_DEX_ Posted May 24, 2017 Share Posted May 24, 2017 (edited) A kaj kazete na ovo: http://www.tatechnix.de/tatechnix/gx/product_info.php/info/p33170_ta-technix-sport-suspension-kit-toyota-yaris-type-p1-40-40mm.html Znaci amortizeri+opruge -40mm od TA-tecnixa? Edited May 24, 2017 by _DEX_ Link to comment Share on other sites More sharing options...
Rybak Posted May 24, 2017 Share Posted May 24, 2017 Daj zemi flexu i spili opruge i btk :DSent from my LG-H818 using Tapatalk Link to comment Share on other sites More sharing options...
_DEX_ Posted May 24, 2017 Share Posted May 24, 2017 (edited) @Rybak napokon neka normalna rasprava o autima i dijelovima (ok, ako Yaris mozemo nazvat autom ) i sad se vi zajebavate Edited May 24, 2017 by _DEX_ 1 Link to comment Share on other sites More sharing options...
JosipZG Posted May 24, 2017 Share Posted May 24, 2017 najjeftinije-> odfuraj original opruge u http://www.opruge-omega.hr/kontakt.html i reci kolko hoćeš niže, mislim da mi je rekao nekih 150kn po komadu da ih "stisne" al daj stavi eibach i ne drami više Link to comment Share on other sites More sharing options...
_DEX_ Posted May 24, 2017 Share Posted May 24, 2017 @JosipZG nikakvo rezanje i grijanje. Nema sanse i ne kenjaj Pa kaj ne valja set amortizera i opruga skupa i to taman -40 mm kolko bi me najvise zadovoljilo? I to sve za 1500 kn. Cini mi se ok ponuda. Link to comment Share on other sites More sharing options...
JosipZG Posted May 24, 2017 Share Posted May 24, 2017 nije rezanje i navodno je to potpuno sigurna opcija zagrijat ih i stisnut. nije da čovjek to radi prvi put u životu doma u pećnici Link to comment Share on other sites More sharing options...
_DEX_ Posted May 24, 2017 Share Posted May 24, 2017 5 minutes ago, JosipZG said: nije rezanje i navodno je to potpuno sigurna opcija zagrijat ih i stisnut. nije da čovjek to radi prvi put u životu doma u pećnici Rekao sam rezanje i grijanje da nebi. Rađe kupim opruge ili ovakav set sa amortizerima. Nekak mislim da je jos najbolje ovakav set sa amortizerima koji su i napravljeni za te opruge. I fakat mi se cijena cini sasvim ok za to. Link to comment Share on other sites More sharing options...
Xman Posted May 24, 2017 Share Posted May 24, 2017 7 minutes ago, _DEX_ said: @JosipZG nikakvo rezanje i grijanje. Nema sanse i ne kenjaj Pa kaj ne valja set amortizera i opruga skupa i to taman -40 mm kolko bi me najvise zadovoljilo? I to sve za 1500 kn. Cini mi se ok ponuda. moram ti reci da si faking neodlucan. S Yarisom ne bus isao na Grobnik, dakle kriteriji su ti izgled i donekle osjecaj u voznji. Te gewinde ti sigurno pruzaju bas to i za 1500 kn, kaj imas vise razmisljat? Tko ti moze garantirat da ce ti zadnji kraj pasti tocno koliko hoces, a pricas o 0,5 cm? S gewindama barem znas da ces ga zaserafit kak tebi pase a sve ostalo je nebitno jer pricamo o Yarisu a ne o Poršu 911. Link to comment Share on other sites More sharing options...
killuminati Posted May 24, 2017 Share Posted May 24, 2017 nije rezanje i navodno je to potpuno sigurna opcija zagrijat ih i stisnut. nije da čovjek to radi prvi put u životu doma u pećnici nije da ne može, al je to qurac od posla.. ne preporučam ni pod razno, ovisno o karakteristici žice, može kasnije lakše puknut, nekima auto počne s vremenom tonut, a neujednačenost je izraženija nego s tvorničkom oprugom (nebitno kraća/normalna)..zato se u tvornici žica nakon što prođe termalne procese reže/brusi na krajevima da bi bila ravna.. 1 Link to comment Share on other sites More sharing options...
BaGy Posted May 24, 2017 Share Posted May 24, 2017 3 minutes ago, Xman said: moram ti reci da si faking neodlucan. S Yarisom ne bus isao na Grobnik, dakle kriteriji su ti izgled i donekle osjecaj u voznji. Te gewinde ti sigurno pruzaju bas to i za 1500 kn, kaj imas vise razmisljat? Tko ti moze garantirat da ce ti zadnji kraj pasti tocno koliko hoces, a pricas o 0,5 cm? S gewindama barem znas da ces ga zaserafit kak tebi pase a sve ostalo je nebitno jer pricamo o Yarisu a ne o Poršu 911. to nisu gewinde koliko vidim, vec samo set amortizera i opruga Link to comment Share on other sites More sharing options...
Xman Posted May 24, 2017 Share Posted May 24, 2017 moj bed al poanta ostaje, da mu za konkretnog Yarisa nista bolje/skuplje ne treba Link to comment Share on other sites More sharing options...
_DEX_ Posted May 24, 2017 Share Posted May 24, 2017 @Xman, nisu to gewinde. To je fixni set opruga i amortizera. A dobro, kad kupim Porsche onda cu tu pitat, a do tada ocito moram pitat na forum.hr. Zbilja ne znam kakve veze ima sto pitam za Yarisa. Jebes ti ovo kad na autoforumu ne mogu pitat za savjet oko ovjesa bez obzira jel auto od 2000 ili 200000 eura. Makar sam i samo cekao kad ce netko tako nesto prosrat. Link to comment Share on other sites More sharing options...
Xman Posted May 24, 2017 Share Posted May 24, 2017 Just now, _DEX_ said: @Xman, nisu to gewinde. To je fixni set opruga i amortizera. A dobro, kad kupim Porsche onda cu tu pitat, a do tada ocito moram pitat na forum.hr. Zbilja ne znam kakve veze ima sto pitam za Yarisa. Jebes ti ovo kad na autoforumu ne mogu pitat za savjet oko ovjesa bez obzira jel auto od 2000 ili 200000 eura. Makar sam i samo cekao kad ce netko tako nesto prosrat. odmah skaces kao i obicno, nepotrebno, jasno da trebas pitati ali na trecoj stranici ti i dalje ne bi opruge jer te jebe da li ce past 3.5 ili 4 cm. Ajd mi reci tko ti to moze garantirati? Link to comment Share on other sites More sharing options...
JosipZG Posted May 24, 2017 Share Posted May 24, 2017 nije fora to kaj pitaš za yarisa nego kenjaš već 10 postova a ne znaš ni sam kaj hoćeš i samo ponavljaš brigu o tih 0.5cm gore dole možda od eibacha -3 padne više nego ovaj "-4", dok ne probaš ne možeš znat 100% 1 Link to comment Share on other sites More sharing options...
BM0021 Posted May 24, 2017 Share Posted May 24, 2017 skoro sigurno ga eibach vise spusta nego bilo kakav M ili S ovjesMeni je eibach pro kit 1cm nizi od s line ovjesa. Auto i dalje udoban Link to comment Share on other sites More sharing options...
_DEX_ Posted May 24, 2017 Share Posted May 24, 2017 1 minute ago, JosipZG said: nije fora to kaj pitaš za yarisa nego kenjaš već 10 postova a ne znaš ni sam kaj hoćeš i samo ponavljaš brigu o tih 0.5cm gore dole možda od eibacha -3 padne više nego ovaj "-4", dok ne probaš ne možeš znat 100% Pa da, NE ZNAM! Zato i pokusavam raspravit tu o tome, ali ocito je to bio jako glup potez. Link to comment Share on other sites More sharing options...
_DEX_ Posted May 24, 2017 Share Posted May 24, 2017 (edited) Da je Sassa ovdje pitao za BMW-a ili nesto za Porschea i to na 20 strana onda bi mu pusili kurac, draskali jaja i sigurno mu nebi prigovorili kaj tolko pita. Nisam ja kriv kaj sam sirotinja (ok, djelomicno i jesam sam kriv) i vozim Yarisa. Bas se zato ne zelim zajebat sa oprugama ili bilo cim da ne bacam dvaput lovu ako sa prvom opcijom necu biti zadovoljan! Edited May 24, 2017 by _DEX_ Link to comment Share on other sites More sharing options...
JosipZG Posted May 24, 2017 Share Posted May 24, 2017 (edited) hahahahah baš si cmizdravac 20 ljudi ti je preporučilo eibach (ja više puta, imao sam ga na svim 106 (prokit,) do sad i još su na 106T i sad imam i sportline na AX-u ali to ne bi stavio na auto za cestu) i super sam zadovoljan. i razmišljam o tome da ih stavim na bmw ni Sassi nitko ne bi točno mogao reći, on bi ionako kupio neke od najboljih gewindi ja o ovim TA-technix ne bi ni razmišljao, neovisno o tih 0.5-1-2 cm razlike Edited May 24, 2017 by JosipZG Link to comment Share on other sites More sharing options...
MeaCulpa Posted May 24, 2017 Share Posted May 24, 2017 TA-tecnixa su za bacit u savu Link to comment Share on other sites More sharing options...
Xman Posted May 24, 2017 Share Posted May 24, 2017 (edited) Da je on ovdje pitao nesto za Porsa, rasprava bi isla ovako: Trazim opruge za Porsa. Procitao sam na stranim forumima da model A spusta 3-4 cm, model B spusta 4-5 cm. Da li mi netko moze reci da li koji od ta 2 modela spusta tocno 3,45 cm odnosno 4,45 cm? Ni mm vise ni manje. Prvi odgovor - ne, nitko. Sasaa - ok hvala, dovidjenja. Postova max 5 i to zato jer su neki postali u isto vrijeme.. Dakle da ponovim, mislim po treci puta, NITKO ti ne moze reci da ce ti auto pasti tocno koliko ti zelis pa ni koliko je deklarirano jer je to nemoguce. Tebe jebe 0,5 cm, i kaj sad? Edited May 24, 2017 by Xman Link to comment Share on other sites More sharing options...
x3m Posted May 24, 2017 Share Posted May 24, 2017 Da je Sassa ovdje pitao za BMW-a ili nesto za Porschea i to na 20 strana onda bi mu pusili kurac, draskali jaja i sigurno mu nebi prigovorili kaj tolko pita. Nisam ja kriv kaj sam sirotinja (ok, djelomicno i jesam sam kriv) i vozim Yarisa. Bas se zato ne zelim zajebat sa oprugama ili bilo cim da ne bacam dvaput lovu ako sa prvom opcijom necu biti zadovoljan!Koliki ti je budget za to?Ja bi na tvom mjestu, uzeo eibach - ovaj koji najvise spusta, ne znam jel sportline ili proline, i vozio tako na amortizerima koje imas. Nakon nekog vremena, napravio bi upgrade amortizera na Koni sport i to je top za Yarisa. Gewinde, ak uzmes ove lowbudget sto su cijenom u rangu kvalitetnih opruga, nebus stalno drkao po njima gore dole, nego kad jednom spustis tak bus se i vozio isto kao i u slucaju da auto spustis s oprugama. 1 Link to comment Share on other sites More sharing options...
_DEX_ Posted May 24, 2017 Share Posted May 24, 2017 I kaj je tolki problem kaj je i 3 strane rasprave o bilokakvim oprugama ili bilo kojem drugom dijelu auta? I onda se cudite kad vam ekipa kaze kak se vise raspravlja o ves masinama nego o autima? Kaj je najbolje da je ista kolicina rasprave o usisivacu nebi na kraju ispao ovakav problem. Jebali vas auti na ovakvom forumu. Sad tek vidim da ovdje definitivno nista necu pitat oko turba ili slicnih stvari koji bi volio stavit na Yarisa i mozda cak i budem, ali ovdje sigurno nije mjesto za takve rasprave i pitanja.Sent from my LG-H850 using Tapatalk Link to comment Share on other sites More sharing options...
Xman Posted May 24, 2017 Share Posted May 24, 2017 Just now, _DEX_ said: I kaj je tolki problem kaj je i 3 strane rasprave o bilokakvim oprugama ili bilo kojem drugom dijelu auta? I onda se cudite kad vam ekipa kaze kak se vise raspravlja o ves masinama nego o autima? Kaj je najbolje da je ista kolicina rasprave o usisivacu nebi na kraju ispao ovakav problem. Jebali vas auti na ovakvom forumu. Sad tek vidim da ovdje definitivno nista necu pitat oko turba ili slicnih stvari koji bi volio stavit na Yarisa i mozda cak i budem, ali ovdje sigurno nije mjesto za takve rasprave i pitanja. Sent from my LG-H850 using Tapatalk meni se cini da ces se opet nafuriti i demonstrativno otici, "zauvijek", kao i prosli put al nemoj molim te, evo ajmo i dalje raspravljat o 0,5 cm na oprugama, to je definitivno zanimljivije od bilo kakve vesmasine Link to comment Share on other sites More sharing options...
scuka Posted May 24, 2017 Share Posted May 24, 2017 Zadnji kraj ekipa zna rješavat sa tanjim gumama koje dodu na oprugu (rubber spring pads), dovoljno za tih 0.5 cm 1 Link to comment Share on other sites More sharing options...
BaGy Posted May 24, 2017 Share Posted May 24, 2017 Just now, Xman said: meni se cini da ces se opet nafuriti i demonstrativno otici, "zauvijek", kao i prosli put al nemoj molim te, evo ajmo i dalje raspravljat o 0,5 cm na oprugama, to je definitivno zanimljivije od bilo kakve vesmasine a dobro Xman...kao moderator mislim da se trebas drugacije nositi s ovakvim situacijama... 5 minutes ago, _DEX_ said: I kaj je tolki problem kaj je i 3 strane rasprave o bilokakvim oprugama ili bilo kojem drugom dijelu auta? I onda se cudite kad vam ekipa kaze kak se vise raspravlja o ves masinama nego o autima? Kaj je najbolje da je ista kolicina rasprave o usisivacu nebi na kraju ispao ovakav problem. Jebali vas auti na ovakvom forumu. Sad tek vidim da ovdje definitivno nista necu pitat oko turba ili slicnih stvari koji bi volio stavit na Yarisa i mozda cak i budem, ali ovdje sigurno nije mjesto za takve rasprave i pitanja. Sent from my LG-H850 using Tapatalk DEX...ta technix od 1500kn...mislim da cijena govori za sebe koliko to valja...ali probaj u konacnici, tako ces najbolje vidjeti jel pase 1 Link to comment Share on other sites More sharing options...
