DarioB Posted March 17, 2018 Posted March 17, 2018 41 minutes ago, Hic said: 318 GT za francusko trziste Evo nesto ljepse Proradio metanol injection, jos samo novi ecu i volan/abs Ili ovako nesto, 420 GC 163->242 Kak 163 na 242KS? 41 minutes ago, Hic said: 318 GT za francusko trziste Evo nesto ljepse Proradio metanol injection, jos samo novi ecu i volan/abs Ili ovako nesto, 420 GC 163->242 Kak 163 na 242KS?
DarioB Posted March 17, 2018 Posted March 17, 2018 @hic nisam mislil da lazes, nego pitam dalje to dobiveno samo mapiranjem ili je jos nekaj mjenjano? 730D F01 245 KS, kolko se tu moze dobit mapiranjem?
dcrnic Posted March 17, 2018 Posted March 17, 2018 Fora izgleda ova corsica... na ovim felgama ubijena u pod i u ovoj boji... 1
Hic Posted March 17, 2018 Author Posted March 17, 2018 @hic nisam mislil da lazes, nego pitam dalje to dobiveno samo mapiranjem ili je jos nekaj mjenjano? 730D F01 245 KS, kolko se tu moze dobit mapiranjem?Samo mapa, ali auto je 40000km.Ovaj 730d do nekih 285-295ks mislim. Ovisi o dpf-u najvise.
GoranE46 Posted March 18, 2018 Posted March 18, 2018 Samo mapa, ali auto je 40000km.Ovaj 730d do nekih 285-295ks mislim. Ovisi o dpf-u najvise.I auto je b47 motor koji se dize jace od n47Isti motor kao 190ks smanjen tvornicki jer je neko xy trziste vjerovatnoSent from my iPhone using Tapatalk
TomiTraktor Posted March 18, 2018 Posted March 18, 2018 I auto je b47 motor koji se dize jace od n47Isti motor kao 190ks smanjen tvornicki jer je neko xy trziste vjerovatnoSent from my iPhone using TapatalkKak se B47 jace dize?Vidio sam 150-200 za B47 pa mi se ucinilo malo optimističnoSent from my Moto X4
GoranE46 Posted March 18, 2018 Posted March 18, 2018 Kak se B47 jace dize?Vidio sam 150-200 za B47 pa mi se ucinilo malo optimističnoSent from my Moto X4B47 u 20d varijanti je stock 190ksSent from my iPhone using Tapatalk
TomiTraktor Posted March 18, 2018 Posted March 18, 2018 B47 u 20d varijanti je stock 190ksSent from my iPhone using TapatalkZnam to, pricam o 18d gdje sam vidio da dizu sa 150 na 200 (za stock aute sandpfom), a N47 je negdje isao 143 na 185 sa dpfomSent from my Moto X4
GoranE46 Posted March 18, 2018 Posted March 18, 2018 Znam to, pricam o 18d gdje sam vidio da dizu sa 150 na 200 (za stock aute sandpfom), a N47 je negdje isao 143 na 185 sa dpfomSent from my Moto X4Tako je, sve tocnoB motori idu visePa eto ti usporedbe isti tuner isti valjci n vs b u startu isto, na kraju 20ks vise B motorSent from my iPhone using Tapatalk
darko_st Posted March 18, 2018 Posted March 18, 2018 12 hours ago, GoranE46 said: I auto je b47 motor koji se dize jace od n47 Isti motor kao 190ks smanjen tvornicki jer je neko xy trziste vjerovatno Po vin-u je 140kw/190ks. http://bimmer.work/vin/85acf4c73020c4b9183459c3c9013364/
marin2405 Posted March 18, 2018 Posted March 18, 2018 Mislim da je to belgijski trziste s tim smanjenim konjima, nesto kao a6 2.0 190ks u hr, tam 150.
GoranE46 Posted March 18, 2018 Posted March 18, 2018 Po vin-u je 140kw/190ks. http://bimmer.work/vin/85acf4c73020c4b9183459c3c9013364/Stavka opreme 843. Iskodiras van i imas 190 Sent from my iPhone using Tapatalk
Kevin Posted March 26, 2018 Posted March 26, 2018 (edited) Za koji to Evo bullet Billet block?? dobra stvar a samo 29kg. Edited March 26, 2018 by Kevin
ND4SPD Posted March 26, 2018 Posted March 26, 2018 Ne vidim dobro na slikama, jesu to Carillo klipnjace? Kako to da ste isli na H-beam?
Hic Posted March 26, 2018 Author Posted March 26, 2018 Jer su najbolje. Znam da ce teoreticari poceti sa I beam turbo tuff bla bla bla..Bullshit. Carrillo je BOG za klipnjace i kazu da je H bolje od I. The end
ND4SPD Posted March 26, 2018 Posted March 26, 2018 15 minutes ago, Hic said: Jer su najbolje. Znam da ce teoreticari poceti sa I beam turbo tuff bla bla bla.. Bullshit. Carrillo je BOG za klipnjace i kazu da je H bolje od I. The end Tim Radley se ne slaze, the end
