_DEX_ Posted May 23, 2017 Share Posted May 23, 2017 Past ce ti koliko je deklarirano. Ako ti eibach nije dovoljno onda nemas kaj nego uzet te druge. Stavio bi ja gewinde, ali nedaje mi se 500 eura sad. Zulja me Sent from my LG-H850 using Tapatalk Link to comment Share on other sites More sharing options...
Jura1000 Posted May 23, 2017 Share Posted May 23, 2017 Imam na bravu eibach sportline, auto je pao 4cm kako je i pisalo , auto se super vozi , na lezecima moras stat . izgleda jako nisko tako da bi cak rade stavio pro kit. Zelim reci da nize od toga sigurno netreba, 4cm zvuci malo ali u praksi nije bas ... Link to comment Share on other sites More sharing options...
_DEX_ Posted May 23, 2017 Share Posted May 23, 2017 4 cm bi mi bilo savrseno. Za Yarisa nema 4 cm Eibach Sportline, samo Low tech ima 4 cm i kostaju 1500-1600 kn. Za njih mi je pak zao dat tolko kad Eibach kosta dosta manje. Brijem da cu na kraju uzet ove Vogtland kaj spustaju 35 mm. Bum si jos promislio koji dan, pa cu kupit nekaj.Sent from my LG-H850 using Tapatalk Link to comment Share on other sites More sharing options...
Vlado206 Posted May 23, 2017 Share Posted May 23, 2017 Lowtec ti je uvozio Scorpion sa foruma (autobusnja) prije, mozda i jos uvijek, po dobrim cijenama. Link to comment Share on other sites More sharing options...
_DEX_ Posted May 23, 2017 Share Posted May 23, 2017 Lowtec ti je uvozio Scorpion sa foruma (autobusnja) prije, mozda i jos uvijek, po dobrim cijenama.Clan Scorpine? Tog nalazim među clanovima. Poslat cu mu PM.Sent from my LG-H850 using Tapatalk Link to comment Share on other sites More sharing options...
Lovrek Posted May 23, 2017 Share Posted May 23, 2017 I ja stavio na svoj eibach pro kit opruge i pao je taman koliko sam htio...naprijed 2-3 u odnosu na M sport, iza 1-2 cm... Udobnost takodjer mozda cak i bolja od M sport... Link to comment Share on other sites More sharing options...
maredo Posted May 23, 2017 Share Posted May 23, 2017 I ja stavio na svoj eibach pro kit opruge i pao je taman koliko sam htio...naprijed 2-3 u odnosu na M sport, iza 1-2 cm... Udobnost takodjer mozda cak i bolja M sport...Uvijek slučaj kod BMW-a...puno ljudi je još od E46 mijenjalo "M" ovjes opruge za Eibach Prokit i auti su bili udobniji i bolje se vozili Link to comment Share on other sites More sharing options...
DarioB Posted May 24, 2017 Share Posted May 24, 2017 Eibach Sportline je -30mm? Siguran si? Pa kolko onda spušta Eibach Pro kit? Link to comment Share on other sites More sharing options...
_DEX_ Posted May 24, 2017 Share Posted May 24, 2017 Eibach Sportline je -30mm? Siguran si? Pa kolko onda spušta Eibach Pro kit?Da. Za Yarisa je -30 mm. Ne znam za Pro kit.Sent from my LG-H850 using Tapatalk Link to comment Share on other sites More sharing options...
Ozy Posted May 24, 2017 Share Posted May 24, 2017 Dex ne kukaj vec za tih 200eur sto spominjes uzmi neke low budget gewinde i igraj se ak vec toliko izbjegavas prokit. A te low budget gewinde ce ziher but udobnije od h&r opruga koje su zesci dizastr. Link to comment Share on other sites More sharing options...
MarioST Posted May 24, 2017 Share Posted May 24, 2017 Ja imam eibach -3 i to je super po pitanju udobnosti i voznih osobina. ako oces nize gewinde i nista drugo meni je ovo super kompromis Link to comment Share on other sites More sharing options...
_DEX_ Posted May 24, 2017 Share Posted May 24, 2017 27 minutes ago, Ozy said: Dex ne kukaj vec za tih 200eur sto spominjes uzmi neke low budget gewinde i igraj se ak vec toliko izbjegavas prokit. A te low budget gewinde ce ziher but udobnije od h&r opruga koje su zesci dizastr. Gdje uzet low budget gewinde za 200 eura? Uzimam odmah! Link to comment Share on other sites More sharing options...
JosipZG Posted May 24, 2017 Share Posted May 24, 2017 (edited) uzmi eibach -3cm i vozi se ko čovjek i ne kakaj za tih 0.5cm nisi žena da ti 0.5cm igra neku ulogu @maredo ili netko drugi, pro kit ispadne po visini slično kao "m" ovjes? Edited May 24, 2017 by JosipZG Link to comment Share on other sites More sharing options...
_DEX_ Posted May 24, 2017 Share Posted May 24, 2017 Tebi koji imas viska ne igra 0,5 cm ulogu Nek mi Ozy nade gewinde za 200 eura, uzimam to i bok. Link to comment Share on other sites More sharing options...
JosipZG Posted May 24, 2017 Share Posted May 24, 2017 da i onda ćeš ih u 2 godine morat 4 puta skidat zbog reklamacija ili sranja, ili auto neće nikak držat ili nešto treće bolje uzet dobre opruge nego lošije gewinde Link to comment Share on other sites More sharing options...
Xman Posted May 24, 2017 Share Posted May 24, 2017 1 minute ago, JosipZG said: uzmi eibach -3cm i vozi se ko čovjek i ne kakaj za tih 0.5cm nisi žena da ti 0.5cm igra neku ulogu @maredo ili netko drugi, pro kit ispadne po visini slično kao "m" ovjes? skoro sigurno ga eibach vise spusta nego bilo kakav M ili S ovjes Link to comment Share on other sites More sharing options...
JosipZG Posted May 24, 2017 Share Posted May 24, 2017 fora je u tome da ja ne želim niže od ovoga sada hahahahha ak se dobro sjećam kad sam gledao ima eibach za običan ovjes i eibach za "m", pa možda ovaj za običan dođe taman na visinu kak mi je tvornički sa "m" Link to comment Share on other sites More sharing options...
killuminati Posted May 24, 2017 Share Posted May 24, 2017 ja imam H&R na ionako tvrdom autu i ok, tvrdo je, ali nije neudobno, dapače na otvorenoj cesti i autoputu se odlično ponaša vjerojatno radi progesivne karakteristike kao i eibach, ali da je neka ekstremna razlika u odnosu na eibach, pa baš i nije kak ekipa voli pričat.. meni je auto pao oko 40mm na novim amortizerima, više nego deklarirano..u gradu je malo drugačija priča, na poprečnim neravninama, tračnicama i sl. malo nabija, ali drugo nije za očekivat..na drugi sad ide eibach pa ćemo vidjet.. Link to comment Share on other sites More sharing options...
Xman Posted May 24, 2017 Share Posted May 24, 2017 Ja sam bas rekao Dexu, moj je na HR tvrd ko kurac, ja sam se naviknuo pa recimo da ne primjecujem ali ono kad sam ih namontirao pa se poceo vozit, poludit sam htio. Uzeo bi eibach ali nisu imali DCC compatible pa nisam htio kemijat iako ne znam koja je razlika. Link to comment Share on other sites More sharing options...
Xman Posted May 24, 2017 Share Posted May 24, 2017 Just now, killuminati said: ja imam H&R na ionako tvrdom autu i ok, tvrdo je, ali nije neudobno, dapače na otvorenoj cesti i autoputu se odlično ponaša vjerojatno radi progesivne karakteristike kao i eibach, ali da je neka ekstremna razlika u odnosu na eibach, pa baš i nije kak ekipa voli pričat.. meni je auto pao oko 40mm na novim amortizerima, više nego deklarirano.. u gradu je malo drugačija priča, na poprečnim neravninama, tračnicama i sl. malo nabija, ali drugo nije za očekivat.. na drugi sad ide eibach pa ćemo vidjet.. ja se po autoputu obavezno vozim na comfort postavci jer mi inace na velikim brzinama skace ko koza po nasem losem pokrpanom autoputu Link to comment Share on other sites More sharing options...
killuminati Posted May 24, 2017 Share Posted May 24, 2017 tu i tamo primjetim da lagano poskakuje na dužim pravcima pri brzinama iznad 120, ali nije naporno, zapravo jedva primjetno.. ti imaš i veći kotač s gumom nižeg profila pa je možda zato izraženije.. Link to comment Share on other sites More sharing options...
Juicy Posted May 24, 2017 Share Posted May 24, 2017 13 minutes ago, Xman said: Ja sam bas rekao Dexu, moj je na HR tvrd ko kurac, ja sam se naviknuo pa recimo da ne primjecujem ali ono kad sam ih namontirao pa se poceo vozit, poludit sam htio. Uzeo bi eibach ali nisu imali DCC compatible pa nisam htio kemijat iako ne znam koja je razlika. Tvoj je em više pao nego moj (sa manjim tvornički deklariranim padom), em je udobniji... Imao sam istu dilemu, pro-kit ili sportline, svi rekli sportline, pro-kit je kurac, em ne padne, em je tvrdo... Uzmem sportline, padne auto istina, ali tvrd ko kurac, do točke da se ne želim voziti po rovovima tipa Lučko jer štopam promet... Imao gewinde, nažalost ih prodao dalje, sad mi žao, to je em bilo nisko, em pun kurac udobnije od ovoga. Ljudi kažu da je pro-kit okej kaj se tiče udobnosti (nisam probao), meni sportline nije. Slika je bezveze, ali možda se vidi koliko je pao... Link to comment Share on other sites More sharing options...
scuka Posted May 24, 2017 Share Posted May 24, 2017 sa Vogtlandom nećeš pogriješiti, preko 100 godina se bave oprugama, rade ih i za KW.. jedino kažu da znaju biti mekane u odnosu na eibach i h&r (kaj uopće nije loše ako ne briješ na trkača) Link to comment Share on other sites More sharing options...
BaGy Posted May 24, 2017 Share Posted May 24, 2017 Očigledno sve osim postenog gewinde-a nema smisla... Meni je na golf 4 bio h&r...bio je tvrd i bolje je ležao na cesti od Gewinde-a. Ali su Gewinde bile puno udobnije od opruga...i niže(iako mi to više nije bitno) Link to comment Share on other sites More sharing options...
_DEX_ Posted May 24, 2017 Share Posted May 24, 2017 Ja imam dosta lufta na zadnjem kraju i jaja bi si odgrizao da dam lovu, a ne padne mi dosta. Sent from my LG-H850 using Tapatalk Link to comment Share on other sites More sharing options...
