osi . Link to comment Share on other sites More sharing options...
J.J Posted May 2, 2014 Report Share Posted May 2, 2014 Imam ih 4 komada + fanuc robot , za sada jedini u hrvatskoj koji vari sa tigom i kamerom u 8 osi . Kaj se snimaš dok radiš... Link to comment Share on other sites More sharing options...
Mille Posted May 2, 2014 Report Share Posted May 2, 2014 Kaj se snimaš dok radiš... Naravno da se snimam. Lep lepsi a nu mene Link to comment Share on other sites More sharing options...
