444IN Posted April 18, 2017 Posted April 18, 2017 Ma nije samo kad se nagnes pod dobro svijetlo se vidi fleka ak pogledas direkt odozgo cak i iz blizu ne vidi se, Golf 7.Sent from my ONEPLUS A3003 using Tapatalk
Tomica93 Posted April 18, 2017 Posted April 18, 2017 Mislim da ne treba dalje, naravno odma nakon pranjaSent from my iPhone using Tapatalk
_DEX_ Posted April 18, 2017 Posted April 18, 2017 Tebi krave lete po drvecu? Sent from my LG-H850 using Tapatalk
Tomica93 Posted April 18, 2017 Posted April 18, 2017 ne znam sta je to bilo, ali jedini put u tolkoj "kilaži"
ZaX Posted April 19, 2017 Posted April 19, 2017 Offtopic dio Ontopic - vosak ti neće pomoći kod kemija koje se nalaze u kakici, za to ti treba keramički premaz. Šajo je dobar detailer i ako se može izvući bude ti on to napravio. Na Partes FB stranici imaš galeriju slika sa raznim vrstama oštećenja laka te kako se saniraju.
444IN Posted April 19, 2017 Posted April 19, 2017 A vidim sad da ne pomaze, mislim nije mi prvi put ptica pokeljala auto ali ovo da ovak ostane jos nisam imo. Zvao sam ga jucer bas kaze moralo bi se dat napravit pogotovo jer nije to sad probilo nist samo se vidi pod kutem fleka cak ak pogledas iz blizu onak odozgo ne vidis nis. Sent from my ONEPLUS A3003 using Tapatalk 1
Rockatansky Posted April 19, 2017 Posted April 19, 2017 Tebi krave lete po drvecu? Sent from my LG-H850 using TapatalkNije se tebi galeb posrao po autu, e to da vidis Poslano sa mog SM-G930F koristeći Tapatalk
Mattas Posted April 19, 2017 Posted April 19, 2017 Ako ti je Šajo blizu, kamo si ti. Ja sam u okolici Labina pa ako hoćeš nazovi pa da vidimo da li se može rješiti. 091 895 2584
brba Posted April 21, 2017 Posted April 21, 2017 Sonax 04/06 ( hauba na sonax cutmax ) Sonax pns Sent from my iPhone using Tapatalk 2
Damba Posted April 22, 2017 Posted April 22, 2017 Vrhunski, i ja sam prešao na sonax Poslano sa mog SM-G930F koristeći Tapatalk
brba Posted April 22, 2017 Posted April 22, 2017 Meni je 04/06 top vec dugo , stvarno vrhunska one step Zanimaju me sam kakve su od gyeona paste Sent from my iPhone using Tapatalk
Gabre Posted April 22, 2017 Posted April 22, 2017 Jedan prijelaz i onda vosak i to je to? Moram uzet. Sent from my Pixel XL using Tapatalk 1
brba Posted April 22, 2017 Posted April 22, 2017 Neces izvuc sve al ima jako solidan cut i odlican finish , moze se dugo radit sa njom .... uzitak za radit.. kupis si malu od 250ml i imas za svoje potrebe dosta Nisam jos isprobao novu 05-05 , al navodno valja Kupis sonax 04/06 , sonax zuti pad za DA , sonax pns ili npt i to je sve kaj ti treba za odradit korektan posao Sent from my iPhone using Tapatalk 3
Gabre Posted April 22, 2017 Posted April 22, 2017 Aj budem narucio, chemical guys v34 i v36 nista ne naprave. Malo zasjaje, ali sve imalo ozbiljinji swirlowi i ogrebotine ostaju. To je ovo? Sonax (242141) Profiline EX 04-06 - 8.45 fl. oz. https://www.amazon.ca/dp/B00KBT64QY/ref=cm_sw_r_cp_apa_qrb.yb2NWF72W
brba Posted April 23, 2017 Posted April 23, 2017 Gabre to je to Jos ovo za zastitu i amen https://www.amazon.ca/gp/aw/d/B01L1UFJ9E/ref=mp_s_a_1_3?ie=UTF8&qid=1492943270&sr=8-3&pi=AC_SX236_SY340_QL65&keywords=Sonax+polymer&dpPl=1&dpID=41zexceBYyL&ref=plSrch Radi sa rotacijom isto dobro Sent from my iPhone using Tapatalk 1
Gabre Posted April 23, 2017 Posted April 23, 2017 Super, bas cu uzet, imam DA porter cable polirku. Jel mogu proc od Chemical guysa padovi, imam ih svih boja narancaste, bijele, crneSent from my Pixel XL using Tapatalk
danijels2006 Posted April 25, 2017 Posted April 25, 2017 (edited) Felge odrađene Gyeon Rim-om Prije same zaštite pranje,pa glina te odmascivanje.... Gyeon Bathe+ vrhunski šampon koji nakon prvog pranja stvara vrhunsku hidrofobnost laka... Gesendet von iPhone mit Tapatalk Pro Edited April 25, 2017 by danijels2006 1
Gabre Posted April 27, 2017 Posted April 27, 2017 On 4/22/2017 at 11:26 AM, Damba said: Vrhunski, i ja sam prešao na sonax Poslano sa mog SM-G930F koristeći Tapatalk On 4/22/2017 at 5:39 PM, brba said: Neces izvuc sve al ima jako solidan cut i odlican finish , moze se dugo radit sa njom .... uzitak za radit.. kupis si malu od 250ml i imas za svoje potrebe dosta Nisam jos isprobao novu 05-05 , al navodno valja Kupis sonax 04/06 , sonax zuti pad za DA , sonax pns ili npt i to je sve kaj ti treba za odradit korektan posao Sent from my iPhone using Tapatalk danas totalnom slucajnoscu nadjem ovaj ducan http://prodetailingsupplies.ca/ htio stat u chemical guys i trazim na google maps di je na karti i medju ostalim tockama interesa primijetim Pro detailing supplies, tako da nisam ni stigao u Cguys imaju sve od Sonax-a, meguiarsa, griots, dr beasleys (nikad cuo iskreno), uglavnom profi opremu, a i gazda je bivsi detailer i bas se kuze. Imaju i taj sonax 04-06 i preporucava mi za vece ogrebotine Sonax cutmax ili tako nesto se zove. A i nesto novo mi je pokazao, keramiku od sonaxa, navodno traje dugo, i da je dovoljno jednom dvaput godisnje osvjezit samo sa PNS-om od sonaxa.
brba Posted April 27, 2017 Posted April 27, 2017 Keramika je navodno odlicna Cutmax je vrrrhunska pasta , jaako dobar cut i odlican finish Eo ga u akciji Sent from my iPhone using Tapatalk
Gabre Posted April 27, 2017 Posted April 27, 2017 za 40$ dobijem 250ml cutmaxa i 250ml 04 06, tj, nekih 200kn. padove imam od Cguysa, narancastu i bijelu i crnu sad sam nabrijan da uzicam od zene jedan dan da odradim sve, malo ce biti teze, curice oce van svaku sekundu kad je lijepo. A obozavaju i samnom raditi bilo sto oko auta
Nicol Posted April 29, 2017 Posted April 29, 2017 Koji nano premaz za sajbe uzet i gdje? Jel to "tesko" za nanijeti?
