KIMI_1.8T Posted January 3, 2013 Posted January 3, 2013 dali ce taj stariji kabel raditi na vcdsu ili samo na vag com? dali auto 2004tu mozes preko vcdsa? Vag Com je VCDS ( Vag Com Diagnostic System )
Luky Posted January 3, 2013 Author Posted January 3, 2013 zašto mi na golfu 3 neće da očita km? nije vrag da su skidani?
Pekx Posted January 3, 2013 Posted January 3, 2013 (edited) Jer na golfu 3 kilometri ne pisu u ECU nego samo u satu. Od mk4 na dalje se kilometri nalaze na dva mjesta, makar i to nije sasvim tocno. Edited January 3, 2013 by Pekx
Luky Posted January 3, 2013 Author Posted January 3, 2013 Jer na golfu 3 kilometri ne pisu u ECU nego samo u satu.Od mk4 na dalje se kilometri nalaze na dva mjesta, makar i to nije sasvim tocno. aha.. a normalno, onaj ko skida, skinut ce i iz ecu-a..
Pekx Posted January 3, 2013 Posted January 3, 2013 aha.. a normalno, onaj ko skida, skinut ce i iz ecu-a.. 90% skinutih u hr skida samo sa sata. Ok, mozda sam malo pretjerao, ali nisam daleko. A svaki mk3 ako nema total je presao najmanje 300 000.
Luky Posted January 3, 2013 Author Posted January 3, 2013 90% skinutih u hr skida samo sa sata. Ok, mozda sam malo pretjerao, ali nisam daleko. A svaki mk3 ako nema total je presao najmanje 300 000. ma nema mk4 ispod 300 000, kamoli mk3..
mariotdi Posted January 3, 2013 Posted January 3, 2013 90% skinutih u hr skida samo sa sata. Ok, mozda sam malo pretjerao, ali nisam daleko. A svaki mk3 ako nema total je presao najmanje 300 000. mislis na mk3 ili opcenito...kod mene su skinuti svuda, svud pise isto a znam da nisu pravi km...sve ovisi tko skida i kolko plati inace i meni stize vcds...jel se mogu kilometri skidat preko tog?:showoff:
pacey Posted January 3, 2013 Posted January 3, 2013 ma nema mk4 ispod 300 000, kamoli mk3.. Sad kad si ju proda jel
Luky Posted January 3, 2013 Author Posted January 3, 2013 Sad kad si ju proda jel ja nisam skidao, nit bi.. a ako je tko prije mene, nemam pojma.. dobro je palio, dobro išao, nije ulje trošio.. tako da je to bitno.. @ mario tdi: ma može, napisat cu ti ja da imaš 50 000 km, i odem na tehnički i tamo obrišem.. LOL..
Luky Posted January 3, 2013 Author Posted January 3, 2013 to bi bilo dobro :rofl: nije problem.. kompenzirat ćemo.. :lol:
Luky Posted January 3, 2013 Author Posted January 3, 2013 Ima netko za Opel dijagnostiku? šic van iz ove teme sa opelom.. :lol: još će nam se što pokvarit kad spomeneš opel.. :lol: ima pavičić sigurno..
J.J Posted January 3, 2013 Posted January 3, 2013 šic van iz ove teme sa opelom.. :lol: još će nam se što pokvarit kad spomeneš opel.. :lol: ima pavičić sigurno.. Čuti bre...i OPEL-e treba popraviti...njima je to potrebnije...
Luky Posted January 3, 2013 Author Posted January 3, 2013 Evo 2 greške.. Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl Part No SW: 3C0 937 049 E HW: 3C0 937 049 E Component: Bordnetz-SG H37 1002 Revision: 00H37000 Serial number: 00000003651291 Coding: 8B8A8F2F00041000001D00000000000000007F075C Shop #: WSC 06441 785 00200 VCID: 2B5F19758A1E111 Subsystem 1 - Part No: 1P0 955 119 A Labels: 1KX-955-119.CLB Component: Wischer SE350 012 0403 Coding: 00056272 Shop #: WSC 06441 1 Fault Found: 01504 - Bulb for License-Plate Light (X) 012 - Electrical Fault in Circuit - Intermittent Freeze Frame: Fault Status: 00101100 Fault Priority: 2 Fault Frequency: 4 Reset counter: 14 Mileage: 160422 km Time Indication: 0 Freeze Frame: ON Voltage: 11.25 V ON ON OFF OFF ON Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX2.lbl Part No: 1T0 959 701 C Component: Tuer-SG 024 2451 Coding: 0000176 Shop #: WSC 06441 785 00200 VCID: 377735054656A51 1 Fault Found: 00100 - Drivers Interior Locking Button (E308) 008 - Implausible Signal - Intermittent Ova druga je mikroprekidač u vratima, jel? Nisam skužio da nešto zajebava il slično..
Dario Posted January 3, 2013 Posted January 3, 2013 Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX2.lblPart No: 1T0 959 701 C Component: Tuer-SG 024 2451 Coding: 0000176 Shop #: WSC 06441 785 00200 VCID: 377735054656A51 1 Fault Found: 00100 - Drivers Interior Locking Button (E308) 008 - Implausible Signal - Intermittent Ova druga je mikroprekidač u vratima, jel? Nisam skužio da nešto zajebava il slično.. prekidac za ulock/lock u autu te zeza
Luky Posted January 4, 2013 Author Posted January 4, 2013 Da, to sam i mislio.. Al nisam skuzio da zeza.. Al ova prva sto je?
Dario Posted January 4, 2013 Posted January 4, 2013 pa pise ti :haha: krepala ti je zaruljica od tablice ili je oslabila
Luky Posted January 4, 2013 Author Posted January 4, 2013 Ajme kretena.. :doh: promjenuo sam obadvije, i ne racunam da moze nju izbacit.. EPIC.. hahahahha..
Roby Posted January 5, 2013 Posted January 5, 2013 Trebao bih iskljucit automatska kratka svjetla na Golfu 5? ) Malo me frka radit to kodiranje...sta se moze najgore desit?! hehe Imam Launch Diagun...idem u long coding, pojavi se tablica i kada stisnem OK, pita me dali sam siguran da zelim to! I mene frka dalje hehe
Dario Posted January 5, 2013 Posted January 5, 2013 najgore je sto moze bacit gresku nepravilno kodiranje
