Goertosing Posted January 3, 2019 Posted January 3, 2019 On 03. 01. 2019. at 17:00, Lovrek said: imamo isti.... + lci lampe prije/poslije Expand izgleda da su presprejali ovaj zid od te krajnje desne rupe..... ovako je prije ta rupa izgledala
Radman_ED35 Posted June 1, 2020 Posted June 1, 2020 @Ozy jel ovo jos uvijek postoji? Koja je procedura sada? Ty ??
Lovrek Posted June 1, 2020 Posted June 1, 2020 Bas i mene zanima... moj nastavak, ovaj gore, izgleda zgoreno Sent from my VOG-L29 using Tapatalk
Ozy Posted June 1, 2020 Author Posted June 1, 2020 pa sve kako pise u prvom postu s tim da imam novi broj ogl/37So7BS
Radman_ED35 Posted June 1, 2020 Posted June 1, 2020 Zvao, došao, rekao sta zelim(inox fi76, mandrel piganje, tig zavarivanje, nastavci), slozili ponudu, dogovorili termin. Ty @Ozy ?
Kic Posted June 1, 2020 Posted June 1, 2020 Nek novost da pigaju Inox iznad 70mm? Mislio sam da idu do 70 na pigalici, a iznad koriste koljena?
Oggy Posted June 1, 2020 Posted June 1, 2020 Kako je sa atestom njihovih uradaka? Od ispušne grane pa na dalje?
Bmwlik Posted June 1, 2020 Posted June 1, 2020 Skuplje izvedbe imaju homologacijske oznake i mogu se uredno atestirat, imaju sve papire... 1
Kic Posted June 1, 2020 Posted June 1, 2020 On 01. 06. 2020. at 16:31, Oggy said: Kako je sa atestom njihovih uradaka? Od ispušne grane pa na dalje? Expand Uredno sam atestirao srednji i zadnji Inox lonac (70mm) 1
Bezimeni Posted June 2, 2020 Posted June 2, 2020 On 01. 06. 2020. at 10:07, Radman_ED35 said: Zvao, došao, rekao sta zelim(inox fi76, mandrel piganje, tig zavarivanje, nastavci), slozili ponudu, dogovorili termin. Ty @Ozy ? Expand Moze info na PM kolko te izasla ta igra. tnx
Radman_ED35 Posted June 2, 2020 Posted June 2, 2020 (edited) On 01. 06. 2020. at 13:58, Kic said: Nek novost da pigaju Inox iznad 70mm? Mislio sam da idu do 70 na pigalici, a iznad koriste koljena? Expand Kolko ja znam, kreću u serijsku proizvodnju i žele postat konkurent millteku, akrapu itd. I auto ce kod njih biti 2 dana jer auspuh salju u taj proizvodni pogon, nemogu to sve napravit tamo na licu mjesta. (rekao mi je tocnu lokaciju proizvodne hale al sam zaboravio ? ) On 01. 06. 2020. at 16:31, Oggy said: Kako je sa atestom njihovih uradaka? Od ispušne grane pa na dalje? Expand Skuplji lonci su homologirani i mogu ti dati papire za atest, cijevi grane i auspuha ne ulaze u atest jer je to materijal i nemas sta atestirat, jedino moras uzet HJS katalizator koji ima homologaciju za tvoj volumen motora i konjažu, a Lasta ti ga navari i njega atestiras posebno. Edited June 2, 2020 by Radman_ED35 1
dar-mar Posted June 2, 2020 Posted June 2, 2020 On 02. 06. 2020. at 7:53, Radman_ED35 said: Kolko ja znam, kreću u serijsku proizvodnju i žele postat konkurent millteku, akrapu itd. I auto ce kod njih biti 2 dana jer auspuh salju u taj proizvodni pogon, nemogu to sve napravit tamo na licu mjesta. (rekao mi je tocnu lokaciju proizvodne hale al sam zaboravio ? ) Expand Moji prvi susjedi, u Domaslovcu? oćeš da skontroliram kaj se radi na autu
epicuser Posted June 2, 2020 Posted June 2, 2020 lasta konkurencija nekome ? pa daj prvi april je prosao onaj m3 e46 lonac kaj su kopirali milltek im jos stoji gore u radioni jer je zvuk kriminal, bio je covjeku na autu 30 sekundi i morali su skinut ga dole 2
Ozy Posted June 2, 2020 Author Posted June 2, 2020 On 02. 06. 2020. at 15:41, epicuser said: lasta konkurencija nekome ? pa daj prvi april je prosao onaj m3 e46 lonac kaj su kopirali milltek im jos stoji gore u radioni jer je zvuk kriminal, bio je covjeku na autu 30 sekundi i morali su skinut ga dole Expand daj ti reci nama koji to e46 m3 ima dobar zvuk?
Ozy Posted June 2, 2020 Author Posted June 2, 2020 On 02. 06. 2020. at 19:00, Hic said: Od Mog brata, sa miletovim auspuhom. Predobar. Expand daj tu klip neki jer se svaki čuje kao yugo sa probušenim zadnjim loncem a mille je za mene najbolji majstor, bolji i od akrapa i svih drugih no ovo je topic o lasti, koliko para toliko muzike 1
Hic Posted June 2, 2020 Posted June 2, 2020 Dobijes klip jedino tamo gdje sunce rijetko sijeAuto se cuje jebeno i nikako kao yugo!
Zoka RS Posted June 2, 2020 Posted June 2, 2020 Ja na 7r imao zadnji lonac od laste i fakat je bio oke s obzirom na cijenu,pukao jednom nosac to zavarili i gas dalje...
Oggy Posted June 3, 2020 Posted June 3, 2020 On 03. 06. 2020. at 13:57, Garet said: Nema do Mille-ta... Expand A on je ko prije dvajst godina Sole? Ili je to sve iz vana narudžbe iz kataloga?
Rallye VR6 Posted June 3, 2020 Posted June 3, 2020 Na sve aute koje radim mi covjek iz Pule slozi od Lastovcica lonce , nista ne bruji i prolaze ateste bez problema.Ulozeno - dobiveno je super. Kec tfsi , cijev sa jednim loncem , auto se uopce ne cuje , tisi je nego serijski polo gti 1.8t Tko hoce izdrkane tig zavare i to sve da bude do yaya , apoteka , zna se koji ljudi to rade i koliko je to love. Na R32 po jedan lonac i cuje se bolje nego 90% R32 koji imaju tanki zvuk kao da lonce sutas Poslano sa mog SM-J510FN koristeći Tapatalk Poslano sa mog SM-J510FN koristeći Tapatalkhttp:// 6
Garet Posted June 3, 2020 Posted June 3, 2020 On 03. 06. 2020. at 15:27, Oggy said: A on je ko prije dvajst godina Sole? Ili je to sve iz vana narudžbe iz kataloga? Expand Ne bih znao to..bio sam poslao upit tom Lasti alj nisam uopce dobio odgovor,mozda bira sta ce raditi...Mille-ta sam zvao, popili kavu,on pogledao izmjerio i sve rijesio ....stvarno super usluga,
semper Posted June 3, 2020 Posted June 3, 2020 On 03. 06. 2020. at 18:00, Garet said: Ne bih znao to..bio sam poslao upit tom Lasti alj nisam uopce dobio odgovor,mozda bira sta ce raditi...Mille-ta sam zvao, popili kavu,on pogledao izmjerio i sve rijesio ....stvarno super usluga,Ja sam kod lastovcica radio na escortu komplet inox od turbine + 2 protocna lonca i cifra je bila negdje oko 500e
Rwd Posted June 3, 2020 Posted June 3, 2020 Koliko para toliko muzike,radio sam auspuh kod Nikole(Milletech) i ne žalim ni lipe.Tko je picajzla i pati od detalja nema šta dalje tražiti jer boljeg kod nas nema.Od varova,kvalitete materijala pa sve do dizajna samog auspuha.Stvarno možete birat šta želite i taj auspuh je projektiran sa planom.Što hocu reći,recimo malo ljudi zna napravit ispuh na nekom N/A motoru da ne izgubi snagu nego ju čak dobije.Bila je priča o onom e90 M3 koji je dobio bas dosta snage samo sa full milletechom,mislim čak 5 dužina u odnosu na stock sto je jako puno. Dosta ljudi otpiše Milletecha jer su čuli da je preskup bla bla a recimo nisu ni poslali upit niti se informirali. Kad usporediš recimo cijenu full Akrapoviča ja garantiram da Nikola može složit ispuh za osjetno manje love.Uvijek bi prije otišao kod njega jer ti napravi doslovno ispuh kakav želiš. 1
