Unknown Posted April 19, 2016 Posted April 19, 2016 (edited) Pise bypass solenoid. Kaj pogledat kod tog? Dosta se spominja ona mala vakum crijeva. Auto izmedu cca3500 i cca 4500 ima laganu stanku u boostu Edited April 19, 2016 by Unknown
Miataoldschool Posted April 19, 2016 Posted April 19, 2016 mozda boost leak...pregledaj sve spojeve,crijeva..trazi los spoj pukotime i slicno..mozda pomogne
2fast Posted April 20, 2016 Posted April 20, 2016 Ti solenoidi rikavaju, nisam nikad imao tu grešku, ali nije rijetka.
Unknown Posted April 20, 2016 Author Posted April 20, 2016 kolko para,kak ispitat. dal onaj napred ili iza
2fast Posted April 20, 2016 Posted April 20, 2016 Mislim da ti imam doma par komada. Oba znaju riknut.
Unknown Posted April 20, 2016 Author Posted April 20, 2016 eto malo sam prckao po tim cjevcicama od vakuma i sad auto opet vuce konstantno i ponovo puca al greska je i dalje tu P1243-58 Turbocharger Bypass Solenoid Valve Circuit
Unknown Posted June 10, 2016 Author Posted June 10, 2016 (edited) spojili smo boost na cukicu primjetili smo da: overboost kada krene auto puni 1.5 bar, nakon kaj se se smiri na ja mislim 1.2 (ili 1bar nezan ni sam vise) ima male varijacije gore dolje. to znam osjetit u 6 oj kada ga do kraja poklopim oko 3500 i kada prode okretaje dalje ide normalno stavio sam drugi solenoid na turbo zatim i iza motora za BOW i isto greska dalje. cim napuni boost i ja pustim gas bum ta greska graska nije da mi ju stalno prikazuje, samo na ocitanju i ja se vozim sasvim normalno svaki dan s tim. da li je moguce da serijski bow ne radi kako treba i radi taj problem? da li je to normalno? Edited June 10, 2016 by Unknown
2fast Posted June 10, 2016 Posted June 10, 2016 Moguće da je membrana napukla. Imao sam sličan problem. Najbolje rješenje njega blokirati i staviti dvoklipni.
Unknown Posted June 10, 2016 Author Posted June 10, 2016 moram prvo naci problem da ga mogu rijesiti. ako kupim drugi bow i nije to onda sam bzvz bavio lovu
Unknown Posted September 24, 2017 Author Posted September 24, 2017 greska se ponovo vratila i nervira me. koliko sam istrazivoa ili je blow off ili su ti soleonidi. da li ima tko tu da mi moze pomoci oko tog. dogada mi se da kada jurim i saltam pri punom gasu auto ima stanku jedno sekundu izmedu brzina i onda pocne ponovo vuci. ko da ne krene boost odmah
Kic Posted September 24, 2017 Posted September 24, 2017 Prije isušena i popucala vakum crijeva ili vac box propušta nego BOV/solenoid. Kak smo pričali maloprije, nabavi silikon pa ćemo izmijenjat crijeva. Ova stanka može bit i radi overboost-a pošto nemaš precat. Otpuštanje wastegate-a bi trebalo pomoć.
KIMI_1.8T Posted September 24, 2017 Posted September 24, 2017 Jel ja ne vidim ili nigdje ne pisu podatci koji je to motor?
KIMI_1.8T Posted September 24, 2017 Posted September 24, 2017 Onda vakum ne upravlja s turbinom nego tlak. Znaci , ako pukne to tanko (tlacno) crijevo, turbina puni koliko god moze jer N75 ventil ne otvara WG.
Kic Posted September 24, 2017 Posted September 24, 2017 On 24. 09. 2017. at 17:29, KIMI_1.8T said: Onda vakum ne upravlja s turbinom nego tlak. Znaci , ako pukne to tanko (tlacno) crijevo, turbina puni koliko god moze jer N75 ventil ne otvara WG. Expand Vakum odnosno ECU preko solenoida upravlja recirc BOV-om, to je ovaj P1243 WG/overboost je drugi problem
Unknown Posted September 24, 2017 Author Posted September 24, 2017 (edited) dobro kaj smo onda krecemo od crijeva? Edited September 24, 2017 by Unknown
KIMI_1.8T Posted September 25, 2017 Posted September 25, 2017 On 24. 09. 2017. at 18:03, Kic said: Vakum odnosno ECU preko solenoida upravlja recirc BOV-om, to je ovaj P1243 WG/overboost je drugi problem Expand Obicno BOV-pm upravlja vakum ili tlak direktno s usisne grane ovisno u kojem je polozaju klapna gasa (ako je klapna otvorena onda je na cjevcici tlak koji drzi BOV zatvorenim, a ako je zatvorena onda je podtlak/vakum (jer kad se klapna zatvori, motor u usisu stvara podtlak) i taj podtlak vuce membranu koja oslobadja tlak u sistemu usisa - ponovo ga vraca u usis turbine i tako radi recirkulaciju. Malo gledam te turbine i naletim na ovu sliku. Ovo ovako ne moze raditi. Cjevcica koja ide na BOV sigurno ne ide sa el. ventila. Ta cjevcica mora ici negdje na tlacni dio jer WG-om upravlja tlak a cjevcica sa BOV-a negdje na usisnu granu iza klapne gasa (strana prema glavi motora). Uglavnom, ove membrane na recirkulirajucem BOV cesto puknu (napuknu) i stvaraju slican problem koji ima.
2fast Posted September 25, 2017 Posted September 25, 2017 On 25. 09. 2017. at 2:00, KIMI_1.8T said: Uglavnom, ove membrane na recirkulirajucem BOV cesto puknu (napuknu) i stvaraju slican problem koji ima. Expand To sam mu i ja rekao, imao sam identičan problem na svojem.
Kic Posted September 25, 2017 Posted September 25, 2017 (edited) @KIMI_1.8T Na toj tvojoj fotki je sve krivo pospajano. To na turbu je WG solenoid, boost kontrola, a BOV otvara ova skalamerija sa svojim solenoidom (zaokruzen): Prvi i najjeftiniji korak je izmijenjat sva ova crijeva, raspadnu se nakon 10 godina. BOV membrana se lako provjeri. Edited September 30, 2017 by Kic
Unknown Posted September 25, 2017 Author Posted September 25, 2017 eto u petak cemo ja i kic zamijeniti crijeva i izvaditi BOV na provjeru.
Unknown Posted September 30, 2017 Author Posted September 30, 2017 rijesen problem thx to kic. na vakum boxu bio je odpojen vacum za BOW, te stavljena nova siikonska crijeva. ali po original setupu
