Sasaa Posted October 16, 2012 Posted October 16, 2012 (edited) U skoro vrijeme bih kupovao clutch kit za Imprezu, koji bi mogao podnest vise snage od serijskog. Znaci trebalo bi trpit cca 600NM, i da ne bude pretvrda pedala, ako je to moguce. Trenutno auto ima nekih 460NM i serijska lamela se dobro drzi sa time, ali ne lansiram auto i napinjem na kretanju bas cesto. Ovo su mi neke od opcija, pa ako netko ima iskustava iz prve/druge ruke sa necim od ovoga nek slobodno napise, ili moze nesto pamento predlozit: SPEC Clutches Single stage 3+ http://www.specclutch.com/cars/Subaru/STi_WRX/2006/Single Mini twin 2-disc http://www.specclutch.com/cars/Subaru/STi_WRX/2006/Mini_Twin HELIX http://www.demon-tweeks.co.uk/motorsport/vehicle-specific-clutches/helix-subaru-impreza-clutch-and-flywheel-kit organic ili cerametallic EXEDY Multi plate clutch kit ili Hyper single clutch kit Edited October 16, 2012 by Sasaa
Hic Posted October 16, 2012 Posted October 16, 2012 Dupli helix kakav Kevin ima, meksi od serijskog. 700Nm.
Kevin Posted October 16, 2012 Posted October 16, 2012 da, zajebi sve i odmah idi na helix! ak si u zg dodji pa ti dam da mi stisnes kvachilo kak to gay zvuci
Sasaa Posted October 16, 2012 Author Posted October 16, 2012 ^^^^ ha ha ha :rofl: ako je tebi dobro za do praone, i nazad se sparkirat u garazu onda ce i meni bit dobro
Hans Posted October 16, 2012 Posted October 16, 2012 ... clutch kit .... Više nitko nezna govoriti hrvatski
Sasaa Posted October 16, 2012 Author Posted October 16, 2012 Kako se uopce to kave na hrvatskome Spojka, Kvacilo, Kuplung ?
Sasaa Posted October 16, 2012 Author Posted October 16, 2012 ^^^ to ti ja kazem, u svakom selu, pardon gradu drugi naziv ...
Ivan_T Posted October 16, 2012 Posted October 16, 2012 ^^^^ ha ha ha :rofl:ako je tebi dobro za do praone, i nazad se sparkirat u garazu onda ce i meni bit dobro za ovoliko koliko se vozis mozes i najtvrdje kvacilo... praona ti je blize nego ulaz od kucnih vrata do garaznih
Jerba2 Posted October 16, 2012 Posted October 16, 2012 Ajde buden ti pogledao za Exedy kolko bi koštao pa ti javim na pm..
Hans Posted October 16, 2012 Posted October 16, 2012 Kako se uopce to kave na hrvatskome Spojka, Kvacilo, Kuplung ? Spojka....garnitura spojke...ma i kvačilo je OK,ovako izgleda koda više niko ništa nezna nego samo prepisujue sa interneta nazive na engleskom.
fire Posted October 16, 2012 Posted October 16, 2012 BTW spec deklarira u lb/ft, a ne u Nm. Znaci stage 3+ je cca 860Nm
Raptor6767 Posted October 16, 2012 Posted October 16, 2012 (edited) Spojka....garnitura spojke...ma i kvačilo je OK,ovako izgleda koda više niko ništa nezna nego samo prepisujue sa interneta nazive na engleskom. Set kvačila. Ili ti, po naški - kuplung set. Edited October 16, 2012 by Raptor6767
Sasaa Posted October 16, 2012 Author Posted October 16, 2012 Spojka....garnitura spojke...ma i kvačilo je OK,ovako izgleda koda više niko ništa nezna nego samo prepisujue sa interneta nazive na engleskom. I roll bar svi zovu zastitni kavez... Sorry za engleski naziv, radim s englezima/amerima vec 10god, pa jbg, pokupis neke stvari...
ND4SPD Posted October 16, 2012 Posted October 16, 2012 Carbonetic je isto OK... Uostalom najbolje ti je provjeriti na nekom stranom forumu: http://bbs.scoobynet.com/forum.php http://forums.nasioc.com/forums/ http://www.iwsti.com/forums/
Sasaa Posted October 16, 2012 Author Posted October 16, 2012 Citam te forume tamo sam pokupio da se ovo najvise koristi, pa sad da vidim malo da li ima tu kakvih iskustava. Znam da su neki decki na Helixu vec dosta dugo.
Hic Posted October 16, 2012 Posted October 16, 2012 Exedy, carbonetic, spec...sve je to tvrdo ko kamen.
Kevin Posted October 17, 2012 Posted October 17, 2012 ^^^^ ha ha ha :rofl:ako je tebi dobro za do praone, i nazad se sparkirat u garazu onda ce i meni bit dobro pa da, vise od 700nm i netreba za to
Japanac Posted October 17, 2012 Posted October 17, 2012 Helix, ja ga imam na serijali i znam da je to jedini dio na autu koji se sigurno neće rasut uslijed divljanja Pedala je tvrda al navikneš nakon što te koljeno pogodi u bradu par puta kad otpuštaš pedalu
Peras Posted October 17, 2012 Posted October 17, 2012 ACT se meni pokazao fenomenalan i drži puno više za što je deklariran i traje, stvarno traje. Pedala ostala normalna, uopće nije tvrda.
doggy Posted October 17, 2012 Posted October 17, 2012 Kod mene je exedy sport tuff duplo mekši nego stock, a i carbonetics blade je dosta mekan i zanimljiv sa kretanjem,jer se ponaša kao organska lamela dok se nezagrije, a onda čupa. Inace probao sam vozit sti tvoje generacije, neznam koji set je imao, možda spec, ali mogu pitati. To je toliko tvrdo da bi nakon 3 semafora u gradu zapalio auto od muke. Neznam jel to stvar do subarua ili proizvodaca seta.
