msporis Posted September 30, 2019 Posted September 30, 2019 (edited) Kakve alu felge, to su čeličane sa ratkapom, BMK kak izgleda, samo nek vozi Edited September 30, 2019 by msporis
Gabre Posted September 30, 2019 Posted September 30, 2019 On 30. 09. 2019. at 13:18, Srele_St said: Ja sam ih radio more i svi su bili 195/55 iako i stom gumom izgledaju glupo na oem felgama mogu mislit kako bi mu stala 205/55 na 6j felgu.Poslano sa mog Redmi Note 7 koristeći Tapatalk205 55 16 izgleda sasvim normalno na 6J felgi
_DEX_ Posted September 30, 2019 Posted September 30, 2019 Ovo je 195/55R16 na oem felgi.Sent from my JSN-L21 using Tapatalk
Rockatansky Posted October 1, 2019 Posted October 1, 2019 On 28. 09. 2019. at 20:47, Srele_St said: Napisi do koliko si spreman ic pa cemo smislit nesto bolje od klebera.Poslano sa mog Redmi Note 7 koristeći TapatalkDo cca. 600kn sa montažom, a i onim tvojim felgama ćemo popričati
Srele_St Posted October 1, 2019 Posted October 1, 2019 Felge su prodane a sta se tice zimskih guma onda cemo blizak lm005. Samo mi se javi malo prije da ti pripremin set. Poslano sa mog Redmi Note 7 koristeći Tapatalk 1
tigar_87 Posted October 1, 2019 Posted October 1, 2019 Hans Getrude na fejsu vidim da ima felge svakakve i gume zimske, možda on ima ok cijene? Čisto samo predlažem, nisam uspoređivao
viktor04 Posted October 9, 2019 Posted October 9, 2019 Vredestein Wintrac Pro ili Nokian Wr A4? Vidim po testovima da hvale dosta pa sam malo neodlučan kaj uzet
Vlado206 Posted October 9, 2019 Posted October 9, 2019 Ja bi A4, sa D4 sam išao s Platka gore u šumu prema Risnjaku.
ND4SPD Posted October 9, 2019 Posted October 9, 2019 On 09. 10. 2019. at 18:24, viktor04 said: Vredestein Wintrac Pro ili Nokian Wr A4? Vidim po testovima da hvale dosta pa sam malo neodlučan kaj uzet Expand WR A4 je sportski orijentirana zimska, WR D4 je vise za snijeg... Ne znam za ovaj Vredestein Wintrac Pro...
robi Posted October 9, 2019 Posted October 9, 2019 Fulda montero 3 ili sava s3+ za clio 3... Mislim si da je tak svejedno jer auto nejde iz grada, ali da pitam reda radi ?
maredo Posted October 9, 2019 Posted October 9, 2019 On 09. 10. 2019. at 19:36, robi said: Fulda montero 3 ili sava s3+ za clio 3... Mislim si da je tak svejedno jer auto nejde iz grada, ali da pitam reda radi Sava ti je prilično loša na mokrom što nije dobro ako je po gradu kada su ceste skoro stalno mokre kroz zimu...po snijegu je super ali njega rijetko ima u gradu na kolniku...ja sam isto za Clio 3 uzeo Kleber Krisalp 3...na testovima u vrhu..390/kom 1
Jasa Posted October 10, 2019 Posted October 10, 2019 On 09. 10. 2019. at 18:24, viktor04 said: Vredestein Wintrac Pro ili Nokian Wr A4? Vidim po testovima da hvale dosta pa sam malo neodlučan kaj uzet Expand Ja uzeo Vredestein jer je isto bio prvi po nekim testovima, pa ćemo vidjet kakva će se pokazat 1
Rockatansky Posted October 10, 2019 Posted October 10, 2019 On 01. 10. 2019. at 13:44, Srele_St said: Felge su prodane a sta se tice zimskih guma onda cemo blizak lm005. Samo mi se javi malo prije da ti pripremin set. Poslano sa mog Redmi Note 7 koristeći Tapatalk Expand Čujemo se druže
Dottore Posted October 10, 2019 Posted October 10, 2019 On 10. 10. 2019. at 14:12, Rockatansky said: Čujemo se druže Obavezno počasti kavu.Отправлено через iPhone
msporis Posted October 23, 2019 Posted October 23, 2019 Imaju li formuski trgovci šta pametno od zimskih guma za dimenziju 205/55/16? Zasad mi je favorit Kleber Krisalp HP3, koji je 423 kn/kom u Vulkalu. Taj cjenovni rang gađam, ide na auto od cure koji ionak ide u prodaju tokom ili krajem zime, inače bi vjerojatno rastegnuo budžet do TS860...
Gabre Posted November 2, 2019 Posted November 2, 2019 On 26. 09. 2019. at 21:25, Gabre said: narucio, opet im osla cijena ko nekidan, i jos je sad akcija da dobijes $80 postom kredit. pa eto, javim se kroz mjesec, dva sa dojmovima. sto sam uspio procitati svi su prezadovoljni. kako bukom, tako ponasanjem. Ima vrlo slicnu saru kao michelin PA4, continetal, pirelli... Expand On 26. 09. 2019. at 22:01, Kegalj said: Jesi dobio formular za kredit koji sam ti linkao gore? Expand uglavnom, danas montirane, u prvih 20km nemam prigovora tihe, lijepo reagira volan, koci dobro, sara izgleda super jucer poslao za rebate, danas vec javili da je odobreno i da salju postom karticu s lovom sad jos snijega da padne
maredo Posted November 3, 2019 Posted November 3, 2019 On 28. 09. 2019. at 10:32, Rockatansky said: I ja se mislim za njih, javi kad m ontiraš kakve su po kiši.Evo zadnja tri dana maltretiram Kleber Krisalp HP3 po kiši, pogotovo gdje znam da je asfalt lošiji i izuzetno sam zadovoljan, ako su takve i po snijegu apsolutni best buy 1
zerowaf Posted November 3, 2019 Posted November 3, 2019 (edited) On 03. 11. 2019. at 9:09, maredo said: On 28. 09. 2019. at 10:32, Rockatansky said: I ja se mislim za njih, javi kad m ontiraš kakve su po kiši. Expand Evo zadnja tri dana maltretiram Kleber Krisalp HP3 po kiši, pogotovo gdje znam da je asfalt lošiji i izuzetno sam zadovoljan, ako su takve i po snijegu apsolutni best buy Expand Potvrđujem! Montirane su prije 8 dana i za sad ih mogu mirne duše preporučiti. U odnosu na NS2R koje vozim kao ljetne gume su puno udobnije, što nije iznenađenje. Na kiši se voze normalno. Grip na suhom i pri cca 10° do 12° C je nešto slabiji nego sa NS2R, ali sam siguran da će biti bolji pri 0° C od Nankanga na istoj temperaturi. Vožnja višim brzinama, npr na njemačkom autobahnu (naravno! ) je sigurna. Budget guma koja vrijedi više nego što košta IMHO. Disclaimer - sve navedeno je iz iskustva sa mojim autom i njegovim ovjesom, masom, rasporedom težine itd. YMMV. Edited November 3, 2019 by zerowaf 1
MoschuS Posted November 3, 2019 Posted November 3, 2019 Imamo mi na Maganeu Kleber HP3 vec par sezona i guma je stvarno za preporuku a cijena vrlo korektna. Sent from my Redmi Note 7 using Tapatalk
Doktor Posted November 3, 2019 Posted November 3, 2019 Ja četvrtu sezonu vozim Bridgestone Blizzak LM 001, koje sam kupio kad su tek izašle. I dalje sam prilično zadovoljan. Auto: Xsara, 185/65-R15
_DEX_ Posted November 5, 2019 Posted November 5, 2019 On 04. 11. 2019. at 22:46, KA2001MR said: Preporuka za zimske za Vita??? Expand Moj stari je prekjucer stavio Hankook na Vito 2011. Jucer sam ga vozio po kisi i nemam nikakve zamjerke. Jedino kaj jos nije stisla zima, pa ti nemam kaj pametnije za rec. 1
matija0311 Posted November 5, 2019 Posted November 5, 2019 On 04. 11. 2019. at 22:46, KA2001MR said: Preporuka za zimske za Vita???Vozimo ljetne i zimske Hankok i zadovoljni Nisu najbolje al su ok Sent from my iPhone using Tapatalk 1
