Boky Posted August 20, 2023 Posted August 20, 2023 Ja sam s obicnim uljem skinuo uspjesno smolu prosle godine..
mrva Posted August 23, 2023 Posted August 23, 2023 imas u tokicu sredstvo xa skidanje smole jebenoradi i znas da ne bus nesto sjebo
File Posted August 23, 2023 Posted August 23, 2023 40 minutes ago, mrva said: imas u tokicu sredstvo xa skidanje smole jebenoradi i znas da ne bus nesto sjebo to ti je ovo i fakat radi dobro kako kaze ekipa, ja prosle godine skidao a morat cu i ove ali puno manje https://webshop.tokic.hr/ciscenje-odrzavanje-i-dodatna-oprema/sonax-skidac-smole-i-katrana-300ml-334200/
Oggy Posted August 23, 2023 Posted August 23, 2023 Jesam na kraju s time. Ali trajalo je i uz puuuno trljanja. Ja sam vjerovao da će biti lakše.
Goertosing Posted August 23, 2023 Posted August 23, 2023 2 hours ago, Oggy said: Jesam na kraju s time. Ali trajalo je i uz puuuno trljanja. Ja sam vjerovao da će biti lakše. eto. a ja kad sam govorio da je sonax bezveze, svi me iznapadali ja smolu skidam s Dodo Juice Tarmaladeom: https://dodojuice.net/products/tarmalade-30ml-tar-and-glue-remover-paste-non-drip p.s. pazi ovo na dnu opisa: "*Please note that Tarmalade is definitely NOT edible and should be kept away from children, dogs and idiots." 🤣 uglavnom, namažem malo na smolu, ostavim kratko vrijeme da djeluje, i onda lagano prebrišem mekanom krpom (bez trljanja) ako je dugo stajalo pa se zapeklo, onda prvo poprskam malo sa CarPro tar X, prebrišem i onda tek s Tarmaladeom. S time da i Dodo Juice ima svoju verziju tar X-a koja je isto dobra: https://dodojuice.net/products/tarmageddon-high-performance-citrus-tar-and-glue-remover? 1
Drag_steer Posted September 4, 2023 Posted September 4, 2023 imam keramiku na autu, sad palo nesto smole na njega, s cime da je skinem a da ne zeznem keramiku?
Kroky Posted September 5, 2023 Posted September 5, 2023 Probaj sa nekim tar&glue removerom, ili antisilikonom. Prije par dana skidao nitrom, auto tjedan dana stajao pod drvetom i bas ga natopilo. Keramiku stavljao na taj auto prije 11mj. oslabilo ju je, al nije ubilo do kraja.... I to keramika koja ima trajnost kao 1-2 godine, auto bio pran samo na samoposluznoj bez ikakvih tretmana, topanja itd 1
DiscoVolante Posted September 17, 2023 Posted September 17, 2023 Pozdrav,Koje sredstvo uzeti za dubinsko čišćenje, pumpicu za nanošenje i četku za bušilicu?Uzeo bih usisivač za dubinsko pranje pa da probam kako to funkcionira.
Gabre Posted September 17, 2023 Posted September 17, 2023 Pozdrav,Koje sredstvo uzeti za dubinsko čišćenje, pumpicu za nanošenje i četku za bušilicu?Uzeo bih usisivač za dubinsko pranje pa da probam kako to funkcionira.Oćeš moj savjet? Radije uzmi te novce i plati nekome da ti to odradi.
DiscoVolante Posted September 17, 2023 Posted September 17, 2023 Oćeš moj savjet? Radije uzmi te novce i plati nekome da ti to odradi. Nije nikakav problem, ali uvijek ima nešto po kući za očistiti, 3-4 auta su uvijek tu.Ne vidim zašto ne bi imao nešto što mi je korisno u kući. 1
Gabre Posted September 17, 2023 Posted September 17, 2023 1 hour ago, DiscoVolante said: Nije nikakav problem, ali uvijek ima nešto po kući za očistiti, 3-4 auta su uvijek tu. Ne vidim zašto ne bi imao nešto što mi je korisno u kući. kuzim ja tebe, tako sam i sam mislio, pa na kraju mi to sve stoji i koristio jednom u zadnje 3 godine. Tako sam nakupovao sranja za detailing i na kraju vremena za nista od toga, koliko sam potrosio na sve to sranje, moga sam 4 puta platiti detailing da mi netko drugi odradi.
maredo Posted September 17, 2023 Posted September 17, 2023 Ja sam uzeo Kercher SE 5.100 i non stop je u pogonu...tri auta, namještaj na mokro ili klasično usisavanje...žena ga krade jer je skužila da njen kućni ne vuče qrtza...Lidlov uz malo pažnje nije loš za skoro trećinu cijene...Koristim ovu tekućinu, ok je, napravi sve...kod Brbe sam uzeo mekšu rotacionu četku i udaram.. 2
DiscoVolante Posted September 25, 2023 Posted September 25, 2023 Odradio svoj auto i kućnu garnituru, jako dobro. Koristio isto Lava Interni tekućinu, samo zelenu, i vruću vodu u usisivaču.Naravno da nije na profesionalnoj razini, ali kad vidiš kakva voda izaÄ'e iz spremnika, definitivno bi svake godine trebalo proÄi siceve i auto opÄenito.... 4
Vila Posted October 11, 2023 Posted October 11, 2023 uzeo sam ovaj set https://ph-detailing.hr/proizvod/set-za-odrzavanje-stakla/jel stavljao ko već? koji je postupak?naša san samo jedan klip na YT di se stavi premaz pa se prebriše sa mikrofibrom
Oggy Posted October 11, 2023 Posted October 11, 2023 Opereš dobro dobro staklo, na neku krpicu našpricaš angela i premažeš cijelo staklo. Ne trebaš na debelo nego jednostavno premazati. Vidjeti ćeš sredstvo po staklu. Pričekaš 10tak minuta i sa čistom krpom prebrišeš cijelo staklo do fine čistoće. Znači ne smije ostati nikakvih tragova po staklu. Nemoj raditi po direktnom suncu i biraj trenutak da ti baš ne padne odmah kiša ili vlaga da se sve dobro "zapeče". Ja sam tako već 6 puta svoje premazao i nije bilo problema. 1
Oggy Posted October 12, 2023 Posted October 12, 2023 (edited) Cca pola godine. Makar efekta mi je bilo i nakon godinu dana, ali ne onakvog intenziteta kao na početku. S time da ne očekuj čuda. Meni do cca 90kmh na oba auta baš ne pomaže odnosno moram upaliti brisače da imam dobro preglednost. Tek na tim većim brzinama počnu se okrupnjivat kapljice i sklizati sa stakla te time dobiješ preglednost kakvu očekuješ. Vidim u onom paketu da si dobio aplikator https://ph-detailing.hr/proizvod/ewocar-microfiber-applicator-aplikator-od-mikrofibre/. S time si premaži staklo sa angelom. Edited October 12, 2023 by Oggy 1
Unknown Posted October 13, 2023 Posted October 13, 2023 Preporuka za sredstvo za skidanje musica i kukaca? svakodnevno sam na AC i nakupi se toga. Trenuton koristim od sonaxa Sonax Insect Star, ali to mi je tako tako.
robert Posted October 13, 2023 Posted October 13, 2023 43 minutes ago, Unknown said: Preporuka za sredstvo za skidanje musica i kukaca? svakodnevno sam na AC i nakupi se toga. Trenuton koristim od sonaxa Sonax Insect Star, ali to mi je tako tako. Dimer 🙂 1
Pavo Posted October 13, 2023 Posted October 13, 2023 Dimer Vrhunska stvar.. ali pripazi na omjer miješanja s vodom.Te mušice operite s vrećom od krumpira (onom mrežastim, plastičnom) ne šteti laku a skida to smeće. 2 čepa na 0.5L istrljat i za 1-2min isprati s vodom i obavezno poslje šampon da ne bi prošao kao ja. Poslano s mobitela koristeci Tapatalk
Srele_St Posted October 13, 2023 Posted October 13, 2023 Preporuka za sredstvo za skidanje musica i kukaca? svakodnevno sam na AC i nakupi se toga. Trenuton koristim od sonaxa Sonax Insect Star, ali to mi je tako tako.https://ph-detailing.hr/proizvod/fx-protect-bug-remover-sredstvo-za-uklanjanje-kukaca/Ja koristim ovog na preporuku brbe.Potrošio sam vec par kanti po 5L i jako sam zadovoljan.Poslano sa mog M2007J3SY koristeći Tapatalk
MKmarino Posted October 14, 2023 Posted October 14, 2023 Da, mislim da sam i ja uzeo ovog za probu, i dobar je.
DiscoVolante Posted October 27, 2023 Posted October 27, 2023 Jedno pitanje, čime je najlakše odstraniti masne tragove prstiju sa vanjske strane vrata? Hvala.
maredo Posted October 28, 2023 Posted October 28, 2023 Jedno pitanje, čime je najlakše odstraniti masne tragove prstiju sa vanjske strane vrata? Hvala.Možda apc na meku krpu? 1
Gabre Posted October 28, 2023 Posted October 28, 2023 Jedno pitanje, čime je najlakše odstraniti masne tragove prstiju sa vanjske strane vrata? Hvala.Tekućinom za suÄ'e prati. Bez zajebancije. 1
