Pekx Posted June 23, 2019 Share Posted June 23, 2019 Helou, trazim kombinaciju ili alternativu za Ferodo DS2500 koja ne skripi, a koci donekle dobro. Treba mi za 7R celjusti koje su same po sebi jako dobre. Ds2500 skripi u svim dosad vidjenim kombinacijama i dosta je iritantno za svakodnevnu voznju. Tnx Link to comment Share on other sites More sharing options...
Iggy_R Posted June 23, 2019 Share Posted June 23, 2019 5 4 Link to comment Share on other sites More sharing options...
BaGy Posted June 23, 2019 Share Posted June 23, 2019 34 minutes ago, Pekx said: Helou, trazim kombinaciju ili alternativu za Ferodo DS2500 koja ne skripi, a koci donekle dobro. Treba mi za 7R celjusti koje su same po sebi jako dobre. Ds2500 skripi u svim dosad vidjenim kombinacijama i dosta je iritantno za svakodnevnu voznju. Tnx Clubsport S diskovi i plocice https://shop.ahw-shop.de/original-vw-golf-7-clubsport-bremsscheiben-340x30-bremsen-1lj-1lk-vorne-5q0615301c Link to comment Share on other sites More sharing options...
Dario Posted June 23, 2019 Share Posted June 23, 2019 (edited) 17 minutes ago, BaGy said: Clubsport S diskovi i plocice https://shop.ahw-shop.de/original-vw-golf-7-clubsport-bremsscheiben-340x30-bremsen-1lj-1lk-vorne-5q0615301c zivo smece za 4000 km. L i D su isti. jedan se uvijek vise grije i warpa kao TTRS 8j i samo je pitanje vremena kad protrese Edited June 23, 2019 by Dario Link to comment Share on other sites More sharing options...
KIMI_1.8T Posted June 23, 2019 Share Posted June 23, 2019 32 minutes ago, Dario said: zivo smece za 4000 km. L i D su isti. jedan se uvijek vise grije i warpa kao TTRS 8j i samo je pitanje vremena kad protrese Istina. Zato kupis ovo i miran si 2 Link to comment Share on other sites More sharing options...
krule Posted June 23, 2019 Share Posted June 23, 2019 ja ne znam kakve vi to DS2500 kupujete, ali meni nikad nisu zaškripale ili zacvilile, ni na suhom, niti mokrom.. RPB trkači diskovi 282mm na Civicu Link to comment Share on other sites More sharing options...
Uros Posted June 23, 2019 Share Posted June 23, 2019 Ds2500 ne cvile Ds uno koce cudo jedno,ali isto tako cvile,bruje.... Link to comment Share on other sites More sharing options...
kutija Posted June 23, 2019 Share Posted June 23, 2019 pagid blue Link to comment Share on other sites More sharing options...
klosar Posted June 23, 2019 Share Posted June 23, 2019 Ja imam na 7R ds2500 i ne cvili nista Link to comment Share on other sites More sharing options...
Rwd Posted June 23, 2019 Share Posted June 23, 2019 Meni na Bmw-u e93 ds2500 cvili za popizdit,kao da se vlak zaustavlja.Najgore je netom prije stajanja kad lagano stišćem kočnicu.Jos kad je krov gore i neka glazbica pa izgubim dojam koliko je glasno ali kad spustim krov i kad čujem koliko cvili,majke mi bude me sramota kad pokraj ljudi moram usporavat.Jedva čekam da ih potrošim i stavim neke druge pločice,nek i malo lošije koče samo da mi više ne cvile jer cu izludit Link to comment Share on other sites More sharing options...
ND4SPD Posted June 23, 2019 Share Posted June 23, 2019 DS2500 bi u principu trebale biti tihe, ali ocigledno ne odgovaraju nekim celjustima... Imao sam dva seta na dva razlicita auta i bile su skroz tihe... Mozete probati sa pastom protiv cviljenja plocice, zapravo dovoljna je i obicna bakrena mast koja se stavi iza na plocicu... Ili ih jednostavno zagrijete/zapalite sa par jacih kocenja, dakle slican proces kao kod bedding-in-a, nakon toga bi jedno vrijeme trebale biti tihe... 1 Link to comment Share on other sites More sharing options...
Rwd Posted June 23, 2019 Share Posted June 23, 2019 40 minutes ago, ND4SPD said: DS2500 bi u principu trebale biti tihe, ali ocigledno ne odgovaraju nekim celjustima... Imao sam dva seta na dva razlicita auta i bile su skroz tihe... Mozete probati sa pastom protiv cviljenja plocice, zapravo dovoljna je i obicna bakrena mast koja se stavi iza na plocicu... Ili ih jednostavno zagrijete/zapalite sa par jacih kocenja, dakle slican proces kao kod bedding-in-a, nakon toga bi jedno vrijeme trebale biti tihe... I ja sam mislio da su tihe a dobre zato sam ih kupio,ali očito ne odgovaraju nekim čeljustima i moš se slikat.Da ih nisam platio 300 eura odavno bi ih skinuo,mislim da cu iduci put probati sa Hawk hps 5.0... Btw očisti inbox Link to comment Share on other sites More sharing options...
ND4SPD Posted June 23, 2019 Share Posted June 23, 2019 24 minutes ago, Rwd said: Btw očisti inbox Sorry, preko tapatalka sam odgovarao, tek sad vidim poruku 1 Link to comment Share on other sites More sharing options...
Pekx Posted June 26, 2019 Author Share Posted June 26, 2019 On 6/23/2019 at 11:21 PM, ND4SPD said: DS2500 bi u principu trebale biti tihe, ali ocigledno ne odgovaraju nekim celjustima... Imao sam dva seta na dva razlicita auta i bile su skroz tihe... Mozete probati sa pastom protiv cviljenja plocice, zapravo dovoljna je i obicna bakrena mast koja se stavi iza na plocicu... Ili ih jednostavno zagrijete/zapalite sa par jacih kocenja, dakle slican proces kao kod bedding-in-a, nakon toga bi jedno vrijeme trebale biti tihe... Prije bi rekao da ne odgovaraju svim diskovima. Koje diskove predlazete na DS2500? Link to comment Share on other sites More sharing options...
ND4SPD Posted June 26, 2019 Share Posted June 26, 2019 1 hour ago, Pekx said: Prije bi rekao da ne odgovaraju svim diskovima. Koje diskove predlazete na DS2500? Nije do diskova... Eventualno ako su ostavile sloj na diskovima, ali onda bi ti tresli... Link to comment Share on other sites More sharing options...
BaGy Posted June 26, 2019 Share Posted June 26, 2019 Ima netko iskustva sa Tarox Corsa 114? Link to comment Share on other sites More sharing options...
ND4SPD Posted June 26, 2019 Share Posted June 26, 2019 7 minutes ago, BaGy said: Ima netko iskustva sa Tarox Corsa 114? Mislim da Ferodo radi plocice za njih, Corsa 114 bi mogle biti upravo DS2500. 1 Link to comment Share on other sites More sharing options...
krule Posted June 26, 2019 Share Posted June 26, 2019 2 hours ago, Pekx said: Prije bi rekao da ne odgovaraju svim diskovima. Koje diskove predlazete na DS2500? ja bi to isto rekao, jesu one dosta mekane, ali su i dosta agresivne, čuo sam da su nekima doslovce pojeli diskove Link to comment Share on other sites More sharing options...
robert Posted June 26, 2019 Share Posted June 26, 2019 Ja sam imao DS2500, tihe kočile na hladno super, nisu satrale diskove....vrijedile su svaku lipu Sa taroxom su iskustva bila užas Link to comment Share on other sites More sharing options...
Exfreerider Posted June 26, 2019 Share Posted June 26, 2019 2 hours ago, ND4SPD said: Mislim da Ferodo radi plocice za njih, Corsa 114 bi mogle biti upravo DS2500. Da tako se nešto šuška DS2500 vrhunska pločica upotrebljiva za svaki dan a može odraditi i track day 1 Link to comment Share on other sites More sharing options...
Mario_S3 Posted June 26, 2019 Share Posted June 26, 2019 (edited) DS2500 na mom autu nikad zacvilile, niti najmanje, auto vožen u svim mogućim uvjetima - iste pločice sam imao na stock TTRS diskovima i sada na AP Racing diskovima. Edited June 26, 2019 by Mario_S3 Link to comment Share on other sites More sharing options...
Raptor6767 Posted June 27, 2019 Share Posted June 27, 2019 DS2500 na mom autu nikad zacvilile, niti najmanje, auto vožen u svim mogućim uvjetima - iste pločice sam imao na stock TTRS diskovima i sada na AP Racing diskovima. Tak i kod mene na Cliu. Imaju nekih 40.000km sad. S time da je auto stajao gotovo godinu dana od prošle vožnje, u protekla 3 dana napravili 500tinjak km u svakakvim uvjetima - ne cvili nimalo. Uzeo sam si DSUno za prednje i DS2500 za stražnje na Meganeu sad. Montaža slijedi pošto su OEM još dobre. 2 Link to comment Share on other sites More sharing options...
Pekx Posted June 27, 2019 Author Share Posted June 27, 2019 Na prijedlog @Raptor6767 i iskustvom nekoliko daily trackdayaša, uzeo sam kombinaciju ATE Power Disc i DS2500. Vidjet ćemo, dovoljno sam lud da vrtim kombinacije diskova i pločica dok ne pogodim. 1 Link to comment Share on other sites More sharing options...
BaGy Posted June 27, 2019 Share Posted June 27, 2019 mozda glupo pitanje, senzor za istrosenost se naknadno kupuje za ds2500? Link to comment Share on other sites More sharing options...
Dario Posted June 27, 2019 Share Posted June 27, 2019 1 hour ago, BaGy said: mozda glupo pitanje, senzor za istrosenost se naknadno kupuje za ds2500? nema ga barem ne za 7R/cupra celjusti 1 1 Link to comment Share on other sites More sharing options...
